Go Back   Mtbr Forums > Classic Mountain Bike Forums > Frame Building
Reply
LinkBack Thread Tools Display Modes
Old 12-12-2009   #26
gjenkins@'s Avatar
Rep: gjenkins@ will become famous soon enough
user gallery
Originally Posted by cannonballtrail
My Pro 29er cracked along the helix and they fixed it under warranty. Great customer service and this is by far the best bike I have ever owned or ridden, but yes, even I must ask, what's the point? Well, the idea is over 100 years in the making.
http://www.theoldbicycleshowroom.co....cle-1510-p.asp
On a more serious note, I don't understand "Looking at tubing cross-sections in CAD drawings, it became apparent." This was determined by "looking at" just as Einstein "looked at" a clock tower and came up with relativity, I guess. A giant leap for mankind from the boys at Lynskey? What happened to a finite element analysis of bending moments, torsional rigidity, compression, and tension? Test results? Their write up either doesn't want to give away trade secrets and RD or they're just spewing hot ti. Whatever the case might be, the design looks cool and the bike is a blast to ride.
I am contemplating a Ti Lynskey or Vassago this next summer. I am open to new tech and will wait to hear more reviews from people who know what they are talking about before I make a decision on this. Owner reviews (such as yours) and technical analysis basically.
gjenkins@ is offline   Reply With Quote
Old 12-12-2009   #27
Rep: Climber999 is an unknown quantity at this point
user gallery
Originally Posted by JohnnieA
I think that if helix was stronger than round, tree limbs would be helix shaped. Trust mother nature.
I am afraid you rely incorrectly on the principle of natural selection. Mother nature improves things when there is pressure to change; utmost rigidity and resistance to torsional pressures have not been trees top priorities.
Anyways, Lynskey has an identical model--dimension wise--which Ted Guitar tested and pointed out to flex in the frame. From personal experience, the Pro29 2010 does not show a hint of flex whatsoever. Now, I may not be as heavy or strong and Ted, so it would be interesting to have him test that bike as well.
Climber999 is offline   Reply With Quote
Old 12-13-2009   #28
pvd
pvd's Avatar
Rep: pvd will become famous soon enough
user gallery
Originally Posted by Climber999
...Mother nature improves things when there is pressure to change; utmost rigidity and resistance to torsional pressures have not been trees top priorities. ...the Pro29 2010 does not show a hint of flex whatsoever.
That sounds like a really bad bike.
Any road or mountain bike needs to be designed to have just the right amount of flex in just the right ways. A mountain bike that doesn't flex will not track well in corners at speed. A road bike won't hug the road quite as well without some flex. The only bike that really shouldn't be flexing is a velodrome bike.
Motorcycle companies put massive amounts of time and energy into making sure their chassis flex properly. They stopped making hyper-rigid chassis about 20 years ago.
Basically, bicycles ARE just like trees. They flex to survive.
pvd is offline   Reply With Quote
Old 12-13-2009   #29
Rep: unterhausen will become famous soon enough
user gallery
even if the objective was to avoid flex, given the same amount of material and any choice of shape possible, a helix really seems unlikely as a shape that would win out as the stiffest tube. I think our intuition incorrectly takes work hardening into account into our mental calculations of stiffness. Anyone that has bent a paperclip to failure feels the clip becoming harder to bend as it becomes work hardened. But that is outside the elastic limit of the material, something you don't experience with a bike that is going to last until the next ride.
unterhausen is online now   Reply With Quote
Old 12-14-2009   #30
coconinocycles's Avatar
Rep: coconinocycles will become famous soon enoughcoconinocycles will become famous soon enough
user gallery
i'm working on the "moebius" frame - it's all mine & it's going to be 15263% stiffer then anything you guys have ever seen. heads up. Steve Garro, Coconino Cycles.
__________________
steve garro el jefe/el solo. coconino cycles www.coconinocycles.com www.coconinocycles.blogspot.com
coconinocycles is offline   Reply With Quote
Old 12-14-2009   #31
Rep: Schmitty is on a distinguished road
user gallery
You got the translation wrong on this. Should read: "Very few 'new' marketing gimics are new. Most have been tried, and few have stood the test of time".
All those tubes will break b/c forming them into that shape has already broken them most of the way. Out of S3? What a joke.
-Schmitty-
Actually, the bike in that link has round tubes with helical seams ala cardboard toilet paper roll. Different deal.
Schmitty is offline   Reply With Quote
Old 12-14-2009   #32
Rep: dbohemian is on a distinguished road
user gallery
FEA analysis
Just because I was curious.
I modeled two tubes. Made it real simple and FEA is only as good as the info in and this is a simple beam bending example. Not very fancy.
One was a .6 wall 1.5 tube round and the other was a helix tube same size, same thickness.
I applied a 100lb load in one direction while fixing one end. Tubes weigh the same within a few grams.
Bottom line as far as displacement is concerned. Round tube flexes 12.35mm and helical tube flexes 15.08mm. Helical tube is not as stiff as a round tube. At least in pure sideways loading. I also ran some torsional scenarios. Round tube is stiffer again by a fair amount and overall peak stresses are less for the round tube.
The helix tube began to show points of failure at 1.5 times a factor of safety and the round at 1.75. The round tube is superior here also.
I would say though, taking a queue from Mythbusters........This myth is BUSTED....
__________________
All the best,
Dave Bohm
Bohemian Bicycles
http://www.bohemianbicycles.com
http://www.framebuildingschool.com
dbohemian is offline   Reply With Quote
Old 12-14-2009   #33
swift's Avatar
Rep: swift is on a distinguished road
user gallery
...But you're modelling a hexagon tube vs. the original square.
The stress concentrated on the apex of the corner is what I would have expected. Good illustration.
