Results 1 to 36 of 36
    650b me
    Reputation: golden boy's Avatar
    half-round files: diameters?
    (Sigh) This really shouldn't be this hard...
    Just so you know, I did my due diligence and reviewed Walt's FAQ before posting this. Unfortunately, my own findings conflict with the FAQ regarding file length/diameter. I have a 12" half-round file. I stuck it inside my 1.375" tube block and it is an exact match, or "bang-on" for our friends across the pond. (The FAQ equates 12" length to 1.25" dia)
    So riddle me this: What does a 10" length equate to (in dia.)? 8"? 14"? I can't find this information anywhere. Are there standards, or can it vary? Who knew files were such a complex subject? Money is tight and I only want to buy good files that match as closely as possible the common tube diameters. Thank you for indulging my anal-retentive questions.
    Reputation: adarn's Avatar
    does it matter
    I use an 8 inch for pretty much every single one of my miters. I spent time at first trying to figure this out too, but I think I've come to the conclusion that it doesn't really make a big difference.
    Also, I'm not sure the answer to your question. so sorry.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Not an anal question, a good question, just not much info and some guess work.
    I can only add to the list a 10" half round as suitable for 1 1/8 (28.6mm). A very common frame size.
    Look for BB @ about 38mm and Head Tube @ 36mm, 2 files is all you need to cover all those frame mitres.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    Same answer as Adam. I use about an 8" which seems to be 3/4-ish for my stays or to do detail work on larger tubes (where I have a small spot to touch down). I have a couple that are 10-14" long. I'd have to guess, but I'd say one is 1-1.25" and the other is 1.5 wide. I use the 1.25 a fair amount on larger tubes. I don't find much use for the big one, oddly enough. Perhaps because it is a bit too coarse, and a bit of a blunt instrument because of it.
    Trying to file miters with just the right size file is pointless, as you cannot stay straight enough with your strokes to make a tight miter like a hole saw, if that is what you are thinking. More importantly, find a file with a tooth count that gives you a good feel. Some are too fine and don't rip, and others are too coarse and you can't be smooth with them. I like my 3/4 and whatever the next one is for that reason. I tried looking back through my invoices to see exactly what size they are, for your... um... anal retentive pleasure, but couldn't find them.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Try this for some information:
    http://www.mcmaster.com/#hand-files/=ljeprx
    http://www.apexhandtools.com/brands/...iles/index.cfm
    I also that you find a used copy of the machinery handbook, I find that the 11th to 19th edition are the best for the home shop, do it yourself type of person, the newer ones are more on the technical end of terminology and can confuse you. Another great read is:
    "starrett book for student machinists". It's still a go to book after all these years.
    Framebuilder
    Reputation: Live Wire's Avatar
    Quote Originally Posted by TrailMaker View Post
    Hey;
    And yet, I do....with every miter on every frame. Angle grinder and files are all I ever use. 3-5 min per join.
    To the op- files do vary a bit, but most are 8" for 1" tubes, 10" for 1.125", 12" for 1.25". Since most of my ht's are close to the bb diameter I use the same 14" file for both.
    650b me
    Thanks to everyone for your replies. It's turning into a more interesting thread than I expected. At UBI, we were taught to use the file with the profile that most closely matched the miter you were cutting. TM, I have to disagree with you on this point. I believe that with care, one can create a 1.125" miter with a 1.125" file. Because, well, I've done it. But I do agree with your point about the cut or grade of the file. At UBI, every file size was available in two grades. I'm not sure, but I think I found the second cut files more to my liking than the coarser bastard cut. Yeah, this sh!t matters to me. I'm a bit of a Luddite, and I believe in using hand tools whenever possible. For me, it goes to the core of being a craftsman.
    Moving on...sounds like there might be some variability on diameters, since my 12" is definitely a 1.375 dia. That said, I might as well pick up an 8", 10" and 14" in my preferred grade and call it good.
    Nemophilist
    Hey...
