Results 1 to 3 of 3
    Felt Q200 - Newbie from UK
    Hi, im new here, & fairly new to biking overall
    Had a quick scout through the site the last few days & theres a lot to take in
    Just purchased a Felt Q200, rode very nicely when i tried it. But havent found much info at all on the net (including on here) in terms of reviews, so if anyone has any please post on here
    Hey Connery -
    I'm stateside, and hadn't even heard of that model until I saw your post. It looks comparable (visually) to the Felt Q520, but you'd have to compare components to draw a definite verdict. I ride an '07 Felt Q620 myself, which has been a pretty solid workhorse for me.
    I think about getting this as a cheap bike for the city.
    COLORS:
    Gloss White, Semi Matte Black
    SIZES
    13.5, 15.5, 17.5, 19.5"
    FRAME
    Felt 6061 Externally Butted Aluminum, Round Tapered Top Tube, A-Style Seatstay Design, Oversized Semi-Integrated Head Tube, Replaceable Derailleur Hanger, Rack & Fender Mounts, Basta-Lock, V-Brake and Disc Brake Compatible
    FORK
    SR Suntour XCT-V2 80mm travel, Pre-load, Internal spring, Alloy Crown, Alloy lower with STKM Stanchions. With spring seal design.
    HEADSET
    Semi-Integrated 1-1/8" Aheadset--Steel Cups, Caged Bearing, with Alloy Laser Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
    STEM
    FELT One-Piece Melt-Forged Design, 1-1/8" Threadless Aluminum, 4-Bolt, 15 Degree Rise. CP Hardware BLAST BLACK Extensions: 13.5/15.5/17.5=90mm; 19.5/21.5=110mm
    HANDLEBAR
    30mm Rise, 6 degree Bend, with Felt Logos. Widths: 13.5-17.5=580mm; 19.5=600mm; 21.5=620mm
    GRIPS:
    Felt Dual-Density Extra-Soft & Sticky (Recipe #25)center with Hard Outer Durometer, 130mm Length, 30mm OD, Grey outer/Blk grip section
    BAR END CAPS
    Rubber Plugs w/ Felt logo Bubble Decal, Included w/Grip
    SHIFTERS
    Shimano Altus ST-EF50 EZ-Fire Plus, 21 Speed
    FRONT DERAILLEUR
    Shimano C051 Dual Pull
    REAR DERAILLEUR
    Shimano RD-M360 Acera
    CRANKSET
    SR/Suntour CW-XCC-T208PB Melt-Forged Aluminum, 48/38/28T Steel Rings. With Chain Guard. Lengths: 13.5-15.5=170mm; 17.5-21.5=175mm
    BB SET
    TH Cartridge Type, Cr-Mo Axle & Cup
    FREEWHEEL
    Sunrace 7-Speed Spin-On Type,14, 16, 18, 20, 22, 24, 28T, UCP Finish
    CHAIN:
    KMC/Shimano UG51 (7-Speed) Brown
    BRAKE LEVERS
    Shimano Altus, Integrated w/Shifters
    BRAKES:
    Tektro 855-AL, V-Type Brake, Aluminum Melt-Forged Arms, Linear Spring, Dual Spring Adjust, 110mm Arm (Fender Compatible) with Custom 60mm Pads and All-Black Hardware
    CABLES:
    Custom Felt Cable Set, Standard Black Casing, Featuring CP Stamped Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and One Red CNC Alloy ferrule
    SADDLE:
    Felt "RXC" Comfort, Low Side Profile Look with Wide/Flat/Plush Top, Double-Density Base, Satin Steel Rails
    SEAT POST
    Felt Alloy Micro-Adjust, 100% Black, 6061 Low-Profile Forged Head & Extruded Rall Clamps, 27.2mm x 350mm (CEN)
    SEAT POST CLAMP
    Felt Bolt-Type with Logo, Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 31.8mm
    F/HUB
    Aluminum Body 32H, with Alloy Q/R Levers
    R/HUB
    Aluminum Body 32H, Spin-On Freewheel Type, with Alloy Q/R Levers
    RIMS
    Alloy Doublewall, 26 x 1.5 x 32H, 23mm Width, Presta Valve, Black Anodized
    TIRE
    FELT THC XC Trail Highway City 26 x 2.1 30TPI Wire Bead, with Presta valve Inner Tubes
    SPOKES
    Sandblast Black Stainless 14G, Brass Nipples
    PEDALS
    MTB Design Steel Cage / PP Body
