Results 1 to 5 of 5
    Will ClownShoe fit on Mukluk?
    Looking to change out my darryls to drilled clownshoes, just wanted to know if this setup will work or if anyone has done it? and any issues with it if you have done it? thanks
    Which Mukluk and which crankset?
    Latitude 61
    2010 mukluk, e13 crankset, running 1x9
    I have a Muk3 with the e13 crankset with BFLs on Clownshoes, and I have chain rub on my lowest three gears when on the granny up front. I assume you have your chain ring for your 1x9 in the middle position, which should give you very minor to no rub at 1-1, as I am rub free on what would be 2-2, as I removed the 12T from my cassette and put a spacer behind it. Just dish the rim a little to the non-drive side, and you should be good. And any tire smaller than a BFL should be good.
    Reputation: Johnclimber's Avatar
    Fit's the front ok
    Moses parting the waves by Johnclimber, on Flickr
