Results 1 to 2 of 2
    Squelch the weasel.
    Reputation: JaquesN's Avatar
    Differences in continental oval fork blades
    Hi all,
    I'm designing a fork crown to be CNCd from plate, and wanted to use standard continental oval fork blades.
    I have two sets of blades in my possession. The True Temper blades are round like a track, with flat sides. The ones from Nova are more like a stretched circle, slightly longer and thinner and with a more continuous curve.
    Not having used many pre-made fork crowns, I have no idea what to do here. Which one is more typical?
    Of course the builder has to massage the fork crown a bit to get a good fit, but I'd like to get it in the ballpark.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Jim, I have only known about the Nova (European Style) Blade which are manufactured by Reynolds and Columbus as well as Tange.
    If you intend to make a 1-off double plated crown fork, this is a good time to use up the TT blades, but if you are setting up for future repeat use, I would go the Euro style as it is the more commonly available to the hobby builder. Most road bike crowns are Euro from all the specs that I have seen.
    Either would make a good fork though.
    If I don't make an attempt, how will I know if it will work?
  1. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  2. KIT-FB-4 fork blades - suitable for discs?
    By cataņo in forum Frame Building
    Last Post: 02-08-2012, 08:52 AM
  3. 31.7 fork legs/blades
    By pyranha in forum Frame Building
    Last Post: 04-06-2011, 04:50 PM
  4. Replacing carbon blades on an On One fork?
    By bikeny in forum Frame Building
    Last Post: 02-26-2011, 11:03 AM
  5. carbon fork blades?
    By ikswonalam in forum Frame Building
    Last Post: 01-17-2011, 08:34 PM
