Results 1 to 5 of 5
    Chewed up Alum drive side dropout.
    As the title says...the drive side dropout is chewed up.
    Nothing major....the axle threads have dug in enough over the last few seasons so that the wheel is a little off.
    I tried the JB Weld route....it didn't last long.
    Suggestions?
    Randomhead
    jb weld in a piece of stainless shim stock? Or is that what you did? You could always file out the other side a little, but make sure it would resist the pull of the chain
    I don't want to file the non drive....I think I will just make things worse.
    I did put aluminum shim stock in....like I said, it didn't last long.
    Anyone have luck building up the area with weld?
    Randomhead
    welding on aluminum isn't the best idea in this application
    Jun 2005
    Is there enough room to mill out a small pocket and put a small piece of steel or sacrificial aluminum?
  1. Replacing drive sold screw pivot on drive side?
    By Jaybo in forum Niner Bikes
    Last Post: 07-29-2012, 09:05 PM
  2. Belt drive rear dropout/splitter options?
    By einreb in forum Frame Building
    Last Post: 07-12-2012, 11:13 PM
  3. Drive side vs Disc side tension
    By edispilf in forum Wheels and Tires
    Last Post: 08-19-2011, 08:03 AM
  4. Axle sliding in dropout on brake side
    By False in forum Singlespeed
    Last Post: 07-15-2011, 10:27 AM
  5. GXP Non-drive side Creaking
    By ChainChain in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2011, 07:43 PM
