Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
  1. #26
    Reputation: adarn's Avatar
    Cool, I'd love to see pics if you can figure out the posting thing!
    -Adam Sklar
    My blog
    Instagram
  2. #27
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Adarn, better late than never.
    As shown, it is pretty much a mirror image of the original.
    Eric
    If I don't make an attempt, how will I know if it will work?
  3. #28
    Most Delicious
    Reputation: dr.welby's Avatar
    Quote Originally Posted by Eric Malcolm View Post
    Does that actually work? Seems like the attachment point can only move a few mm upwards. As my brain is processing it, you don't want a mirror image, you want to flip the input arm 180 degrees, which puts it just above and outside the lower pivot for the cage.
  4. #29
    Dec 2011
    Yes, I know what you are pointing out. You can do it that way (180 degrees) as long as the movement allows clearance with the crankarm. With this one, I intend to cable it from a low position on the seat tube. This modification does require a bit of thinking through in this respect. You need to to draw it out and measure, measure, and measure again. A problem teaser for sure.
    Eric
