Results 1 to 2 of 2
    Internal gear routing in advice frame- advice needed
    Hi, I am think of running both the front and rear gear cabling through the down tube on a road bike I am building out of Columbus life tubing. Planning on using brass tubing to route the cable through the tube and then brazing some covers over the holes. Can anyone see any problems with compromising the strength of the down tube? The gear cables would exit the down tube on the bottom just before the bottom bracket and then wrap around the underside of the bottom bracket.
    Any advice much appreciated.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    The covers restore the material loss.
    Eric
    If I don't make an attempt, how will I know if it will work?
  1. 29er Frame Fitting - Advice needed
    By Eric Taylor in forum 29er Bikes
    Last Post: 10-15-2013, 08:54 PM
  2. Internal gear hub advice needed
    By rusty904 in forum Commuting
    Last Post: 03-06-2013, 02:32 PM
  3. Frame Size Advice Needed
    By wheeljack in forum Beginner's Corner
    Last Post: 04-23-2012, 06:57 PM
  4. Advice needed - What gear ratio for 2x10?
    By njdj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2012, 12:14 PM
  5. Frame Building 101 Advice Needed for Newbie
    By SweetDoug in forum Frame Building
    Last Post: 01-02-2011, 02:31 PM
