    Feb 2005
    Do I need to remove water bottle bosses for anodising
    Hello,
    I'm planning on re anodizing my 2002 Titus Switchblade frame.
    Do I need to remove the water bottle bosses?
    If so, how do I do it?
    thanks
    Kand
    Do I need to remove water bottle bosses for anodising-switchbladebottlemount.jpg
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    I am not familiar with your frame, but the principle follows that you anodize similar metals. Alloy tube, alloy fittings - no problems. Alloy tube, steel fittings, you have an issue.
    Talk to your anodize applicator and see what he thinks.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Feb 2005
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    Thanks Eric.
    I asked the anodized and you are right. The water bottle bosses need to come off.
    cheers
    kand
    Reputation: Feldybikes's Avatar
    They can be drilled out and new ones rivted un when your done. Might need a right angle drill head to reach inside your frame. And if you've not done this sort of thing before, you could screw up the frame. But the point is it can be done.
  1. Adding bottle cage bosses to a frame.
    By LyNx in forum Frame Building
    Last Post: 04-03-2016, 04:40 AM
  2. HD with water bottle?
    By agleck7 in forum Ibis
    Last Post: 06-19-2013, 02:16 PM
  3. Bottle cage bosses
    By adarn in forum Frame Building
    Last Post: 07-25-2012, 12:51 PM
  4. Bottle Bosses on small frame
    By tfinator in forum 29er Bikes
    Last Post: 02-24-2012, 04:48 PM
  5. Adding water bottle bosses to steel fork?
    By Johnny K in forum Frame Building
    Last Post: 02-09-2011, 04:19 AM
