Results 1 to 13 of 13
    Nemophilist
    Reputation: TrailMaker's Avatar
    How do YOU set a Crown Race for Welding?
    Hey;
    Looking for ideas on setting a crown race as square as possible before welding. All that comes to my mind is to machine a die to a snug slip fit for the steerer that can be slid down and used as a square. It seems I'd like something theoretically a little closer than eye-balling.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Feb 2013
    Eyeball is good enough, because of course you cut the race seat after welding/brazing.
    RCP Fabrication
    28.6mm Paragon tube block with 1/4" of one end opened to 30.0mm
    Attachment 834920
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Hammer.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by BenCooper View Post
    Agreed. I just slip it in place and braze it.
    mtbtires.com
    Grease, flathead screwdriver, hammer....done
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Quote Originally Posted by Sprocking Crail View Post
    I think we're talking about the crown race seat, that gets welded/brazed to the steerer tube. Not the crown race that the bearing sits on from the headset.
    Hey, good question TM. Usually I lathe these after welding, its a very light skim and this squares it up. I braze mine, but I see a lot of manufactured unicrown forks are Tigged on the outer side. Cast crowns used on road bike forks are integral with the crown itself so you machine up afterwards from brazing. To keep the seat square when setting up, slip a squared over-sized tube down the steerer and tack the outer edge, remove tube and weld up, you will be close.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Feb 2013
    Yup - I do the same, well, I braze it on, do a rough cut in the lathe, then finish off with a Park crown race cutter to get it spot on.
    But since it's getting the cutting operations after welding/brazing, it's not necessary to be obsessive about getting it straight to start with.
    pvd
    pvd is offline
    If you can put the fork into a lathe (like I do), why would you use the Park cutter? You can do far better with the lathe.
    Nemophilist
    My solution;
    A good way of making use of one of those little slugs of bar stock that are too small for anything else.
    Feb 2013
    Quote Originally Posted by pvd View Post
    My lathe isn't big enough for a complete fork. So my fork procedure is:
    Braze crown to steerer
    Rough cut crown in the lathe
    Braze in fork blades
    Send off for paint
    Final cut with Park cutter to remove paint traces and get final crown diameter and face.
    Dec 2011
    Quote Originally Posted by TrailMaker View Post
    My solution;
    I guess when you see this, an old H/bar Stem would become a handy tool.
    Eric
    I'm doing what BenCooper is doing.
    andy walker
  1. space in between bottom of crown race & top of fork crown
    By TheeSuperUberV in forum Beginner's Corner
    Last Post: 09-15-2013, 06:35 PM
  2. Crown race question
    By KEITH21 in forum Shocks and Suspension
    Last Post: 01-11-2013, 07:46 PM
  3. Crown Race Question
    By ZXFT in forum Shocks and Suspension
    Last Post: 09-09-2011, 10:04 PM
  4. Possible Welding flaw on my frame = welding "hole" = Crack?
    By Nick_M2R in forum Downhill - Freeride
    Last Post: 02-11-2011, 07:29 AM
  5. Replies: 6
    Last Post: 08-10-2010, 06:43 AM
