Results 1 to 2 of 2
    Direct mount front mechs - how much clearance can you gain?
    Hey guys,
    I've not being paying as much attention to the forum recently so I appologise if this has been covered.
    I've got a project coming up where tyre clearance at the front mech (cable mechanism not cage) will be a bit tight. We are basing some of the geometry off a production bike that uses a normal band on mech and there is about 3-5mm from the tyre to the mech. I'm wondering if a direct mount will actually give more clearance? If it does, how much can I expect?
    I'd rather not be recomending cutting the mech up but I realise this is an option
    Matt
    Harrumph
    Reputation: G-reg's Avatar
    What Walt said in one of my build threads. "Hopefully this will make sense"
    Essentially you can move it forward and "clock" the FD around the BB a fair bit. Use the top pull versions to get rid of the dual pull thingy. You are limited really by the aft/bottom portion of the cage interfering with the chain in small chainring/cog combinations.
    I'm going to do a little R&D for my next build and see how things go. I've become a fan of how sell the 2/10 direct mount derailleurs shift. I'll be willing to fudge Shimano's specs, but not past the point where that awesome shifting is harmed.
    <hr style="color:#ffffff; background-color:#ffffff" size="1">
    Slowly slipping to retrogrouchyness
