Results 1 to 44 of 44
    Apr 2014
    xx1 crank with next sl spindle
    Found out they have same insert,so have to try it out xx1 crank with next sl spindle-dsc_0027.jpgxx1 crank with next sl spindle-dsc_0030.jpg
    great success
    aka bOb
    Reputation: bdundee's Avatar
    Now this is interesting!!
    What width spindle and what is the distance between the inside of the arms?
    Apr 2014
    since i had a xx1 crank i was not using,it was cheaper to buy the spindle instead of a new crank
    Apr 2014
    for 170 rear spacing,it is 140 mm between the arms.
    aka bOb
    Quote Originally Posted by mortenste View Post
    Thanks dude!!
    Reputation: CYCLEJCE's Avatar
    Hmmmmm. I wonder if the XO-1 would have the same spindle/crank interface? Can someone verify? I'm looking for a 100mm option in a carbon crank with 175mm arms...
    Apr 2014
    probably the same,if it is bb30 spindle.
    Reputation: Fat907's Avatar
    Jun 2014
    Whose red chainring is that?
    Apr 2014
    It is a absolute Black chainring.
    I'm interested in giving this a try. What Q factor are those cranks? What frame did you put them on and how did they fit? I'm curious if this would work with the narrower 156q cranks.
    This is good info. My question is how did you get the xx1 spindle out? I thought the axle was pressed in on the drive side? I only have the gxp version so I am not sure if itis different from the bb30. Thanks
    -Nolan
    Apr 2014
    Quote Originally Posted by uwprunner View Post
    I am about to put them on a fb-02 chinese frame,dont know the Q factor
    Apr 2014
    Not pressed on the bb30.i had to use alot of force to screw it off, and a rubber mallet to punch out the spindle.
    Reputation: jfrbikes's Avatar
    Where were you able to order the 100mm next sl spindle?
    Apr 2014
    Ebay
    aka bOb
    Nice find right there, Bam!!!
    Rhymes with fartmaster
    Quote Originally Posted by CYCLEJCE View Post
    THREAD HIJACK ALERT!
    What is that blue vehicle in your avatar image?
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    Quote Originally Posted by Leopold Porkstacker View Post
    I think it could be a car
    I am slow therefore I am
    Jul 2013
    Hi,
    I tried the same, but I think it isn't that simple.
    The spindle fits perfectly, and the solution is some ~30gr lighter than the genuine XX1 GXP crank for fatbikes. But the q-factor is way to big for 170mm rears. Perhaps this works with a 190mm rear or you must look for the smaller Q-156 version of the BB30 crank. I had only the wider version with q-168.
    (the shown race face spindle is the 170mm version and the gxp XX1 also)
    (The weight of the BB30 version with race face spindle is about 475gr.)
    xx1 crank with next sl spindle-img_2791.jpgxx1 crank with next sl spindle-img_2790.jpg
    Apr 2014
    Its 10 mm clearence with the raceface spindle.is that to much?
    Attached Thumbnails Attached Thumbnails xx1 crank with next sl spindle-dsc_0118.jpg
    aka bOb
    Quote Originally Posted by larres View Post
    Hi,
ID:	915101Click image for larger version.
    Thanks!! Do you happen to know the distance between the inside of the arms with the Next spindle installed?
    nvphatty
    Guest
    me believes not.
    Jul 2013
    I ve measured ~22,3cm from outside to outside at the hole for the pedals.
    Here is a picture from the mounted GXP Fatbike crank. That is about 1cm distance, on a 2013 Mukluk 2.
    The BB30 crank would be to wide for me.
    Apr 2014
    maybe with the gxp crank i would bump into the chainstay.so cheaper and better option for me with the race face spindle.
    Quote Originally Posted by Burnt-Orange View Post
    Smartass. Car looks like something older with character, not all dumbed-down with modern-day floofy electronic garbage which takes the fun out of driving.
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Anybody know if this would work with regular XO GXP crank arms? I think it's the 168 q factor...
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
    Wait, does this mean that I could use the arms of my XX1 BB30 156q cranks on the spindle of the Race Face Turbine cranks on the Yampa I ordered?
    Apr 2014
    If the race face is a bb30 yes
    i need a wider q factor. so accordingly the 190mm spindle would produce roughly a 22.3cm from inside to inside of the crankarms?
    Mr. Knowitall
    Reputation: hssp's Avatar
    Is this at the spindle? Seems improbable that the width is 140mm at the pedal...
    Can anyone confirm the Q factor with the 100mm (for 170mm hubs) Race Face Spindle? I have an opportunity to get some BB30 Q168 cranks and I consider doing it - if the Q is sufficiently narrow. (i.e. not too much wider than 202.5mm that is on my X5 cranks, with means 176mm between the inside of the crank arms at the pedal).
