Results 1 to 3 of 3
    2013 Felt Nine 50… massive vibration during braking… bad frame?
    Recently purchased a 2013 Felt Nine 50 Bike, Not long after I purchase the bike I’ve been experiencing a massive vibration throughout the whole bike during breaking at any speed.
    Brought it back to the LBS where I bought it, they made some minor adjustments (basically tightening everything down) unfortunately this didn't help. After bring it back a third time, they contacted FELT, which FELT then recommended contacting the brake manufacture, SRAM. SRAM was kind enough to replace and upgrade the brake system to the 2014 Elixir 9 Trail Hydraulic Disc Brake (four piston), original brake system was Avid Elixr 1 hydraulic disc brakes, after a few miles of riding the problem came back. So I then replaced the rotors, original rotors Shimano with Centerlock. I purchased the Shimano Centerlock adapter and compatible SRAM Avid rotor for the Elixir 9, still the same problem. I then upgraded the wheels with a different hub, direct six bolt for rotor. And again same problem!
    So conclusion has to be a bad FELT Frame!!
    Nov 2012
    Just in case you are having the same issue as me check your rear chain stay, I have broken two (second one this morning). What this does is causes the tire to rack sideways and rub the frame causing a vibration especially under heavy rear braking or pedaling.
    Reputation: TracksFromHell's Avatar
    Jul 2014
    Could be the forks, could be the tires, could be a loose headset.
    Does it happen with either front or back braking?
    What PSI are you running?
    What suspension do you have?
    What speed does it start at/end at?
  1. Large vibration with rear braking
    By tjwil9488 in forum Brake Time
    Last Post: 03-18-2015, 12:22 PM
  2. XT brake vibration on 2013 Stumpy Expert Evo 29
    By faip22thedoc in forum Specialized
    Last Post: 08-22-2013, 06:37 AM
  3. Replies: 19
    Last Post: 07-01-2013, 11:05 AM
  4. Replies: 21
    Last Post: 04-24-2012, 10:39 AM
  5. Replies: 10
    Last Post: 05-13-2011, 02:14 PM