The springer fork on that Indian Larry chopper is sweet!
swift is offline   Reply With Quote
Old 12-14-2009   #34
user gallery
Opps. Well, I changed it to a square of equal weight. The deflection got even higher and stresses are greater still. Really busted.
One of use should make a springer with chain
__________________
All the best,
Dave Bohm
Bohemian Bicycles
Old 12-14-2009   #35
Moderator
Moderator
Rep: Walt is just really niceWalt is just really niceWalt is just really niceWalt is just really nice
user gallery
Say "what" again!
Look at the big brain on Brad! Er, I mean Dave.
BTW, we will see you in like 3 weeks. Be ready for some mountain biking and beers...
-W
__________________
Waltworks Custom Bicycles
Boulder, CO USA
www.waltworks.com
waltworks.blogspot.com
Walt is offline   Reply With Quote
Old 12-14-2009   #36
WAWE
Rep: aosty will become famous soon enough
user gallery
Look at his pic again... it's actually pentagonal...
@bohm - Nice job!
aosty is offline   Reply With Quote
Old 12-14-2009   #37
On-One Bikes & Titus Cycles. Mod only for WA/OR
Moderator
shiggy's Avatar
Rep: shiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud ofshiggy has much to be proud of
user gallery
That will be the perfect bike for my "Escher" trail! An all downhill loop.
__________________
mtbtires.com
shiggy's Out There with On-One and Titus in America.
All About the Ride
shiggy is offline   Reply With Quote
Old 12-14-2009   #38
user gallery
my lawyers tell me it's safe to reveal that I have applied for a patent for bicycle tubes based on the Klein bottle and all other higher dimensional manifolds with a non-intersecting surface. The only problem is that they are really hard to miter and sometimes fatigue cracks start in the higher dimensions and you can't see them until it's too late. The advantage is that they are optimally horizontally stiff and vertically compliant ... as far as you know.
Old 12-14-2009   #39
Most Delicious
dr.welby's Avatar
Rep: dr.welby will become famous soon enough
user gallery
I'm working on a prototype Shroedinger's Frame but I can't find anyone willing to test ride it.
Meanwhile: Quantum Slacks
dr.welby is offline   Reply With Quote
Old 12-14-2009   #40
user gallery
I dunno, that should be a real hit at Critical Mass
Old 12-15-2009   #41
Victim of Saddle Rage
cannonballtrail's Avatar
Rep: cannonballtrail is on a distinguished road
user gallery
FEA Analysis
The thread that doesn't die. Thanks for posting the FEA. I think Lynskey varied the wall thickness, however the point is a Helix has more flex than a round tube regardless. Second, as my materials prof used to say "garbage in garbage out" when it comes computer models vs. in-situ tests, so I think a lab test is in order. Anyone want to sacrifice a Pro 29er?
Well, I just got back from 3 days on the road with my Helix. Tucson Mnt Park, Trail 100, and Coast to Coast on National in PHX + the hill climb and Mormon. The bike is actually quite flexy, but some flex=comfort and control IMHO. At 140 lbs with gear, I might not be the best tester.
Still on a level of strangeness the Pro 29er pales in comparison to the black sheep.
__________________
" the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us." C&H
cannonballtrail is offline   Reply With Quote
Old 12-15-2009   #42
user gallery
i bet it kills you like a cat in a box............maybe. + the klein jar comment made me bust up & i feel like crap, so thanks, Ut! Steve Garro, Coconino Cycles.
__________________
Old 12-15-2009   #43
Rep: surlytman is on a distinguished road
user gallery
I'm surprised Gary Fisher didn't come up with that marketing drivel!
__________________
Want to teach your kids to ride without training wheels at ages 2-4? www.stridertk.com
surlytman is offline   Reply With Quote
Old 12-15-2009   #44
user gallery
Niner goes hexagonal
Just received a mail from Niner with a preview of their Air 9 carbon and what are they advertising? A hexagonal downtube for better "stiffness." Now this is not the same as twisting a tube or plastically deforming a tube and calling it stiffer, but it is interesting that they have departed from the round tube concept. Do they know something we don't?
http://www.ninerbikes.com/fly.aspx?l...ikes&taxid=271
__________________
Old 12-15-2009   #45
user gallery
nope. it's just that with production units if you don't have a new offering every model year people loose interest. in custom every bike is it's own model...........just sayin - not bagging on niner........... Steve Garro, Coconino Cycles.
__________________
Old 12-15-2009   #46
Rep: jcrew94123 is on a distinguished road
user gallery
While they mention hexagonal, Niner doesn't mention that they twist the downtube - it looks pretty straightforward/symmetrical to me in the pics on their site.
__________________
- Jeff
____________________________
'97 Adroit, '96 Adroit, two '93 Attitudes & '90 Attitude
jcrew94123 is offline   Reply With Quote
Old 12-15-2009   #47
user gallery
[QUOTE=cannonballtrail] Do they know something we don't?
[QUOTE]
They can barely make a frame that doesn't break....
I'd insert a youtube of Steely Dan doing Asia here, but I'm lazy.....
-Schmitty-
Old 10-14-2010   #48
gjenkins@'s Avatar
user gallery
Are you kidding? Huckin Kitty is both riding it and not riding it as we speak.
Old 10-14-2010   #49
vulture's Avatar
Rep: vulture is on a distinguished road
user gallery
I wonder if the direction of the twist is specific to the northern hemisphere? I mean whats that thing gonna ride like if it conflicts with the Coriolis force when it is in say, New Zealand or some other southern hemisphere location? I love the bike industry.
vulture is offline   Reply With Quote
Old 10-14-2010   #50
shovelon's Avatar
Rep: shovelon is on a distinguished road
user gallery
My Karma hates your Voodoo.
shovelon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
