Results 1 to 8 of 8
    NFD: 2014 Nine 1
    Picked up a new '14 Nine 1. Changed a few things on it. Its a large btw.
    XX1 Cranks, 36t ring. 1x10 setup.
    Chris King BB
    I9 Torch Wheels. Red hubs.
    Thompson Stem. 110mm
    WTB Ti Silverado Saddle
    2.3/2.25 Racing Ralphs-Tubeless.
    Ditched the front derailleur and left shifter.
    Comes in at a little over 21 lbs. Got 2 rides in so far. Its pretty fast.
    NFD: 2014 Nine 1-img_20131120_153727_260_zps402175fe.jpg
    That frame and build look really good.
    I hate to badger you with questions, but I'm trying to decide on a new HT and the Felt's geometry coupled with the fact that a 36t XX1 chainring fits makes it pretty appealing. My only concern is that I noticed the bb is on the low side. Have you had to make any adjustments to avoid pedal strikes? Also, what do you think about the ride - is the rear end on the stiff side, or is it fairly compliant?
    Well its stiff. Very stiff, yet compliant. Best I can describe is this. On my alum hard tail, when I land a jump, it hits pretty hard. You land with a BANG! On the Felt, you land with a thud. THe carbon absorbs the shock without any noticeable flex.
    I also have a Pivot 429 Carbon. I pedal strike a lot with that bike if I'm not careful. This bike I have not, not yet anyway.
    I was concerned about the geometry being a little too aggressive. With the 100mm fork its perfect. My only complaint is with a zero degree stem, the shifter doesn't clear the top tube. I don't want the bars any higher so for now I will run the shifter a tad loose. I have a bit of clear 3m tape on the top bar. I will try to keep the crashes on the left side.
    Thanks for the good feedback - that's helpful.
    Certifiably Crazy
    Reputation: Carloswithac's Avatar
    Feb 2012
    Sweet bike! I miss riding my hardtail.
    2013 Felt Edict Nine
    Reputation: Whyzee429's Avatar
    Sep 2012
    NFD: 2014 Nine 1
    Any updates now that you've had it for over a half year?
    Reputation: plume's Avatar
    Quote Originally Posted by Whyzee429 View Post
    I've had a 2015 for a couple of months now. I haven't ridden it a ton but what I've taken from it is that a low BB and relatively short stays coupled with a very light and snappy frame make it a very fun race bike. But, that's what it is, a race bike. I prefer lower BB especially on 29ers since it helps a bit in the corners and have no issue with pedal striking on occasion consider how well the bike handles for what it is.
    My goals are a handful of XC races then I plan to purchase an Enve fork and use the bike for some more technical gravel races and even some CX. I even have commuted on it a few times. Great bike if you're looking for a rocket. Mine was 20.5 lbs out of the box and closer to 21.5 with tires that I trust. I can lose 100 grams or more when I switch wheels.
    The X0 drivetrain is acceptable but I do prefer Shimano. The x0 brakes are adequate but noisy. Sid is a good fork, and the wheels are decent enough.
    Hope this helps a bit. All in all a decent value for the money!
    My one says BRAP!
    Aug 2013
    hi, can this frame be converted to SS? thanks
  1. Replies: 18
    Last Post: 04-21-2015, 10:38 AM
  2. 2014 Fuel EX 5 29er vs 2013 or 2014 EX 6
    By TheChefJPratt in forum Trek
    Last Post: 07-23-2014, 11:54 AM
  3. Replies: 56
    Last Post: 06-27-2014, 10:16 PM
  4. 2014 X-Cal 8 or 2014 Superfly 5?
    By 80sforlife in forum Trek
    Last Post: 01-26-2014, 04:44 AM
  5. 2014 When?
    By stygz1 in forum Specialized
    Last Post: 05-23-2013, 04:12 AM
