Results 1 to 3 of 3
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    The making of a Chain Stay
    So I have had a couple people ask me about the CS on my 36er. Im starting another frame so I thought I'd show what it takes to make a 2ft
    long CS so here goes! Starting with a 4ft piece of 3/4" x.065 tubing.The making of a Chain Stay-dsc00701.jpg
    Next I find center and put a mark for later after the bending process
    to cut the tube in half then off to the bender (JD2). I don't put a line at
    start of the bend since I will have excess to cut off at the other end I just
    line up the end of the tube with shoe coupler. On the CS I pull it 2 notches this makes it easy for repeatability.
    The making of a Chain Stay-dsc00702.jpgThe making of a Chain Stay-dsc00703.jpgThe making of a Chain Stay-dsc00704.jpg
    After I repeat this on the other end it gets cut in half.The making of a Chain Stay-dsc00705.jpgThe making of a Chain Stay-dsc00707.jpg
    Also I forgot to mention you'll need your Waltworks Sox on to complete any of this!
    Now on to dimpling the the stay for more tire clearance I made this tool last year and I have only used twice before, as you can see its made with a 2 1/2lb dumb bell. To get the similar result I measure the exposed shaft on the jack
    The making of a Chain Stay-dsc00708.jpgThe making of a Chain Stay-dsc00709.jpg
    To ovalize the tube from the bend to the end it gets pressed between a piece of wood and a bigger press head. Same as before press to desired result and measure the jack shaft.
    Attached Thumbnails Attached Thumbnails The making of a Chain Stay-dsc00710.jpg
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    Nice!
    andy walker
    Nov 2008
    Thats cool! Thanks for sharing.
    Steven
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
  1. Chain wrapping back around crank sprocket catching on chain stay what to do?
    By Thall36 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2013, 08:53 PM
  2. Help! Chain will not stay on.
    By KCKS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2012, 06:09 AM
  3. Replies: 3
    Last Post: 03-04-2012, 08:40 PM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. chain stay
    By napa in forum Specialized
    Last Post: 06-13-2011, 07:19 AM
