Results 1 to 3 of 3
    Increase fork travel on 2013 Felt Nine 50
    I recently purchased 2013 Felt Nine 50 Bike. The front fork is a “RockShox Recon Silver TK 29 solo air, tapered aluminum steerer tube, forged alloy crown, magnesium lowers, disc mount, lockout, adjustable air spring, adjustable rebound, 100mm travel (80mm fork on 14" offering)”.
    I see on SRAM’s website I can increase the travel of this fork to 120mm by removing spacers. But also in my research I have read some OEM forks cannot increase travel from the manufacture spec’s. Does anybody know if this is true and this particular fork? Don’t want to take the fork apart and find out it cannot be done.
    tmb
    tmb is offline
    When in doubt- turn left
    My(and my wife's) Edict 50's came w/ the Recon Gold, and yes I was able to remove the internal spacer and make them 120mm.
    Feb 2012
    You might want to double check with felt as it's possible that adding that travel could add stress to the frame and void the warranty. At least to be safe.
  1. Increase fork travel on 2013 Felt Nine 50
    By tjwil9488 in forum Felt
    Last Post: 09-01-2013, 10:46 AM
  2. Replies: 8
    Last Post: 03-06-2013, 05:33 PM
  3. Fox 32 travel increase?
    By capslayer in forum All Mountain
    Last Post: 04-04-2012, 08:29 AM
  4. Fox 32 travel increase?
    By capslayer in forum Shocks and Suspension
    Last Post: 04-01-2012, 09:32 AM
  5. Can 6 mm increase in CS be felt?
    By jeremy524 in forum 29er Bikes
    Last Post: 12-30-2011, 02:52 PM
