    Can you bore a threaded BB to PF30?
    I have a carbon frame with derailleur hanger that I would like to turn into a singlespeed without the use of a tensioner. Is it possible to bore out the threaded BB to a PF 30 so I can use an EBB?
    Reputation: wabiker3576's Avatar
    Jan 2005
    I doubt it, I wouldn't .. just use one of these Philcentric Outboard Bottom Bracket Cups
    Phil Wood & Co.
    2013 Ellsworth Carbon Evolve XT
    2013 Ellsworth Enlightment XTR
    2013 Ellsworth Enlightment SS
    Bike Shop Employee
    http://problemsolversbike.com/files/..._Reference.pdf
    BB30 is 42mm ID. PF30 is 46mm ID. You have to ask yourself if you can machine 4mm out of the ID and still have a strong enough shell (or any left at all most likely.)
    OSCMTB
    Reputation: Berkley's Avatar
    Quote Originally Posted by smdubovsky View Post
    I believe the OP has a standard threaded BB shell, in which case it definitely will not work.
Hot Deals
Contests
Latest Mountain Bike Articles
