Results 1 to 7 of 7
    😁Have a great day!😁
    Reputation: Yalerider's Avatar
    Feb 2017
    Bigger chainring?
    So all you wise fellow old timers/farts/dudes or whatever. Here in Southwest Washington it rains occasionally. I have been riding dirt and paved paths and thinking I would like a little higher gear on my Diamondback Sync'r until summer comes(if it does). I have a SRAM NX 1x, w/ X-Sync 30T Chain Ring and SRAM PG1130, 11 Speed, 11-42T cogset. Wondering if I should try a 32t? Would I buy a new chain also or just a couple of links and a power link?
    https://www.ebay.com/itm/222403554774
    Just Joshin' ya!
    Reputation: PrincipalRider's Avatar
    Jun 2005
    Pushing 40, so take it with a grain of salt. I ride a 32 oval chainring with a 11-40 cassette on my Raleigh Skarn. I find it works just fine for climbing whatever here in Phoenix AZ. I also feel my top end is high enough to spin the 3 miles to our local trailheads on relatively flat canal paths. If you do 32, you may not go back. If you have a couple of chain links and pins, then you should be able to make the old chain work. I have done that before and it was fine. However, I just tend to buy new chains since they can be found pretty cheap.
    Getting a dropper post is like getting a bidet. I didn't know I needed one until I get one and boy, does my ass thank me.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Going from 30 to 32 is only 1/2" longer for the chain so it's unlikely you would need to change it. The chain only wraps 1/2 way around the ring so it will see only one more tooth.
    Do the math.
    Reputation: MSU Alum's Avatar
    Why not? I agree with Lone Ranger.
    😁Have a great day!😁
    Feb 2017
    Thanks for the replies, for $15 bucks not much to lose.
    😁Have a great day!😁
    Feb 2017
    Got my 32 T chainring and put it on. Tried on driveway and seems OK. Will have to hit usual trail and see how it does.
    😁Have a great day!😁
    Feb 2017
    Working fine, get a little more speed on the top end. Also my tires were way low so pumped them up to 30# and made a big difference. This 1x9 is kind of finicky to get adjusted right, set low and high but middle still jumping two rings on up shift.
  1. 2016 Fatboy Chainring - options to go bigger
    By MegaMustang in forum Fat bikes
    Last Post: 05-14-2017, 12:06 PM
  2. Fatboy bigger chainring
    By Bentpushrod in forum Fat bikes
    Last Post: 02-21-2016, 01:32 PM
  3. Shouldn't bigger riders ride bigger tires?
    By singletrackmack in forum Clydesdales/Tall Riders
    Last Post: 06-19-2015, 08:06 PM
  4. Replies: 3
    Last Post: 06-05-2015, 06:23 PM
  5. Chain jumping from small chainring to middle chainring
    By menusk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2013, 10:31 PM
