Results 1 to 19 of 19
    Dec 2017
    What are your wheel weights with tires in as ridden condition?
    Mine are, with mounted tubeless Origin8 Tsunami 4.9 tires, in lbs:
    Front 8
    Rear 9
    How does this compare to others?
    turtles make me hot
    Reputation: NYrr496's Avatar
    I'll play next time I switch wheels on my bike. I know mine are pretty darn light even though I run 5" tires. I was on a ride last weekend with a friend and handed my bike to him over a fallen tree. He couldn't believe how light it was.
    I like turtles
    Is op including cassettes? Rotors? Axles?
    Sent from my Moto G (5) Plus using Tapatalk
    Dec 2017
    Yes, everything attached to the wheel in as ridden condition, including rotors, freewheel/cassettes/cogs, skewers/nuts, etc
    Mar 2015
    here are my wheel weights. All wheels have RT66 rotors and SLX level 10 spd cassettes. Mine are all thru axles so the weight of the TA is not included.
    Dillinger 4 on 65mm Carbon rim w/tube
    F 6.15 lbs
    R 7.21
    Dillinger 5 on 100mm carbon rim tubeless
    F 6.68
    R 7.75
    CakeEater 27.5x4 on 50mm carbon w/tube
    F 5.75
    R 6.8
    For reference my summer setup of 29 plus is below
    WTB Ranger on 50mm carbon tubeless
    F 4.5
    R 5.5
    Reputation: blockphi's Avatar
    Mar 2012
    Hmmmm...
    Front: Quite a bit
    Rear: Quite a bit more
    Couldn't be arsed to actually weigh any part on my bikes - until I am not such a fat ass and get to 6% body fat, part weights don't really matter.
    Mar 2015
    While i don't obsess about part weights, there is a very noticeable difference in wheel weights. i can easily tell when i am on a tubes vs tubeless wheel. you do get used to it but you can tell. YMMV but wheel weight is something that i will spend extra to get less of it. I also weight 250Lbs so it is a very small % of my overall mass but to me it is worth it.
    Dec 2017
    Quote Originally Posted by Jefflinde View Post
    F 6.15 lbs
    R 7.21
    F 6.68
    R 7.75
    F 5.75
    R 6.8
    F 4.5
    R 5.5
    How much do the thru axles add?
    Reputation: DirtyHun's Avatar
    Jan 2011
    A good bit. They are chunky.
    2016 El Oso Grande
    Mar 2015
    my axles are about 80 grams i think. don't have my gram scale handy at the moment. the axle is not as critical since it is not rotating. while you don't want a super heavy axle i am not concerned about them. it is also the same axle for all my wheels as the axle goes with the frame
    Set 1
    616 hubs, Yishun 85 carbon rims, no skewers, Escalators studded
    F 5.5
    R 6.4
    Set 2
    Brickhouse Hubs, HED 85 carbon rims, D4 Studded
    F 5.2
    R 5.9
    Set 3
    WTB modded hubs, Lamere 65 rims, Escalator studded
    F 5.3
    R 6.1
    Latitude 61
    Is 5.2, 5lbs 2oz, or 5 and a fifth of a lb?
    Mar 2015
    All my weights where in lbs so 5 and 1/5 lbs.
    Mine are in pounds and tenths of pounds.
    Latitude 61
    150 Hope/LB 65mm: 960g
    200 rotor/4.0 JJ tire:1261g
    front total: 2221g (4.9lb)
    177 Hope/LB 65mm: 1090g
    180 rotor/4.0 Jug Pro tire/XT 10spd 11-36:1350g
    rear total: 2440g (5.4lb)
    turtles make me hot
    Ok... Took me a while. I tried to weigh my wheels on my little tabletop Park scale but the wheels with tires mounted overloaded the scale. I picked up a Feedback Sports scale, the whole bike one. Good to 55 pounds. Here's what I got:
    Front Clownshoe with split tubeless Big Fat Larry weighs 7.43 pounds
    Rear Clownshow with split tubeless Big Fat Larry weighs 8.51 pounds. These wheels are built with Hope hubs, double butted DT Swiss Comps, brass nipples and 24" Q Tubes.
    My Surly Other Brother Darryls are also on Hopes. Double butted Comps and brass nipples. They're set up tubeless with Whiskey tape. I made rim strips from black Gorilla Tape.
    Front with Surly Bud weighs 7.03 pounds.
    Rear with Surly Lou weighs 8.25 pounds.
    Both wheels are using ten speed Shimano XT Cassettes.
    Here's where I was really surprised, and I will weigh my son's wheels when I get a chance. My bike is an aluminum 907 XL frame. I hung it on the scale expecting it to weigh around 32 pounds. It weighs 30.8 pounds. I then thought to myself, my son's Medium with Marge Lites and HuskerDus is probably under thirty pounds. Surprise! It weighs 30.75 pounds. He's split tubeless also but his rear hub is a Salsa. It was pretty heavy if I remember right. All I could get at the time.
    I'm currently building him a Large. I'm going to try and make his new one under thirty.
    I like turtles
    Hows it goin?
    Reputation: Steve Hill's Avatar
    Stock Trek Farley 7 MuleFut 27.5 80mm rear wheel with tube, rim strip, and Barbegazi Tire = 4065g or 8.96 lbs.
    Wheel is 2310g, tube is 430g, and Barbegazi tire is 1325g
    Tubeless:
    Rim with Sun Ringle 78mm tape = 2325g
    Wheel with 4 oz or 120 ml sealant and valve is 3785g or 8.34 lbs.
    A savings of .617 lbs. As long as the sealant holds at 4 oz......
    And the 4 Oskar Blues IPA I consumed while getting the damn thing to seat (finally went with the tube method) are calorie free of course.
    Aug 2016
    Aug 2016
    I don't use wheel weights, mine are pretty heavy without 'em.
    Bicycles don't have motors.
  1. Replies: 48
    Last Post: 6 Days Ago, 10:56 PM
  2. Showroom Weights vs Actual Weights
    By Richardwyngaard in forum Weight Weenies
    Last Post: 05-24-2017, 06:32 AM
  3. XX1 Mini-Review & Weights, XTR Weights, Race Face Next Crank Weight
    By brentos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-31-2012, 05:03 PM
  4. Hub weights...Syncros, wtb, Hope pro 2 Evo weights
    By RTM in forum Downhill - Freeride
    Last Post: 07-26-2012, 06:44 PM
  5. Summer wet condition tires
    By los05 in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-05-2012, 01:14 PM
Members who have read this thread: 128
