Results 1 to 6 of 6
    Squelch the weasel.
    Reputation: JaquesN's Avatar
    Crown race seat of brass
    Would it work to cut a crown race seat into a brass fillet, rather than brazing on an additional steel seat above the fillet, on a unicrown fork? Would the brass be too soft, and eventually deform?
    Thanks,
    Jim
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Jim
    Many years ago, when Campagnolo was introducing headsets, the bottom race was a larger diameter than the forks of the day around this end of the world, and they had to be beefed up with brass and re-cut so they whole headset would work. We did not have Loctite back then. They all held up, and I have wondered doing the same on contempary forks. IMO, you will be fine, keeping a nice lower line (the bit that is visible but not structural) will be a mild challenge for anyones skill-set. Go for it.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Feb 2013
    I've built up worn crown races with brass, never had a problem - getting it neat would be the challenge, the advantage of the steel race seat is you have something to build the fillet up against.
    Squelch the weasel.
    Thanks for your replies.
    I guess I would cut the seat on a lathe.
    Jim
    RCP Fabrication
    Randomhead
    that Ritchey fork had a steel sleeve, it may well have a steel flat as well. I definitely would use something like a paragon. In a pinch, I might machine down a piece of 4130 tubing that is a slip fit over the steerer
  1. Lost crown race
    By xdeity in forum General Discussion
    Last Post: 03-28-2013, 09:42 AM
  2. Crown race question
    By KEITH21 in forum Shocks and Suspension
    Last Post: 01-11-2013, 07:46 PM
  3. Uni-Crown fork legs as seat stays
    By todwil in forum Frame Building
    Last Post: 12-17-2011, 01:30 PM
  4. box crown fork with brass - anyone done one?
    By JaquesN in forum Frame Building
    Last Post: 09-21-2011, 09:25 AM
  5. Replies: 6
    Last Post: 08-10-2010, 06:43 AM