    I guess I don't have CNC hands/arms... or I'm not that patient, or something. Angle grinder? Oh no... far too... barbaric. I'm more patient than that. I do most of my roughing for large tube miters on the top roller of my belt sander. Some people use snips. I'd imagine some people would use their band saw, and I know a lot of guys use their chop saw, at least for heavier stuff! Whatever gets the job done.
    Files; 2nd cut... that's it. That's the tag I was looking for. Thanks to the File Luddite for dropping that piece of info.! Much more effective than the Bastard variety, at least on thin wall stuff. If it was .095 I'd be reaching for that hogger!
    I say again, whatever gets the job done. For the artisans among us, I'll add, and makes you a happy craftsman!
    DWF
    DWF is offline
    Non Dual Bliss
    Reputation: DWF's Avatar
    If you're going to miter with a file, then get a good set of tube blocks and rough them in with the bastard and then finish with the 2nd. You'll just wear 2nds out roughing miters in with them. The smart guys use a hack saw or tin snips to rough miters in.
    Using files doesn't make you a craftsman any more than buying/using antique machinery makes you a machinist. What makes you a craftsman are the superior results you achieve. **** work is **** work no matter what tool you use.
    A man must have enemies and places he is not welcome. In the end we are not only defined by our friends but those against us.
    650b me
    Thanks for the advice on the files, Don. Makes sense to start with the coarse file then move to the second cut. Good reminder about tin snips, too. We used left- and right-hand snips to rough in our main tube miters. At least the Luddites in the group.
    I agree with your second paragraph too. It's the results that matter. I just know that for me, I get more satisfaction from using hand tools.
    Reputation: jay_ntwr's Avatar
    Quote Originally Posted by golden boy View Post
    I have (and use) my 6/8/10/12/14 inch half rounds all the time. I have both bastard and 2nd cuts in each size. I like cut the tube with either a hack saw or cuttoff wheel to get it close, then comes the bastards and finish with the 2nd cuts. What you'll find with the 14" is that you'll clean up with a 12". I'll make sense when you start using it.
    I got all mine at MSCDirect and bought them during one of the 30% off sales--bastard first, then 2nd cut another time. I'd like to add fine ones in all sizes as well for really getting the miters tightened up. What I find is that just a light pass with a bastard is too much when really dialing in miters--probably good enough, but you can get closer with the 2nd cut. Even then, sometimes a light pass is too much with a 2nd cut and I'd like the fine files. Sure, you can build a frame that would be just fine with bastard only I'm sure--I've done it more than once--but I do like having the 2nd cuts now and wouldn't do it with just bastards again.
    650b me
    Thanks for sharing your experiences, Jay. I'll take a look at MSCDirect. I'm hoping to buy all US-made Nicholson files.
    I'm not sure where mine were made, but they are all Nicholson. They've been excellent files and really weren't all that expensive in the grand scheme of things. I'm sure one day I'll wear them out and want new ones and for what I paid for them and the amount of use I've gotten out of them, I'd buy the same ones again.
    DWF
    DWF is offline
    Non Dual Bliss
    AFAIK very few Nicholsons are made in the states and from what I've seen they're certainly not the quality they used to be.
    Files
    650b me
    Hmmm....when I did my main file research several months ago, I read lots of comments to only buy the US-made Nicholson files. Easier said than done! I found a couple at the local hardware store and snatched them up, but I need several more. I looked at your link to Grobet and that is the only other brand of files that folks thought were worth a damn. Thanks for the link.
    Search on VSalon. The Brazil made Nicholson files were not liked.
    Simonds files seem to be one of the more available files that guys like.
    Not to derail this thread too much.
    But does anyone use a rotary file/burr for roughing out miters? It looks like they would work well.
    "It has always been my way to de-value the fashionable, light-hearted, impulsive traits that people associate with Punk, because Punk is more than that, so much more that those elements become trivial in the light of human experience that all punkers share."
    Greg Gaffin
    Quote Originally Posted by boardrider247 View Post
    What I've found with rotary tools is that they tend to climb in the direction of the rotation and make the miter un-round. I've actually had better success with sanding discs (the little ones) for miters the tops of chainstays or on the dropout ends of of stays for hooded drops. Those work well, but you have to be very careful and even then, I usually finish them with a file.
