Results 1 to 10 of 10
    Reputation: Clockwork Bikes's Avatar
    100% Clockwork Full Suspension
    Finally got this thing done but haven't ridden it much. It's 160 x 160mm travel and I'm really happy with how the suspension elements function individually but only more riding will tell if they work well as a whole.
    https://www.flickr.com/photos/clockw...57691970402140
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Oct 2013
    Sick! I really like the cable routing details too!
    Plays with tools
    Reputation: customfab's Avatar
    It's funny how advancements in shock tuning and single ring cranks have made suspension designs we use to shy away from viable choices again.
    Reputation: octanejake's Avatar
    Oct 2010
    Fantastic looking frame, well done.
    Are the two sides of the rear end joined together? or is it just the bolts and axle?
    Oct 2011
    Very slick looking! Only concern I have is how is the rear end for stiffness?
    Quote Originally Posted by WaywardTraveller View Post
    I can't detect any more flex than I would in a hardtail. The frame axle is 1.25" and then steps down to 30.15mm for the 4 bearings (the outermost bearings are 40mm from the center plane). The shock bolt is M8. It was a challenge to make a robust pivot and keep a 53mm chainline.
    Finally got the bike out to proper DH trails at Spirit Mountain in Duluth, MN.
    It was a blast and I was really able to ride beyond my skill level with all that travel! Only one good crash and a few washouts.
    No mechanical problems and pivots stays nice and snug with no play.
    Oct 2013
    Congrats on designing, building and riding such a sweet bike!
    Reputation: Feldybikes's Avatar
    Noice!! Seatstay and chainstay curves look really clean and the pivot hardware looks factory.
    Nerdy builder questions:
    I can’t tell exactly how you dropped the right chainstay. Is it just bent and you’re using a compound angle? Those make my brain hurt, but the result looks stellar.
    Also, looks like no bend to the seat tube but non-ginormous chainstays? Tire clearance at full travel is always a challenge for me with 29ers. Edit: never mind, looks like it’s “bent” over the pivot.
    Did you get the housing “stop” for the dropper from Ceeway? How do you like it?
    Quote Originally Posted by Feldybikes View Post
    Thanks. The right CS was tough--I used about 8' of tube. The first bend is R2.5 and the second in R6. The miter is compound, but barely so it wasn't too tricky. There's also 2 ovalizations in there.
    The ST isn't bent, but does change 20* after the pivot.
    The dropper routing just goes through a reinforced hole that accepts a grommet from Salsa.
  1. Replies: 28
    Last Post: 08-29-2016, 04:39 AM
  2. Replies: 12
    Last Post: 11-05-2014, 02:26 AM
  3. Replies: 8
    Last Post: 07-14-2011, 07:11 PM
  4. High Cascade 100, Butte 100 or Pierre's Hole 100?
    By wasatchbiker in forum Endurance XC Racing
    Last Post: 02-14-2011, 02:35 PM
Members who have read this thread: 109
