Results 1 to 3 of 3
    Headtube reamer for integrated 1.5 headset
    I will possibly be building a frame using one of the tapered columbus headtubes that uses seperate rings for an integrated headset (Page 9 here http://ceeway.com/acrobat%20files/Ca...bi2013_web.pdf) but I don't know of anyone who makes a reamer to true it up after brazing. Does anyone know who makes this cutter?
    I've also never used a system like this before so if anyone has and could confirm the build process for me that would be great. I'm assuming:
    - Cut headtube to length (taking into account lip on inserts)
    - Braze in rings (silver or brass depending on gap to fill, my gut says silver if I can so that I limit the heat)
    - Build frame
    - Ream
    Matt
    J_K
    J_K is offline
    How about reamer/facer from the Cyclus? .: RA-CO GmbH*•*IHR RADSPORT GROSSHANDEL*•*720940 - head tube reamer IHS 1 1/2" (52/7/45), spare*:.
    Maybe Peter have them available.
    Excellent, thank you. I hadn't thought of cyclus for some reason, I should be able to source that quite easily too
  1. Integrated Headset gap?
    By emdog4 in forum Beginner's Corner
    Last Post: 07-23-2012, 10:55 PM
  2. is integrated headset that bad?
    By timex99 in forum Ibis
    Last Post: 02-18-2012, 08:23 PM
  3. Integrated Headset Creek
    By Stratocaster in forum Specialized
    Last Post: 08-22-2011, 11:52 AM
  4. Threadless headset and Integrated headset?
    By ricky916 in forum Bike and Frame discussion
    Last Post: 07-24-2011, 12:07 PM
  5. Tapered, integrated headtube, straight 1 1/8" steer tube.
    By False in forum General Discussion
    Last Post: 06-23-2011, 08:25 AM
