Results 1 to 13 of 13
    Oct 2013
    Headtube reaming a factory frame?
    I posted this on the general forum, but think that it is more of a frame-building question
    The bottom of my headtube has an internal diameter or 44mm, and na external diameter of ariund 65.5mm
    I would like to fit a headset with a bottom cup OD of 54mm
    The bottom of the headtube has a wall thickness of around 10.5mm
    Can I ream/bore the bottom ID to 54mm to fit the headset?
    The frame is constructed from Al6061T6
    The dimensions listed here are not exact, would obviously need to have everything within tolerance
    What are your thoughts?
    Jan 2011
    You should just get the proper sized headset cup.
    1cm thick head tube, Are you sure? That seems crazy thick even for aluminium are you sure it is not just thick at the face (i.e. hourglass shape).
    In any case, reaming is not the way to enlarge holes and not recommended for this much material removal. Getting the proper sized headset cup is the way to go.
    Mark Farnsworth, Raleigh, NC
    http://farnsworthbikes.com
    Oct 2013
    The headtube is tapered, and yes it is an hourglass shape, but with a wider bottom than top.
    The top of the headtube has ID 44 and OD 55
    The bottom was only opened to 44mm to fit the 1.125inch steerer that came with the model - other models with the same frame came with tapered steerers, 1.124 - 1.5
    I assume that the same headtubes were opened to 54mm to accomodate the tapered headsets OD of 54mm
    Most Delicious
    Reputation: dr.welby's Avatar
    It's not an insert?
    There's just no sane reason to make a 10mm thick head tube just so you can miter the same complicated miter as your tapered steerer bikes.
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Im with DR Welby are sure it's not an insert reducer maybe post up a pic so we can see!
    PAYASO 36er.....Live the Circus
    The cat's name is jake
    Reputation: BungedUP's Avatar
    Aug 2003
    What is the brand/model of frame, out of curiosity?
    The headtube would best be modified with a milling machine capable of circular interpolation (CNC without enclosure, or a K&T 2D, in the unlikely event you knew someone with one of those), then reamed to finish size. A reamer would not be able to handle that type of cut. It could be done incrementally with a boring head in a manual mill as well. If you tore the frame down, figure on an hour+ to machine a plate to use as a cap to fixture the head tube on the mill table, and another hour + to machine the headtube. Figure between $65 and $125/hr for machine work.
    Oct 2013
    Frame is a scott spark 29er team 2012. This model comes with a straight steerer fork, higher spec models come with tapered steerer forks.
    Here are some pics:
    Looking down into the headtube
    Looking from the bottom. The ring is the flange of the headset, not a spacer
    Front view of frame
    Side view of frame
    View from the bottom. Paint has been sanded away to check if there was a spacer that had been painted over
    Close up from the top,
    the black inner ring is the top of the lower cup,
    the headtube then has a radius from ID 44mm to ID 54mm, followed by a taper out to about 57mm
    I have a milling machine, so using a boring head would be the preference.
    Plan on using a dial test indicator to centre/align the milling head to the current hole in the headtube.
    However I am not sure how to secure the headtube (with frame attached) to the mill - hoping to get some help with this part!?
    Oct 2013
    Quote Originally Posted by BungedUP View Post
    The headtube would best be modified with a milling machine capable of circular interpolation (CNC without enclosure, or a K&T 2D, in the unlikely event you knew someone with one of those), then reamed to finish size. A reamer would not be able to handle that type of cut. It could be done incrementally with a boring head in a standard mill as well. If you tore the frame down, figure on an hour+ to machine a plate to use as a cap to fixture the head tube on the mill table, and another hour + to machine the headtube. Figure between $65 and $125/hr for machine work.
    Cap fixture could be the solution for securing it - what exactly do you have in mind?
    Aug 2003
    Take a piece of plate larger than the diameter of the hole you need to make by 2"+ in all directions, drill 3 or 4 holes in it for your stud hardware (to clamp to the table), bore a hole for access to the headtube, and sandwich the headtube between the mill table and the plate. Obviously, you'll need to plan out where the stud hardware holes are in relation to the table slots or bolt pattern (if you use a sub-plate), and the clearance hole.
    You may need to space the bottom up from the table a tad to clear the top tube, if there isn't much extension of the headtube. You'll get it figured out when you start setting up.
    Watch out that the taper of the HT doesn't cause you trouble - if you bore it deep, you may start to thin the wall down quite a bit as you move into the external taper.
    Reputation: adarn's Avatar
    why don't you just run an external cup on the bottom?
    Oct 2013
    Quote Originally Posted by adarn View Post
    The new fork is raising the front a bit, don't want to raise it any more with an external cup
    Quote Originally Posted by Danielmessem View Post
    Hmmm, well a cane creek EC40 will run you like $30, it might be worth running that for a bit to see how it handles before hurting the frame.
    Oct 2013
    Can't argue with that - lets see how she handles
  1. Replies: 7
    Last Post: 05-13-2014, 09:20 AM
  2. Headtube reaming/facing
    By LGavin in forum Turner
    Last Post: 10-01-2013, 03:44 PM
  3. Replies: 2
    Last Post: 08-20-2013, 11:19 PM
  4. Replies: 3
    Last Post: 08-17-2013, 02:37 PM
  5. Headtube reaming, with a lathe, prior to brazing
    By JaquesN in forum Frame Building
    Last Post: 02-07-2012, 04:57 PM
