Results 1 to 9 of 9
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Fluid on my knee
    Yesterday, while taking a break, I noticed my right knee looked a little swollen, and upon closer examination I discovered this pocket (maybe 1/2 cup) of fluid around my knee. Sort of like a small limp water balloon when I stand up. I'm wondering if anyone else has experienced this phenomenon and what to do about it.
    I was just riding along, felt nothing unusual at the time. There does seem to be some inflamation in the joint now, which I have been treating with Etodolac, an NSAID. I guess I need to get the fluid drawn off, for starters.
    I ride with the best dogs.
    Reputation: brainbckt's Avatar
    Could be inflammation, could be something more serious like a torn meniscus. If causing discomfort, a drain/cortisone shot may help short-term. See an orthopedist.
    saddlemeat
    Aug 2003
    I believe it's a case of what used to be called "housemaids knees", or bursitis. There is no inflammation, no pain, and the fluid volume is decreasing slowly. I have talked to several people who went through it, and who recommended not getting the fluid drawn unless it is hindering knee movement, which it is not. Seems like a very mild case, compared to what some others have experienced. I have been taking it a bit easy on it though, not biking or hiking, or carrying heavy loads.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    I had a pretty bad case of bursitis a few years ago. Caused by taking a knee, while wearing a very heavy backpack, for long periods of time.
    Sent from my XT1585 using Tapatalk
    Death from Below.
    saddlemeat
    Aug 2003
    Le Duke- Did you have any lasting effects from it?
    Formerly of Kent
    Not on that knee, no.
    Death from Below.
    dru
    dru is offline
    Had bursitis several times in my post surgery knee and one elbow. If you whack your joint you'll likely get it if you aren't sensible and keep on riding like I did! Anyways, rest and ice and ibuprofen really help. I whacked the same knee again about two months later and it took months to get better.
    Drew
    occasional cyclist
    Reputation: mudge's Avatar
    May 2010
    Quote Originally Posted by Le Duke View Post
    "Pain is just weakness leaving your body. Unless you were in the Infantry, then it's probably arthritis."
    May 2010
    I'm more concerned if I DON'T have a little fluid on my knees
  1. Fluid trainer fluid replacement?
    By trailbrain in forum XC Racing and Training
    Last Post: 02-06-2018, 03:20 PM
  2. Replies: 23
    Last Post: 02-25-2016, 10:48 AM
  3. Cyclops fluid trainer fluid replacement
    By trailbrain in forum Tooltime
    Last Post: 02-11-2014, 10:30 AM
  4. Replies: 2
    Last Post: 11-21-2012, 09:32 AM
  5. Knee injury sufferers - fluid on your knee after impact
    By Horacek in forum General Discussion
    Last Post: 01-26-2011, 01:24 AM
