Results 1 to 8 of 8
    How to attache these dropouts?
    Hi - I don't quite get these dropouts... what is the point of the cutouts on the tabs? How should they be attached... i.e. how far in should they go? To complicate things the tabs are tapered. Should I cut a v shaped slot to fit? Would really appreciate your thoughts!
    Most Delicious
    Reputation: dr.welby's Avatar
    Quote Originally Posted by rpiontek View Post
    Probably they save weight and heat up to temperature faster.
    Cover the holes enough so they aren't exposed when you taper your ends.
    Only if you really want to. You can just overfill a square notch and then file flush.
    Interesting, where'd you find them?
    cheers
    andy walker
    Hi Andy, they are here..
    * Kalavinka * Tsukumo Cycle Sports
    Thanks Dr. Welby!
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    I wonder if the tapers are for allowing straight stays to come in on an angle, not requiring the drop-out to be bent or using S-bend stays.
    Eric
    If I don't make an attempt, how will I know if it will work?
    cool, show a pic of your finished frame please
    cheers
    andy walker
    Most Delicious
    Quote Originally Posted by Eric Malcolm View Post
    I could see it helping that, but I've also seen it as a cosmetic treatment:
    <a href="http://alexandchristine.smugmug.com/Bicycles/Framebuilding/Ivy-T/i-rDjpPDD/A" title="Photo & Video Sharing by SmugMug"><img src="http://alexandchristine.smugmug.com/Bicycles/Framebuilding/Ivy-T/i-rDjpPDD/0/S/P1050896-S.jpg" title="Photo & Video Sharing by SmugMug" alt="Photo & Video Sharing by SmugMug"></a>
    It's a neat look, always wanted to try it.
    Reputation: Meriwether's Avatar
    i bet they're for domed stays perhaps?
    See this blog for pictures. Once v-slotted you hammer the chainstay ends over the dropout so you wouldn't have to fill it with much brass at all for a solid connection.
    Just a theory...
  1. How do I buy dropouts for a DT?
    By jitenshakun in forum Knolly
    Last Post: 07-13-2012, 06:55 AM
  2. Dropouts 133 150
    By Trail_Blazer in forum General Discussion
    Last Post: 07-13-2012, 01:13 AM
  3. Worn dropouts
    By Mtn-Rider in forum Wheels and Tires
    Last Post: 07-05-2011, 09:54 AM
  4. 142 x 12 dropouts
    By 18bikes in forum Frame Building
    Last Post: 06-16-2011, 11:17 AM
  5. Rip 9 Rear Dropouts
    By pete weber in forum Niner Bikes
    Last Post: 04-12-2011, 05:34 PM
