Shamisen Appreciator
 Originally Posted by TrailMaker
This is interesting;
Laying down a contiguous "bed" for the actual weld to nest/fuse into. Very interesting. I had never considered this, but it makes perfect sense! As he suggests, even with exceptional miters (which are mandatory for this), you are stealing material from both tubes to create this fusion, and necessarily thinning them at a critical juncture. You can do this with some materials and in certain applications and get away with a fusion weld alone (I do it on stainless intercooler/intake hard pipes), but not in this case. It also occurs to me that this fusion step makes it much easier to get visually stunning (and structurally solid) final welds when it is time to add the filler.
Thanks for letting that little trick slip out!
exactly right on all counts but it also gives the joint some thermal stability when you go back to add filler, all but entirely preventing too big a keyhole opening thanks to too much heat.
if you ever get an opportunity to cut up a bike, take it. Specifically, cut through an acute joint to see if there's a gap underneath the weld bead. Ideally, you won't see any air space at all between the two parent tubes. In a lot of cases though, you'll find that the filler rod "bridges" between them, leaving a triangular gap. With something as notch-sensitive as ti, that's bad news bears.
Thanks for the info Sean, sexy lookin' rig you're building there!
 Originally Posted by Drevil
Nothing but the finest for this steed:
- High-rise steel handlebar for strength
- Post Moderne seatpost 26.6mm (might need a shim for 30.9mm)
- Adjustable angle stem for easy adjustments in varying terrain
- Avocet bottle cages, powdercoated pink
- Scott AT-4 grips (made of real Kraton!)
- Jandd pink handlebar bag with WOMBATS patch for power pills and energy snacks
- Avid SD 2.0 cantilever brake levers
- Gorilla brake booster for awesome skids
- Cane Creek handlebar end grip extenders for aero tucks
- Forte Easy Rider saddle in case the 'roids flare up
If Sean doesn't get the cantilever posts on the frame, I'll have to think of something else for #7 and #8.
Haha! Nice! I'm old enough to remember the WOmens' Mountain Biking And Tea Society (WOMBATS). I may have some of that old gear in my box o' parts - probly the pink grips and the SD 2's.
really like the look of this fatbike. got any numbers of that geo? How short did you manage to get the chain stays?
i particularly like the tassels...one in either direction?
What day are we riding?
I see you are going with the dual-seat option, good choice.
Looking forward to the build-up pics.
pug biker
2 seats, 4 tires and half a fork...
pug biker
that's a nice list of parts, Jones bar is supersweet!!!
mount a lefty in the frame is awsome, do you have a technical drawing of those clamps for the lefty ??
miesj
create your own FAT path 2 succes, don't just follow others
hilarious
 Originally Posted by elgordo
hilarious
You forgot the prior post. There'll be 3 seats, 2 bars, and 6 brake levers. This thing is gonna be outta control!
No sir. Hit up Mendon C to the S for the numbers.
I'm still curious how you're going to keep those tassels attached to your nipples for an entire ride.
Different rims front and rear...? Why...?
Because Lefty is offset, and the Marge Lite has an offset spoke bed, is relatively light, and is available now. Why not the same on the back? Because I bought it a little ways back, plus I already know it works well for me.
With nipple clamps, of course.
(Sorry, no pics - you'll have to look that up for yourselves.)
I've just put together a lefty wheel with a 80mm GFS, with non-offset drilling. Theres a fair amount of tension on the right side, with a notable amount less on the left side. But IMHO these tensions are fine. With a BFL mounted (at 18 PSI), the disc mounts of the hub, are 1-2 mm from the floor when laid flat. So I'm not sure you actually need an offset rim to make this work. In fact when I get my Lefty, I fully expect to be able to losen the right nips half a turn, while tensioning the left by the same.
Also the project 321 hub is a lovely component. So well made.
A big boy did it, and ran away.
62*28'
"Direct" from Sean:
A slightly augmented Direct mount standoff
Make it work, then make it pretty.
The standoff wasn't long enough to work with a 100mm shell with a +5mm offset for the rings so...
machined a sleeve to a light press fit, welded around the circumference, turned the weld into a taper, mitered for extra tire clearance, cut a hunk out of a scrap tube, shaped and then fusion welded. Then the weld cap was filed down to make it look as if it were machined from a solid bar.
"Direct" from Sean:
Hoe Lee Cow. That is a pretty part. Function over form always works for this architect!
i didnt fully clock that you were getting front gearage on this beast til i saw these pics...thats super cool...short fat and shifty!//// impressive space management..!
Subscribed.
Sorry I missed this one for so long. Nice bike Drevil.
 Originally Posted by buddhak
After 10 years of almost exclusively riding rigid singlespeeds, I wanted a change. Besides, I have enough fine examples of them.
The sliding drops are insurance, just in case.
By cjsbike in forum Fat Bikes
Last Post: 01-02-2012, 10:49 AM
By dRjOn in forum 29er Bikes
Last Post: 10-07-2011, 07:55 AM
Last Post: 03-31-2011, 08:22 AM
By rockcrusher in forum 29er Bikes
Last Post: 08-27-2010, 02:10 AM
Last Post: 05-15-2010, 07:42 PM
- You may not post replies
- You may not edit your posts
Forum Rules
