Results 1 to 17 of 17
    Dec 2013
    Yellow Rim Strips ?
    Looking for some yellow rim strips for my yellow Pugsley with Marge Lite Wheels. Surly doesn't sell that color. Any ideas out there? Thanks.
    Go to a craft store and buy yellow ribbon, 2" width. Or use yellow Duck (brand) tape.
    Jason
    Disclaimer: www.paramountsports.net
    nvphatty
    Guest
    Quote Originally Posted by JAGI410 View Post
    yup craft stores carry all sorts of materials avail to use. I found wht vinyl table material for mine and cut to fit.
    Reputation: smithcreek's Avatar
    Nov 2012
    I used cordura (backpack material) and it works well.
    Dec 2013
    Thanks for all the replies. -38 F. yesterday here in Northern MN. I didn't take the bike out.
    nvphatty
    Guest
    Quote Originally Posted by Jackpine6 View Post
    i seriously doubt anyone would in those temps. only zero here and i'm not movin either, except on my trainer.
    You must live right by me, I'm in Ely.
    Dean.
    Reputation: duggus's Avatar
    ...Be careful what you're looking at because it might be looking back...
    Reputation: bikefat's Avatar
    Nov 2013
    Looks pretty cool. The downside to those Borealis rims I want, is my rims won't be all tricked out.
    Denver Broncos: 101-3 since 1975 when scoring 30+ at home.
    C.J. Anderson career YPC = 5.67
    Reputation: maddslacker's Avatar
    Quote Originally Posted by bikefat View Post
    You could always get the Fatback carbon rims, since they have cutouts.
    Reputation: Pro4tundra's Avatar
    When taping fat bike rims with cutouts, how do you avoid the sticky side from collecting dirt and debris through the cut outs? I must be missing something.
    Reputation: anvil_den's Avatar
    Nov 2007
    The sticky side has got to be on the inside and you probably have to be sticking it onto something first.
    I'm cheap.. just reused my existing Surly rim tape and stick some nice color "flamed" tape over it
    Yellow Rim Strips ?-kytsywy-p0lp0y3xkktnymrl0gjofjvyd702vj1q7me.jpgYellow Rim Strips ?-a3bljfpr1f7hw7vclgpog0vkn0kpbfzc62yuoruead0.jpg
    If you go the route of the reflective adhesive tape, it has a backer on it. You can just leave that on the tape, or peel it off after you've gone full circle. I take a standard 3-hole punch and put a hole in it for the presta valve, perfect size, nice and clean. That gives me 1/4" of overlap and I use the adhesive on the tape to hold the 2 ends together.
    Quote Originally Posted by Pro4tundra View Post
    I did like this... took the colored rim tap and wrapped it around my rim with the colored (non-sticky) side facing the rim cutouts. LEAVE THE COLORED TAPE BACKING ON. When I got all the way around I taped it to the other end. Then I ran two strips of duct tape sticky side to what would be the sticky side of the colored tape, all the way around. This holds it in place and acts as another barrier so the colored tape doesn't burst when you add air pressure.
    The grey is the two strips of duct tape, colored tape underneath:
    Ahhh, making much more sense now. Thanks guys.
    Oslo, Norway
    Feb 2012
    We're running Tyvek material from a map.
    Looks cool and weighs 12g vs typically 80-115g for a 90mm strip (for 100mm rims)
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    Nov 2013
    http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
    I have just replaced the surly rimstrip. looks pretty smart with lights!
  1. Different coloured rim strips - where can I get them?
    By flatlandersk in forum Fat bikes
    Last Post: 04-28-2016, 02:30 PM
  2. Are Stan's rim strips necessary?
    By head in forum Wheels and Tires
    Last Post: 12-09-2013, 07:18 AM
  3. Comic Strips..
    By Fishbucket in forum Off Camber (off topic)
    Last Post: 03-19-2013, 06:20 AM
  4. need help getting the right Bontrager rim strips.
    By muell in forum Wheels and Tires
    Last Post: 02-02-2013, 05:40 PM
  5. Bontrager rim strips?
    By Graysku11 in forum General Discussion
    Last Post: 09-06-2012, 01:57 PM
