    Dirt Huffer
    Reputation: AC/BC's Avatar
    130mm chainstay clearance enough for Bud + 100mm rim?
    I'm doing a 190mm frame and have 130.5mm clearanced near the BB. I have 445mm chainstays. Wondering if this will be enough with the yoke on the crankside. I'm using 780mm as an overall tire diameter.
    Moderator Moderator
    Reputation: Walt's Avatar
    Surly tire specs here: How Fat can we go? | Blog | Surly Bikes
    -Walt
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    The Surly stuff is likely "accurate," but that said, there is also nothing like having the bits in hand to avoid heartache.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Reputation: Meriwether's Avatar
    Quote Originally Posted by AC/BC View Post
    I posted up some Lou measurements here:
    Husker Du Tire Profile - For The Archives
    I think you'll be just fine with that amount of tire clearance. The Surly specs are close on my NEW tire, i don't know if they'll stretch out a bit though over time. Whether you have chainring/crankarm clearance is another story and hard to answer from the info you gave.
    Good luck!
  1. Chainstay clearance - Your thoughts, please.
    By dmaindonnie in forum General Discussion
    Last Post: 02-05-2012, 06:16 PM
  2. 130mm fork on a carbon frame designed for 100mm
    By Will Goes Boing in forum General Discussion
    Last Post: 11-13-2011, 09:06 PM
  3. Fox 36 Talas 160mm vs 130mm vs 100mm
    By ForestHorse in forum Santa Cruz
    Last Post: 09-24-2011, 08:27 AM
  4. DT swiss xmc 100mm>130mm
    By biketavioumaximus in forum Shocks and Suspension
    Last Post: 05-11-2011, 01:24 PM
