Results 1 to 17 of 17
    Mar 2013
    Disc tabs obsolete yet?
    What do you builders think, are post mounts the future? Tab mounts going to stick around for awhile?
    Brian
    Moderator Moderator
    Reputation: Walt's Avatar
    I am working from the assumption that PM is the future. I'm actually not a huge fan of it for steel forks (it ends up being a bit awkward in a lot of cases) but that ship has sailed. It's certainly lighter, assuming you have to use a PM caliper + adapter if doing ISO.
    -Walt
    Randomhead
    as far as I know, all shipping brake sets are post mount and they come with an adapter. I'm guessing it will not be long before you have to source an ISO adapter separately. Wish we could get some of those post mount tabs that are used on QBP bikes.
    Moderator Moderator
    Does someone want to draw something up? I will be happy to cover the costs of have a few hundred or a thousand made.
    -Walt
    Mar 2013
    Quote Originally Posted by Walt View Post
    -Walt
    Nice offer Walt. All builders will need these in the future, its inevitable that someone will design/build/sell post mounts, might as well be Walt for starters.
    Brian
    Feb 2013
    Paragon do some very neat post-mount tabs with replaceable threaded inserts. I quite like being able to go freehand, though, with steel tube and threaded bosses.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by BenCooper View Post
    I have done that, and used canti bosses as post mounts, too.
    mtbtires.com
    Mar 2013
    Quote Originally Posted by shiggy View Post
    Got pics?
    thanks, Brian
    Dec 1998
    Quote Originally Posted by calstar View Post
    Got pics?
    thanks, Brian
    Both are direct mount for 185mm rotors.
    Fork, 20mm TA, canti bosses
    Rear, 6x1 bottle cage type bosses in .375 tubing, perfect slip fit (can not remember the wall thickness)
    mtbtires.com
    Reputation: davesauvageau's Avatar
    I like the look of those disc mounts, reminds me of a Ducati frame. What is the deal with the clear plastic looking jobber on behind the brake in the bottom left picture? I can see it in the bottom right picture as well. Curious….
    My motorcycle runs on infant blood
    Reputation: MiWi's Avatar
    Jan 2013
    I always go for PM front and rear and use canti bosses, too.
    (turned down on my lathe and integrated in some plates)
    I flip those bosse over, to have the bigger diameter (apr. 10mm) and a bigger seating for the brake-caliper. Itīs not that good to see in the picture.
    Michael
    Dec 1998
    Quote Originally Posted by davesauvageau View Post
    Short stays and my shoe rubs the pad adjust knob, turning it. The plastic bottle top protects it.
    mtbtires.com
    Interesting!
    Belltown Brazer
    Reputation: MDEnvEngr's Avatar
    Showed these pics earlier. Drilled and tapped soft balls:
    Departing from East Hampton, CT
    Mar 2013
    Quote Originally Posted by MDEnvEngr View Post
ID:	826264Click image for larger version.
    Very nice!
    Cleavage Of The Tetons
ID:	825121Click image for larger version.
ID:	825123Click image for larger version.
    That is nice work.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Reputation: mbeardsl's Avatar
    That's look great IMO
  1. Welding disc tabs onto non-disc frame?
    By evdog in forum Frame Building
    Last Post: 06-24-2012, 09:27 PM
  2. Replies: 6
    Last Post: 09-12-2011, 07:24 AM
  3. Disc Tabs On Swingarms
    By phill77 in forum Santa Cruz
    Last Post: 05-26-2011, 01:22 PM
  4. Welding on disc tabs?
    By mrniceguy42 in forum General Discussion
    Last Post: 03-30-2011, 06:43 AM
  5. Sliding disc tabs?
    By marks_bike in forum Frame Building
    Last Post: 03-08-2011, 12:05 PM
