Results 1 to 13 of 13
    What replacement tube do you use/recommend?
    For those of you that ride the 4.7 tires (Surly Big Fat Larry etc.), what replacement inner tube do you use/carry as your spare? I'm not quite ready to go tubeless. Care to share your recommendations on a replacement tube?
    The Surly light 3.0 - 4.0?
    Other?
    Q-tubes 2.3-2.7?
    Is this large enough?
    Reputation: marathon marke's Avatar
    Sep 2012
    I use and carry the Surly 3.0 - 4.0. I thought I heard that narrower tubes wouldn't work well when riding the real low pressures, since the tube never reaches it's full shape. I ride a Moonlander, so I don't expect the bike to be as light or ride anything like a CF frame/wheel setup.
    - Mark Ehlers
    The Prodigal Cyclist
    Sep 2004
    I've been running 26x2.4 trek presto tubes for three seasons now, LML/nates up to clown shoe/bud, not a single flat and only 201 grams each!
    Sep 2012
    Quote Originally Posted by bowtiguy View Post
    bowtiguy, that's good to hear. What's the lowest pressure you run with these? I might have to try them at some point.
    - Mark Ehlers
    Quote Originally Posted by gdb2b View Post
    We still talking about tubes?
    Yup, large enough and even gets soft when you need it to.
    Quote Originally Posted by MiniTrail View Post
    something about bursting bubbles comes to mind
    I'm your Huckleberry.
    Dec 2011
    Quote Originally Posted by jonshonda View Post
    Q-tubes 2.3-2.7?
    I've used them in BFL's with no problems.
    Sep 2004
    Quote Originally Posted by marathon marke View Post
    I don't have a gauge but I'd say down to 4-5 psi, I put lots o baby powder on them prior to install so they don't hang up if the tire slips on the rim.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    ...I'm not quite ready to go tubeless...
    What?
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    I have not flatted on the fatbike yet (3rd winter), so I can only comment that the original Surly tubes are bulkier than I want to carry on recreational rides for this low risk of flats.
    But I see Surly now has an "ultralite" fat tube alternative....
    Universal Cycles -- Surly Ultralight Fat Bike Light Tube
    Roadie
    Jan 2014
    Quote Originally Posted by mtbxplorer View Post
    At 310g that isn't really "light" and at $20 a pop, it ain't cheap either. At least it's reliable?
  1. Replies: 3
    Last Post: 10-23-2013, 07:04 AM
  2. Recommend a replacement for Fox launch leg armor?
    By howl in forum Apparel and Protection
    Last Post: 09-24-2013, 04:43 PM
  3. Recommend me a replacement tyre..
    By deesta in forum Wheels and Tires
    Last Post: 03-26-2012, 11:13 AM
  4. Fork steer tube replacement
    By bfree in forum Shocks and Suspension
    Last Post: 08-31-2011, 12:07 PM
