Results 1 to 3 of 3
    Reputation: motorman's Avatar
    Wheel building help needed - spoke offset??
    Hi Folks,
    I have a set of Snowcat rims I am trying to build up for my 29er+ 9Zero7.
    The rim has offset spoke holes that alternate 4mm & 8mm from the rim centreline.
    Question is, how do I enter these figures into the spoke calculator for building the offset rear & non offset front wheel?
    I don't understand which is + & which is -??
    Any help appreciated
    Drink coffee....ride bikes....eat cake
    http://morayfatbike.blogspot.com
    Reputation: Velobike's Avatar
    I just change the figure for the flange differences to compensate so the calculator doesn't know about the offset.
    Sketch it out. Helps prevent mistakes.
    Latitude: 5736' Highlands, Scotland
    read;
    Fat Bike Wheel Building | Golden Bike Shop
    Fat Bike Wheel Spoke Length
    If using a program like freespoke Freespoke with rim and hub offset; then enter the left (Non-drive side) rim as negative (-) offset, meaning the spoke crosses over centerline of the rim, and for the drive side spoke, the rim hole offset is positive. Enter hub offset (17.5) as a positive value. For an offset rear wheel, this should give you two spoke lengths that are very close to eachother (within 1mm). If you get two very different lengths, you did something wrong. Note that with your rim having two slightly different offsets, you can tweak the spoke lengths a tiny bit (to equalize) by selecting which of the offsets is laced to which rim flange, enter at either -4,8 or -8, 4.
    Also note that it is very easy to drill new holes on opposite side of snowcats if needed, such as to change a 32 hole set into a 38 hole set or to use same max possible offset for both sides (Like -10, +10) in order to better equalize the spoke tension...
  1. Offset wheel building help...
    By Weinerts in forum Fat bikes
    Last Post: 09-28-2013, 08:50 AM
  2. Rusty at Wheel Building: The 49 spoke wheel.
    By Fleas in forum General Discussion
    Last Post: 09-02-2013, 07:17 PM
  3. Wheel building & Spoke lengths
    By dis00 in forum Wheels and Tires
    Last Post: 08-02-2013, 09:05 AM
  4. Wheel build spoke length info needed.
    By easterntide in forum Fat bikes
    Last Post: 05-02-2013, 07:37 AM
  5. Wheel building, spoke question
    By cbieh589 in forum Wheels and Tires
    Last Post: 05-30-2011, 02:33 PM
Members who have read this thread: 4