    Nemophilist
    Not to derail this thread too much. But does anyone use a rotary file/burr for roughing out miters? It looks like they would work well.
    Yes;
    Just one of many tools that I use if it fits the situation. Like Jay said, there is a skill set to using them, but they work well for an initial hogging. I always finish with files as well.
    Ive asked before, but does anyone think it is worth it to use spindle sander type cartridge rolls for messing with miter joints, on say an air die grinder? also a buddy of mine showed me some round grinder stones for a 4.5" angle grinder that looked awesome. they thread onto the arbor. I do some miters in stuff like 1x.065 stainless tig welded and things of that nature where time is of the essence and fitup needs to go quick.
    I have a pretty wide assortment of files but many are older and kind of dull. I need some big ones that are fine, 0 or 2. can get a deal on pferd from a supplier of mine. are those any good? how does one judge the quality of a file? I don't mind paying for ones that will stay sharp in hard materials like 4130.
    Reputation: Meriwether's Avatar
    I know it's been covered already mostly but I found this really helpful list somewhere a few years ago, maybe on the old Frameforum archive?
    Files for mitering tubes:
    Different length files have different radii. Generally use a:
    - 14" half-round file to cut a miter for a 1-3/8" tube
    - 12" half-round file to cut for a 1-1/4" tube
    - 10" half-round file to cut for a 1-1/8" tube
    - 8" half-round file to cut a notch for a 1" tube
    - 12" round file cuts a 3/8" diameter
    - 10" round file cuts a 5/16" diameter
    - 8" round file cuts a notch for 1/4" diameter tube
    - 12" and 10" half-round for main tube and chainstay miters; -
    - 10" and 12" 'rat-tail' round for seat stay bridges, dropouts and tips;
    - 6" half-round for filing lugs,
    - some smooth 4" flats, rounds and triangles for detail work;
    - a bearing scraper for carving lug edges, deburring and miters.
    I like to use half-round Fine or Mill cut files for smoothing out the marks the hole saw teeth leave on the coped edges after milling and for general smoothing around the edges. But if you're doing it all with files then maybe that isn't a problem.
    BTW, Nicholson files are now made in Brazil. Says right on em.
    Nemophilist
    Quote Originally Posted by sonic reducer View Post
    Hey;
    A spindle sander is something that has intrigued me. I always eye the Oscillating Spindle Sander that Harbor Freight sells, but don't know how the oscillating part would work at all. For large tubes, I've used the top of my belt sander for the bulk of the cut, finishing with files. That works very well. There is someone on this forum that has a horizontal belt sander rigged up for mitering.
    No way a die grinder has the torque to run a sanding drum.
    Moderator Moderator
    Reputation: Walt's Avatar
    When I started, I built about 100 frames with just a hacksaw/file for mitering. This is not to say that I was somehow more awesome than anyone else, I just didn't have any space for machines/knowledge of other mitering techniques (teh interwebz didn't have nearly the framebuilding resources it does now!) As Don said, garbage in, garbage out, and I made some total garbage miters until I got decent at it.
    The technique is:
    -Figure out where your miter needs to be on the tube and mark it out with whatever (ie tubemiter program).
    -Cut out as much material as you easily can with a hacksaw. For me this was generally just a big triangle with the bottom point near the deepest part of the miter mouth.
    -Take a bastard cut file of the correct length/diameter and get close, finish with a smoother cut.
    I never had great luck trying to grind in miters with hand held power tools - maybe I'm just too clumsy, but I would always end up ruining them one way or another and the whole process would take longer than if I'd just stuck with files. In all honesty, I think I can do a miter just about as fast by hand as I can with the milling machine - but while the milling machine is cutting a miter I can be doing something else, so it's still a great time saver for me.
    -Walt
    Nemophilist
    Quote Originally Posted by Walt View Post
    The technique is:
    -Walt
    And...
    The key is certainly that you wrapped your mind around what a miter really was. Like anything else, the most basic method will ALWAYS teach you everything you NEED to know. Beyond that, it is purely more expensive, not necessarily "better."
