Results 1 to 12 of 12
    Reputation: Clockwork Bikes's Avatar
    Front Der Direct Mount
    I'm not a big fan of the Paragon front der. direct mount because it's a fairly heavy chunk of steel and I don't like the square der. body against the round mount.
    I pieced together one last summer but it's way too much work to be practical.
    Would you be interested is a design like this? It weighs half as much and should be easy to open up the miter to 1.25" if needed.
    Thoughts, criticisms?
    -Joel
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    Looks like a good solution.
    You might offer one version mitered and one not, just to cover people doing odd non standard applications like curved or forward set seat tubes, etc. That is a double edged sword, of course. A non mitered version is easier to produce and is a more universally adaptable part, but doing two versions complicates production, and inventory.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Harrumph
    Reputation: G-reg's Avatar
    I'd be interested in a non mitered version. One of the biggest benefits to the DM is being able to plop it on wherever it needs to be. Pre-mitering puts you basically back to needing the seat tube in the range for a clamp on FD. All of my mounts have ended up slightly to way ahead of the seat tube, so I couldn't use your mitered version at all really.
    My wish list would be longer and wider horizontal tabs, trim to fit for various seat tube angles/sizes/derail location. Stainless would be nice too, as getting/keeping powder/paint would be a challenge.
    Slowly slipping to retrogrouchyness
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    It's a nice solution. I'd buy a few.
    The model needs some work though. Add a radius to the corners. A 1/4" radiuse would make it pop.
    Moderator Moderator
    Reputation: Walt's Avatar
    No miter/long tabs
    I mostly use the direct mount setups for very unusual configurations (ie curved/offset seat tubes, fatbikes or other bikes with odd chainlines, etc) so I *always* need to do the mitering myself, and I need a lot of extra tab. The Paragons works fine if I hack them up a bit but this basic idea looks good to me. I assume the backing nut would be brazed in prior to attaching the mount?
    Worth noting, too, that I've done very few of these since XX1 came out. I think the end of the front derailleur (at least for mountain bikes) is nigh.
    -Walt
    Quote Originally Posted by G-reg View Post
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Nice!
    Cool idea making it over sized to be trimmed to fit would be ideal!
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Good idea.
    My only reservation is mud filling the void. Is this a percieved problem or a non issue?
    I use a piece of 25.4mm top tube off a wreaked frame and a plate, drilled and threaded. It is easy to clean. The TT is .5mm wall, the plate is 5mm, so not much weight either.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Eric Malcolm View Post
    Good idea.
    Eric
    Functional a non-issue.
    It could fill with mud, but mud is lighter than steel. Would not cause any shifting or clearance problems.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by Walt View Post
    -Walt
    I would be inclined to used a normal hex nut, similar to FD band clamps. It may need to be filed to match the curve of the top of the mount, and that would keep it from spinning. Replaceable, too.
    mtbtires.com
    Reputation: whydomylegshurt?'s Avatar
    I bought a stick of 1" square thin wall tube from Mcmaster to build a nearly identical mount. It takes me about 20 minutes with a hacksaw, drill and tube notcher to have a mount built for any seat tube offset. I use a standard M6 nut on the back, but I use a bit a silver to hold it in place.
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    Quote Originally Posted by whydomylegshurt? View Post
    That was exactly what I was thinking (have not done it though).
    I'm having (25) mitered and (25) non-mitered versions made next week. Once I get them and confirm they work, I'll buy a proper ad. and offer them for sale.
    Thanks, Joel
