Results 1 to 15 of 15
    Reputation: Clockwork Bikes's Avatar
    Dropper Post Cable Routing
    I'm experimenting with my first frame with a dropper post with internal routing for myself. Does anybody have a clever idea for the cable inlet on the DT that won't be an easy path for water to travel along the housing into the frame?
    Thanks, Joel
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Di2 grommets?
    Most Delicious
    Reputation: dr.welby's Avatar
    Too small. You have to enlarge the hole just to fit 3x1mm dyno wiring.
    will rant for food
    I don't have any recommendations for off the shelf... but if you need some custom shaped rubber stuff, I know how to do that way better than building bikes so far. Lemme know if you (probably don't) need some heavy-handed solution.
    Reputation: Evil4bc's Avatar
    Depends on what dropper post you plan on running .
    Thomson has a cable actuated dropper so the frame opening can be pretty small for 4-5mm housing to fit through .
    Rock shok Reverb has a hydraulic fitting at the end so you need a 7.5mm opening in the frame just to fit the grommet through .
    I just re-inforce the hold with a 1mm thick cap then drill both he cap and seat tube at the same time to the desired OD needed for whatever dropper you plan on using .
    Follow me on Instagram for up to date build pics -Brad4130
    Nem-Pro store
    Nem-Pro Blog
    Gonna give these a try.
    Nov 2014
    Those look to be nice and tidy Clockwork. I may have to find those. My plan was to use some of the stock grommets from Transition, but they are a bit larger.
    https://www.transitionbikes.com/2016...&P=4234&o=3899
    Cinelli thing seems to work but time will tell.
    More pics of the whole bike here: https://www.flickr.com/photos/clockw...57668963108890
    Reputation: bigcrs's Avatar
    Semi thread-jack alert...
    Now that my Nimble 9 is out for warranty I'd like to make it compatable for my 9point8 dropper, just a couple of questions before I do so.
    - Once the hole is made, how should it be treated now that corrosion protection is compromised?
    - Any ideas (other than what's already been mentioned) where I can pick up some rubber grommets?
    - I dont imagine that this hole will create any potential structural problems - any reason I should think otherwise? ( I won't be drilling at a junction, in a tube bend or the like. Just a few inches up from where the st and dt meet)
    Reputation: Feldybikes's Avatar
    Assuming a Nimble 9 has water bottle bosses, I'm not sure what corrosion protection you're talking about. It's not like the frame was completely sealed from the get-go. It probably has vent holes on the stays. This generally just isn't a big deal unless maybe if you live right by the ocean.
    I'm not sure where to source grommets. As mentioned above, depending on what you're drilling for, you can might the hole pretty tight making a grommet somewhat redundant. I've thought about adding silicone sealant around it, but have never bothered in practice.
    I'm not going to touch the structural issue.
    Quote Originally Posted by Feldybikes View Post
    The frame has protective finishes on both the inner and outer surfaces. Once a hole is drilled it'll expose unprotected steel that's between to finished ones.
    Your not going to touch "structural issues", what does that mean? You either know or you don't know. If you think the hole will create a safety issue you should put up. Don't sit on your hands.
    Nov 2007
    First, the only protective finish on the inside would be something like Boesheild or Framesaver sprayed in thru vent holes. You could easily spray the new hole for the same effect.
    Second, no one here wants to speak for a manufacturer regarding drilling a hole into a frame. My opinion: it is not a safety issue, but a crack will begin at the hole someday without some sort of reinforcement around it.
    Reputation: dseybert's Avatar
    Quote Originally Posted by Clockwork Bikes View Post
    Could you tell me where you got these?
  1. dropper post cable routing question
    By crewjones in forum Tooltime
    Last Post: 05-18-2015, 04:54 PM
  2. Dropper Post Stealth Cable Routing -- Yay or Nay?
    By justaute in forum Beginner's Corner
    Last Post: 03-04-2015, 03:23 PM
  3. Dropper Post Cable Routing on Mojo-C
    By cchough in forum Ibis
    Last Post: 05-28-2013, 10:33 PM
  4. Dropper Post Cable Routing
    By steve86 in forum Ibis
    Last Post: 06-01-2012, 06:14 PM
  5. Replies: 7
    Last Post: 02-03-2012, 09:33 AM
Members who have read this thread: 15
