    650b me
    Reputation: golden boy's Avatar
    BB shell selection
    Let's ignore pressfit shells for this discussion. When would a builder choose a 68mm shell vs a 73mm shell? Is the 68mm shell a more flexible choice, since you can add spacers? Is it all about achieving optimal chainline?
    And a lesser question regarding PMW shells: Anyone using the 1.562" OD shells? Seems overbuilt to me, much like the 44mm head tube. Thus far I've only used the 1.5" OD shells.
    Mar 2011
    Generally the 68mm is for road and 73mm is for mountain. The thicker bottom brackets will distort less with heat.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Building a MTB?, though I use the 68mm myself, I do so due to needing to fit both road and MTB cranksets to do what I want to do. The 2.5mm spacers added to each side of the BB shell has not caused me any grief. But it does make sense if you're purposely building for the 1 discipline of MTB to use the 73mm. Simply put, the cups are fully thread supported by a 73mm. The cups are cantilevered in a 68mm, so theoretically weaker. In practice, this may or may not bother you.
    Eric
    If I don't make an attempt, how will I know if it will work?
    650b me
    Thanks, Eric. I'm with you. In my case, I'm building a dedicated MTB, so there's no reason not to use the 73mm shell. I guess what got me thinking about this was an article in a recent issue of Mountain Flyer. Kent Eriksen built a custom ti hardtail and used a 68mm shell. I just looked at the article again. The customer intended to run it as a singlespeed, so perhaps that explains the use of the narrower shell.
  1. BB not flush with shell
    By Jimbob4life in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2013, 08:56 AM
  2. Hard shell or soft shell knee pads
    By Qubo_2408 in forum Apparel and Protection
    Last Post: 07-18-2012, 08:43 PM
  3. Shell Beach to SLO
    By Steel Freak in forum California - Socal
    Last Post: 03-24-2012, 10:44 AM
  4. 08 RIP BB shell width
    By bank5 in forum Niner Bikes
    Last Post: 09-16-2011, 09:50 AM
  5. Dt Swiss 240 Hub Shell
    By dozerdog in forum Wheels and Tires
    Last Post: 08-13-2011, 11:06 AM
