Results 1 to 10 of 10
    Reputation: sissypants's Avatar
    Sep 2016
    What carbon forks will fit a Vee Snowshoe 2XL?
    What carbon forks (preferably open mold) can fit the 2XL?
    Is a 3XL coming this winter?
    So much info out there, so scattered over these huge threads, I don't know where to start.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    150 mm=5.9055 inches 2XLs are 5.05 inches on 80mm rims. Some one posted pics of a set on a Farley 5.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Sep 2016
    Quote Originally Posted by RockyJo1 View Post
    Yeah so the hub clears, but the issue is most forks are not built for the sheer volume of a 2XL, which translates into about 3 inches beyond the rim, making the effective diameter almost 32 inches.
    So you're saying a Bontrager Haru fork should fit it?
    Rocking on a Rocky
    Quote Originally Posted by sissypants View Post
    RSD and Salsa also.
    May 2005
    Zero issues tubeless on 90mm rims on Salsa Blackborow
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Bontrager Haru and Lauf, both on 80 - 85mm rims.
    Will also fit on 100mm rims, but with basically zero clearance for wheel/tire runout, mud, slop, etc...
    Quote Originally Posted by alias View Post
    The same for me on 100mm rims.
    Reputation: Blaster182's Avatar
    Oct 2016
    Specialized chissel has gobs of room mounted on 90mm.
    Gotta Ride Fat !!!
    Aug 2016
    Simple china-carbon fat-forks (with 150x15mm axles) from the Ebay also clearly fit 2XL's (on any rims) for just $100.
    Sep 2016
    Quote Originally Posted by Comrade Sukhov View Post
    Thank you, that's what I'm looking for! But not all China forks fit them, in fact I've had two forks which haven't in the past (Angle Sports and another generic).
    Specifically, which open mold forks fit the 2XL? Do you have links and pictures? Thanks a lot! Btw I've seen these as cheap as $60 on Aliexpress special sales.
  1. Vee Snowshoe 2XL tires
    By the_eleven in forum Classifieds
    Last Post: 12-15-2016, 06:07 PM
  2. Cargo rack for Farley 7 with Snowshoe 2XL's
    By headwind in forum Fat bikes
    Last Post: 12-05-2016, 10:37 AM
  3. Replies: 6
    Last Post: 03-31-2016, 09:46 AM
  4. Replies: 4
    Last Post: 02-06-2016, 03:42 PM
  5. Vee Snowshoe 2XL 5.05 Tire on a Moonlander?
    By kaleidopete in forum Fat bikes
    Last Post: 12-31-2015, 03:44 PM
Members who have read this thread: 88