    650b me
    Quote Originally Posted by Meriwether View Post
    Thanks for the guideline on file diameters, Meriwether. Regarding Nicholson files: yes, some are made in Brazil, and they say so right on them. And some are made in the USA, and they also say so right on them. If you look on the Nicholson website, you'll notice that they have two different part numbers for most files; one numbering system is for the Brazil-made files, and the other is the US-made tools.
    650b me
    -Walt
    Thanks for saying so, Walt. Now I am determined to build my next frame using only a hacksaw and files for the miters. I know all 100 of your first frames couldn't have been stinkers.
    650b me
    And...
    Amen, brother!
    Thanks for that info! I had no clue! Now I'm edumacated.
    The ones I've bought from MSC are all from Brazil, not sure how to tell what you're getting sometimes.
    Best of luck Golden Boy.
    650b me
    Thanks, Whit. You have to really look to find the US-made files, that's for sure.
    I'm getting closer to making frame #2 a reality! I ordered some small hand tools from Amazon this morning, and some small frame parts from Paragon. I'm just trying to be patient and enjoy the process of researching and acquiring tools and materials as my budget allows.
    650b me
    So much for my theory...
    ...regarding Nicholson file part numbers. I ordered 3 files from MSC, thinking they were American-made based on the part numbers. Nope. Got 'em yesterday, and they're all made in Brazil. I'm thinking maybe Nicholson no longer makes files in the US. This morning I was at the local hardware store where I bought my one and only US-made Nicholson file. I found the bin for that file. There was only one in there. I picked it up and what do you know: Made in Brazil.
    Oh well....I have them now, so I might as well use them. Of course they will "work."
    More importantly, as of this morning I have physically begun building frame #2! It's going to be a 650b hardtail for my wife. I don't have my brazing setup completed yet, nor a jig, so I have befriended a local framebuilder who has agreed to fillet braze it for me.
    single or double cut bastard?
    I've noticed that it's hard to find a 10" and 12" single cut bastard but the double cut is common. Is the double cut the one people are recommending?
    Che
    - Currently working on my 4th frame - 650b rigid w/ EBB.
    a great tool is an air die grinder with a conical stone. in some ways more controllable than a file, less in others, faster by far.
    650b me
    Quote Originally Posted by cgeiser View Post
    Both are recommended. Start with the double-cut to remove more material quickly, then switch to the single-cut when your miter is getting close.
    May 2014
    half-round files: diameters??? (still uncertain)
    Gah! I find it fascinating that this information does not seem to exist anywhere! I've spent a fair number of hours trying to locate a chart or something, with no luck. This thread is the closest I've found to an answer!
    I am looking to finally stock up on some files to ultimately build my first (steel) frame, using a Columbus SL tubeset. I'd like to start by buying only what I need, and so that means files with 1-1/8, 1-1/4, and 1-1/2 diameters. My best guess right now equates to a 10", 12" and I suppose 16"? (14" seems to equate to 1.375, which I don't need).
    Has anyone had any further luck getting this info? Thanks for the help!!
    Marco
    p.s., Sorry I'm late to the discussion here, (and I'm new to forums (Hello!) so am not sure if I'm following protocol, do I need to start a new thread?)
    Randomhead
    I don't think you "need" many files at all. I was always happy with an 8" half round and a 3/8" round. 1/2" round is pretty convenient too.
    having different sizes of files is convenient, but I usually rely on smaller files to get most of the work done. You need a bastage file that will make bridges and one that will cut main miter tubes. The rest is window dressing. It's not like you are going to be able to cut an exact miter with one of these files by just running it mindlessly back and forth.
    650b me
    mviero: I can't give you a definitive answer on the relationship between file lengths and diameters. My advice is to get as many as you can afford between 8" and 14" half-rounds, both double-cut and single-cut. They're not that expensive. Well, the best quality files are a bit expensive, but good luck finding them. Even when I thought I was buying top-quality US made files, I sometimes ended up with Brazilian-made files. They get the job done. Maybe they won't last as long, or cut as fast, but if you're a hobby building I don't think it's worth sweating over.
