    650b me
    Reputation: golden boy's Avatar
    Fillet brazers: alignment checks and cold setting
    Do you wait until you are done with the fillets before checking alignment and doing any cold-setting, if necessary? Or do you do an alignment check/cold-set both after tacking and after creating the fillets?
    It seems to me it would be beneficial to check alignment after tacking the frame. Isn't cold-setting easier to do post-tack vs post-fillet? Or is this a waste of time, because creating the fillets has a much greater effect on alignment than the tacking process?
    Reputation: adarn's Avatar
    Does anyone building with a jig actually cold set their frames?
    I checked the first couple frames out of my jig post tack and post braze and they were all spot on in both cases.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    I would suggest that until you have built a few frames and therefore a level of confidence in how your brazing pans out, that you check constantly, at all times through-out the build. Less mistakes that way.
    Sometimes its the simple pieces that will catch you out, eg: bridges, they can pull the drop-outs into centre because the heat used on the inside of the stays causes a slight shrinkage and therefore bends the stay inwards a little, even in a jig. I have found Uni-crown fork blades do the same, but I have no problem with socket type fork crowns.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Bike Freak
    Reputation: jgerhardt's Avatar
    I check after the ST/BB Then after the front triangle then after I have the rear triangle on and all of the bridges.
    Especially after I get the CS bridge the rear end tends to kind of jump around on me... (maybe I should spend a little more time on my bridge miter?)
    Oh and I do all of my cold setting BEFORE I drill the holes for the bottle brazes.
    My bikes [Fe][C]ycles
  1. Cold setting a frame
    By crux in forum Frame Building
    Last Post: 01-11-2013, 06:10 AM
  2. Alignment checks along the way (TIG)
    By febikes in forum Frame Building
    Last Post: 05-30-2012, 05:52 PM
  3. Fillet brazers - order of operations question
    By singlespeedmindset in forum Frame Building
    Last Post: 03-15-2012, 08:10 AM
  4. Fillet brazers: how long to finish file?
    By golden boy in forum Frame Building
    Last Post: 03-05-2012, 09:57 AM
  5. cold setting ti
    By 1niceride in forum Frame Building
    Last Post: 04-12-2011, 06:51 PM
