Results 1 to 10 of 10
    Oct 2011
    New question here. 100mm EBB Possible?
    is it possible making a frame with EBB 100mm bottom bracket using niner Bio2? little mod for the niner EBB to lock in,
    thoughts?
    thanks
    will rant for food
    You're referring to this? Niner BioCentric II
    I asked them about it a while ago - they said no. Probably covering their ass.
    A good machinist could emulate the design, I think, but it'd run in the neighborhood of $500 if I had to guess. Sounds like a non-trivial reverse engineering project.
    Oct 2011
    thinking of having an EBB on 100mm crankset with 190mm rear spacing.
    will rant for food
    If you're running 190 rear spacing, that means you have zero options for internal gear hubs.
    Are you planning on running single speed?
    The progressively wider rear hubs on fat bikes are to afford granny gear clearance on a triple or double crankset.
    I'm trying to figure if you're wanting to buy / fabricate something expensive you don't really need.
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    I would think you could make peg extensions and longer bolts or maybe just bolts
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    Oct 2011
    planning geared and SS compatible hmmm just want to have more clearance 26x4 and 29x3 tires.
    nothing to see here
    Reputation: Stevob's Avatar
    Salamandre Cycles in France makes what looks like a 100mm EBB
    I see hills.
    I want to climb them.
    Most Delicious
    Reputation: dr.welby's Avatar
    Singular has one planned:
    Fat news | Singular Cycles
    Not just planned - they are reality on the prototypes I have.
    Been faultless so far, they are quite light but the shells are heavy. They will be getting some machining for production.
    Yes - I do own Singular Cycles
    Harrumph
    Reputation: G-reg's Avatar
    I'm trying out a Problem Solvers E46 EBB for PF30 shells on a project, BEER components makes similar EBBs for BB30 and PF30 shells. If you had the means to create a properly faced/reamed 100mm shell you'd be longer bolts away from a usable ebb.
    Slowly slipping to retrogrouchyness
  1. 100mm ok on YS?
    By Jonesy22 in forum Canfield
    Last Post: 07-10-2012, 10:08 AM
  2. Reba RLT 100mm Or SID RCT3 100mm
    By kevinboyer in forum 29er Components
    Last Post: 03-18-2012, 01:53 PM
  3. 80 mm or 100mm or more
    By rmbassett21 in forum 29er Bikes
    Last Post: 12-19-2011, 01:00 AM
  4. Fox RLC 100mm OE - $449
    By LyNx in forum Where are the Best Deals?
    Last Post: 08-24-2011, 06:39 PM
  5. jet 9 80 or 100mm
    By esach in forum Niner Bikes
    Last Post: 03-20-2011, 06:36 PM
