Results 1 to 11 of 11
    650b me
    Reputation: golden boy's Avatar
    Cutting head tube stock to length - and square
    How do you do this without a lathe? At UBI our instructor cut ours for us using a lathe. Obviously, the tube needs to be nice and square before putting it in the frame jig. What are my options, without a lathe?
    A couple ideas I've had:
    1. Pipe cutter
    2. Park saw guide
    Neither would guarantee a square cut, so then I'd have to follow up with a head tube facer, orienting the centering cone on the non-cut end of the tube. Can you use just the facing cutter without the reamer cutter, or is that a bad idea? Am I on the right track? I'm open to ideas.
    RCP Fabrication
    The park cutter comes with bushings to use it with out the reamer. It works to do what you want to do.
    The four black pucks:
    Most Delicious
    Reputation: dr.welby's Avatar
    If you want to kick it old-school, machinist's square and flat file.
    Randomhead
    a tube cutter will get it within the tolerances you need. I would probably just mark with a tube cutter and cut/file some other way
    Nemophilist
    Reputation: TrailMaker's Avatar
    Quote Originally Posted by dr.welby View Post
    Hey;
    Semi-rustic here, with a square and a belt sander. Either of these is likely a fine enough point for the task. You have to watch pipe cutters. I've seen them work more like thread cutters if they are cheap or worn. If I happen to be set up for it, I'll end cut them on the mill, but most people don't have one of those either...
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    650b me
    Thanks for the input, guys. I'm currently equipped to use Dr. Welby's method, so that's a strong possibility.
    For grins, I checked the ends of my stock - HOXPLATHT2 - and neither end is anywhere near square. Off by a mm at least. I had wrongfully assumed that both ends would be square. Newb lesson...
    Reputation: Meriwether's Avatar
    If you have a mill you can load the HT in the vise and level it, then run a light pass with an end mill to square it up better. Not as good a finish as a lathe but works pretty well assuming you've squared up/trammed your vise.
    I used the machinist square and file before that but then the accuracy depended on my patience...Cutting head tube stock to length - and square-imageuploadedbytapatalk1365833515.275252.jpg
    Feb 2013
    I just use a tube cutter. A good quality one, and on the first pass make sure it hasn't wandered, then it's fine.
    Depending on your jig, but with mine it'd have to be very, very squint to make much difference at all on the jig setup.
    650b me
    Thanks for all the replies. I guess my real question was: how critical is it that your head tube is square before putting it in the frame jig. Sounds like using a file and machinist square is "good enough."
    650b me
    Doh! Found this informative thread on the subject. Hadn't even suspected someone had posted about this before:
    cutting a head tube by hand?
    Mar 2013
    Old school band hose clamp method to guide hacksaw(or two close together), file remainder to edge of band, check and final dress with machinist square and file, gets you there pretty quickly.
    Brian
  1. cutting a head tube by hand?
    By febikes in forum Frame Building
    Last Post: 12-19-2017, 07:54 AM
  2. head tube length and steer tube length
    By freeriderB in forum All Mountain
    Last Post: 02-23-2013, 05:09 AM
  3. Judge head tube length
    By bigmike9699 in forum Cannondale
    Last Post: 03-14-2012, 12:36 PM
  4. 2011 Fantom 29 Pro Head Tube Length
    By All_talk in forum Motobecane
    Last Post: 02-01-2011, 10:23 AM
  5. Steerer tube length to head tube length Help please
    By Mailman953 in forum 29er Bikes
    Last Post: 01-05-2011, 11:52 AM
