Results 1 to 3 of 3
    Reputation: D.F.L.'s Avatar
    Dedacciiai tube specs/butt lengths?
    Does anybody have access to the complete specs for Dedacciai steel tubes? I need some butt lengths and taper locations on a few tubes.
    I don't think it's easy for Joe to update his site and I wondered if anybody had the specs.
    If anybody had dealt with their 01 35>32 tapered DT: is there a constant-diameter section on either end?
    Butt lengths on their 8/5/8 29er DT?
    Is the tapered HT, drop-in/ZS bearing?
    Thanks.
    Moderator Moderator
    Reputation: Walt's Avatar
    Call Joe?
    It has always frustrated me that Deda doesn't have useful info easily available. Seems to be a theme with bike tube companies, though.
    I can't answer any of those questions, really, except to say that I had a conversation with Joe about the tapered head tubes and:
    -You have to *glue in* aluminum inserts or something like that.
    -They are some odd Campy headset standard, I think?
    This was a couple of years ago so I might be misremembering (or they could have changed them), though. Joe has all the info in his brain, you just have to listen really carefully to understand it.
    -Walt
    J_K
    J_K is offline
    Some of the Dedacciai specs can be found from here.