    Handmade in Switzerland
    Reputation: maettu's Avatar
    Quote Originally Posted by hssp View Post
    The q-factor with a standard SRAM x0 BB30 crank (Q168mm) combined with the RF 170mm cinch spindle is more or less 210mm. This is exactly in the middle between the RF Next SL crank with 170mm spindle (q-factor 202mm) and the Next SL crank with 190mm spindle (q-factor 222mm). For me, this is perfect...
    Mr. Knowitall
    Thanks. Then this option will be out of the question for me. Maybe if I go for a Q156 on my Bucksaw?!?
    Reputation: Espen's Avatar
    What is the exact lenght of the 170 spindle?
    Thanks in advance.
    Espen
    X0 BB30 crank with cinch spindle
    Although it was not intended for a fat bike I decided to share my project of swapping a SRAM BB30/PF30 spindle for a Race Face Cinch spindle.
    I had a SRAM X0 BB30 crank collecting dust and wanted to install it in a BMC carbon frame with 92mm BB shell. The spindle was too short so I ordered a 134.5mm Race Face 30 mm spindle. I followed the instructions described in this post and worked great. Some things to consider:
    - The spindle ends portion that fits in the crank arm are 2 mm shorter than the SRAM so you have to add around 4 mm to the spindle length that your are gonna use because the ends do not get to the edge of the crank arm
    - Get a M18 steel bolt (Race Face X type) to hammer the spindle out of the left crank arm and also to torque the new spindle. You will avoid damaging the SRAM alloy M18 bolt the comes with the crank. Once the spindle is pressed you can remove the steel bolt and place the alloy one.
    - My Q-Factor went from 168 to 185 mm
    xx1 crank with next sl spindle-img_2678.jpgxx1 crank with next sl spindle-img_2679.jpgxx1 crank with next sl spindle-img_2681.jpgxx1 crank with next sl spindle-img_2683.jpgxx1 crank with next sl spindle-img_2684.jpgxx1 crank with next sl spindle-img_2688.jpgxx1 crank with next sl spindle-img_2690.jpg
    Jun 2016
    Quote Originally Posted by schuster_md View Post
    Hi!
    What a torque moment for a left crankarm alloy bolt?
    And it need a grease or locktite?
    I think that it is a good way to avoid buying the stages spindle and can install the carbon version in a Sram mtb crankset.
    No, it is not valid for what I thought. Actual spindle is shorter than needed and also it is compatible, see the next picture:xx1 crank with next sl spindle-stages-cycling-power-meter-carbon-bb30-welle-fuer-sram_b2.jpg
    Jan 2017
    Has anyone tried fitting BB30 crankset into BSA 73mm with help of RF spindle? I wonder which spindle length is required for this.
    Quote Originally Posted by Barmalyha View Post
    Hi!
    I used the same torque recomended in the removable arm bolt. Phil Wood was applied in the spindle-arm interface and thread locktite in the alloy bolt thread.
    Quote Originally Posted by maettu View Post
    Are you sure you have 168 Q SRAM cranks?
    Based on your info I bought a set of XX1 168 Q to go with RF 170 spindle on my fat bike, I currently have RF turbine cinch, 170 spindle that fit great. Q 212 approx, I tried RF next SL and they were too close to chain stays and were stupid with 190 spindle and chain line was no good.
    I just tried the SRAM 168 Q with 170 RF spindle and the Q was approx 224mm.
    This means the 156 Q should achieve 212mm, the desired Q
    Some pics of RF turbine cinch 170 spindle
    RF next sl 190 spindle
    SRAM xx1 186 Q with RF 170 spindle
    Aug 2017
    Well... this thread is a good find! I would love to convert my x0 carbon crank to be fat bike compatible!! I am pretty new to the technical side, but worst case scenario, a machinist may be able to help.
    Aug 2017
    How have these cranks held up to use? And falling off crank arms?
    No problem so far after 1+ year
  1. Help with Longer Spindle on New Crank
    By LowOnO2 in forum Singlespeed
    Last Post: 03-07-2014, 05:33 AM
  2. Crank spindle extenders
    By funnyjr in forum Fat bikes
    Last Post: 01-20-2014, 10:38 AM
  3. xx1 crank spindle replacement
    By trance3 in forum Fat bikes
    Last Post: 12-16-2013, 04:02 AM
  4. Specialized P2 crank spindle?
    By Collins in forum Urban/DJ/Park
    Last Post: 12-10-2013, 12:42 PM
  5. XTR Crank spindle not long enough?
    By cfrea in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2013, 07:35 AM
Members who have read this thread: 56
