Results 1 to 7 of 7
    What crank for BFLs on Clown Shoes
    I have a Carver O'Beast with BFLs and Clown Shoes. My MWOD is in serious need of help. I am looking to replace it with something lighter. Any recomendations that will give me full use of all the gears with a double up front. I don't like the Surly OD due to the 1990 era bolt pattern.
    Jul 2013
    E*thirteen seems to have a crank with larger offset now too. Those might fit your setup.
    I use mwod on my moonlander though. need some better bearings on them.
    Reputation: gcappy's Avatar
    9-0-7 170 mm frame, BFL's, MWOD, ten x two.
    Reputation: AllMountin''s Avatar
    Not a fan of the MWOD either. Lack of crank arm clearance makes proper bash fitting impossible. Had to massacre my tooth fairy to fit it. To make things worse, the 58mm spider means that the only thing supporting a bash is the mid ring itself. I put a brand new chainring on, mated to a bash. First minor rock hit on the first ride put it out of true.
    A fat bike is supposed to be a go anywhere/ride anything bike. Not having a useful bash is a major liability in the rocks. No ISCG for a taco bash either.
    Not sure where to go with it. I need the granny for deep snow, but I also need a tougher crankset that can handle moderate hits to a bash.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Re: What crank for BFLs on Clown Shoes
    Phil Wood with Middleburn?
    --Lars
    --Peace
    ive got a Ti Obeast with x type middleburns with a plus 5mm ? offset
    moves inner to middle and middle to outer position
    clearing bud on a marge lite
    Jul 2013
    Quote Originally Posted by cozz View Post
    Nice stuff
    Though my Witjira frame is comparable and i got Middleburn crank with Rolling darryl and Bud/Lou - The standard Mono chainring didnt clear the tire for the 2 inner rings. My lbs had some first generation 100mm Middleburn crank stuff though that positioned the ring further outward and that solved my problem.
    I like the middleburn very much - very high quality cranks.
    But would recomment to only go for them when you have a lbs that is willing to test the fit of them with BFL and clown shoes.
  1. Anodized or Painted Spokes? Clown Shoes
    By SpyGame in forum Fat bikes
    Last Post: 01-23-2013, 09:24 AM
  2. BFL's on Clown shoes and 170 9zero7 set up question
    By Boatracer in forum Fat bikes
    Last Post: 01-05-2013, 10:11 AM
  3. Nates on Clown Shoes
    By Bewelnak in forum Fat bikes
    Last Post: 01-31-2012, 09:36 AM
  4. Clown Shoes anyone?
    By lancelot in forum Fat bikes
    Last Post: 11-16-2011, 09:03 AM
  5. clown shoes and nates.....an observation
    By saltyman in forum Fat bikes
    Last Post: 11-09-2011, 04:23 AM
