fxr 2:1 and fox 36
Considering getting a fox talas 36 to a 2007 fxr. Heard that the corwn of a fox 36 will hit the downtube of the fxr. Is that tru ? Anyone riding a fxr 2:1 with a fox 36 ?
I think that is only on small and maybe med. frames.
According to Chris at FOES (I emailed him re a shock enquiry) the FXR was designed around the Fox 36! So really it should be fine..
Slightly
On my med 07 fxr with a 160mm fox talas 36 the only thing that hit is the talas lever and it grazed the paint off the gusset weld.
consider a Cane Creek S8 with a +5mm stack. Hardly affects the geo but you will defo avoid any contact between fork and down tube. Did exacly that for my RS Lyrik setup.
S8 is a fairy descent HS
We just built my buddy's bro 08fxr with 36 floats and it clears.
My med 06 front triangle 2:1 fxr gets grazed by my TALAS 36 I went with the 5mm king lower crown
- You may not post replies
- You may not edit your posts
Forum Rules
