Results 1 to 16 of 16
    wandering front wheel
    sorry, noob question,
    at slow speeds under power my moonie's front wheel "wanders"
    all over. particularly bothersome when climbing
    i try to shift weight, pedal circles etc but it's really annoying.
    is this just inherent to the bike , from bad technique, or would riser handle bar help?
    dave
    spez roubaix
    fantom cross
    crux
    moonlander
    May 2012
    clown shoe? What tire, what psi?
    Reputation: shiggy's Avatar
    Dec 1998
    Re: wandering front wheel
    Quote Originally Posted by Johanneson View Post
    What terrain?
    mtbtires.com
    Aug 2014
    Too much pression, air down a little.
    mighty sailin' man
    Reputation: MiniTrail's Avatar
    Quote Originally Posted by new8812 View Post
    or too little
    Quote Originally Posted by davidarnott
    wheelies, beyond being the best way over any sort of obstacle, both above or below, are are the steedliest expresstion of joy
    Mar 2012
    Sounds like self steer at low pressure and/or too narrow handle bars.
    Reputation: surlybugger's Avatar
    Jan 2013
    Tire pressure front and rear bias.
    Make sure your front has a bit more air in it, than the back tire. This will:
    1. Throw the center of gravity aft,
    2. lessen the footprint grip on the front.
    The opposite will make the front tire grab the trail surface when it goes of camber opposed to level.
    Oct 2011
    riding a fat tire bike is different.... folks call it self steer, and in my experience I have found some tires appear to be prone more than others.. however,,, it is a much bigger contact patch than you might be used to. slight inputs that are easily corrected on a 2.3 tire, tends to have a more profound effect, start with playing around with air pressure, if you have wider bars toss them on ,, but get 3-4 rides on it.. it takes a bit of getting used to.
    I'm sure this is evident but make sure there aren't any big hops or wobbles in your front tire
    Reputation: gcappy's Avatar
    F
    Quote Originally Posted by twright205 View Post
    This!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    And interestingly, I never feel it on any kind of slippery, icy or snowy surface, only on hard surfaces in non-winter conditions. It is very noticeable though on those hard dry surfaces, the slightest amount of leaning in one direction at lower pressures creates a pretty dramatic tendency for the bike to head in that direction, so often in gentle turns you end up applying opposite pressure. It seems like the more people ride fatbikes in dry conditions at low pressure, the more this becomes an issue. As said above, you get used to it and after a while it's barely noticeable, if at all.
    One of the cool things about a fatbike is how dramatically different they ride in different conditions.
    Jan 2013
    Well said, couldn't agree more. It definitely takes some time to get used to it.
    oops
    moonlander, non offset front end, clownshoes, bud/lou's
    i haven't kept a record how different tire pressures handle.i run pretty low pressures being 160 pounds and with tough trail conditions.
    i do know the steeper the trail and harder i pedal, the more self steer i get. our trails can be like ski trails, single track winding up and down fairly steep terrain, sometimes very steep and unrideable with any snow.
    when i am cranking at my limit climbing a steep turn i can barely keep the front end going where i want it to.
    on flats my weight is pretty forward with salso moto handlebars. not very comfortable on flats but helps keep my front end down on steep trails. i am not sure wider bars will fit between some of the trees.
    i do accept that some of this might be technique/weight shifting, but not all.
    also,does this occur on other bikes?
    dave
    spez roubaix
    fantom cross
    crux
    moonlander
    Nemophilist
    Reputation: TrailMaker's Avatar
    Like you said;
    Noob question.
    It can be one way to suss out your correct tire pressure for conditions, but basically... you'll get used to it.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Sounds like you need to experiment with air pressure to me. As hard as it may be to believe I can generally tell the difference of as little as 1/2 pound especially at lower pressures in the front. At too low pressure up front you will tend to get self steer and I also notice the front end being less responsive, more prone to wander, etc. Add in 1/2-1 pound and the front end is lighter feeling, more responsive, no self steer. Try adding a bit of pressure and figure out the minimum pressure that you can run without experiencing the issues that you are.
    Aug 2014
    As i said, even if i look like a clown, too much pression=not enought traction on front so your tire move around on the ground (following the ground and your input, as not enought traction to stay put), It is not self steering where the bike follow the tire which deform . Air down a bit. ;o)
  1. New front wheel...Stans NO TIRE front wheel???
    By ecub in forum General Discussion
    Last Post: 04-24-2014, 06:49 AM
  2. rear wheel wandering
    By DirtFarmer in forum General Discussion
    Last Post: 06-21-2013, 07:38 AM
  3. Wandering cleat
    By mtdawg in forum General Discussion
    Last Post: 09-10-2012, 02:40 PM
  4. Wandering around Georgian Bay
    By osokolo in forum Eastern Canada
    Last Post: 08-08-2012, 06:36 AM
  5. XTR Chain Wandering
    By gf101 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2012, 05:08 AM
