Results 1 to 14 of 14
    Vee Rubber Speedster Tirees
    Picked these up today. MSRP $49. They are also known under the Sunlite and Origin8 brands. 26x3.5. I have these mounted on 100mm Fat Sheba rims.
    Vee Rubber Speedster Tirees-snowwhite.jpgVee Rubber Speedster Tirees-comparisontires.jpg
    Where did you get them? Like the whitewalls!
    They're Sunlite Brand Crusher tires. Same thing, wire bead. Get your LBS to get them from J&B importers.
    Human Test Subject
    Reputation: Volsung's Avatar
    Weight, diameter, etc etc?
    Quote Originally Posted by Volsung View Post
    I thought you've met me.
    will rant for food
    Quote Originally Posted by kuan View Post
    heeyoooooooo
    Reputation: dudeist's Avatar
    Apr 2013
    Nice looking tire. Light, inexpensive, smooth rolling and looks like it would grip like mad on smooth pavement. A word of caution, though. Others have reported that tiny pebbles tend to be picked up in them and cause flats or fling back out at You. Maybe need sealant or thick tubes or a liner. And glasses.
    Human Test Subject
    It was dark and I was drunk
    I just rode the KATY trail in Missouri (260 miles) on the Sunlites with no flats. Ran them around 15 PSI. They do kick a few rocks but I ran with fenders in anticipation.
    Jan 2009
    Got my set of Krushers today. Set up with tubes for now - until I tackle my first split tube conversion this weekend. Vee Rubber Speedster Tirees-image.jpg
    Jul 2014
    Quote Originally Posted by shacklyn View Post
    Got my set of Krushers today. Set up with tubes for now - until I tackle my first split tube conversion this weekend. Click image for larger version.
    How do you like those tires? Do they self steer very badly?
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by treym563 View Post
    the beauty of the speedsters is that they're slicks- road tires, if you will. As such, the perform best at higher pressures, between 15-30 psi, where there is absolutely no self steer. running them at anything below 12 psi defeats any advantage that these tires might offer.
    Jul 2014
    The Sunlite Crusher's I've found on various sites are the wire bead, lower TPI than the Speedsters. For $36/ea it's hard to pass up. Would the wire bead Crushers be much worse than the folding bead Speedsters?
    Reputation: Johanneson's Avatar
    May 2012
    For pavement and gravel I would recommend what you are finding, 60 tpi, wire bead. They are heavy but will not blow off your wheel @ 28-30psi. I wouldn't trust a 120tpi or folding bead tire over 15 psi. In another thread, it was reported the higher tpi speedsters would not stay seated @30psi on a 90mm wheel. Not good if blows while you are doing 35mph.
    Anyway, they(sunlites) work great, I have many miles on them.
  1. Vee Rubber Speedster tires
    By zarr in forum Fat bikes
    Last Post: 08-22-2014, 04:23 PM
  2. Schwinn Speedster
    By Tooth McGavin in forum Vintage, Retro, Classic
    Last Post: 04-12-2013, 01:22 PM
  3. Looking for new rubber
    By jsmit450 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 02-26-2013, 12:53 PM
  4. More stolen bikes - black Access XCL & Scott Speedster roadbike
    By Entrenador in forum California - Norcal
    Last Post: 11-09-2012, 07:17 PM
  5. Vee Rubber
    By reformed roadie in forum 27.5
    Last Post: 09-21-2012, 07:16 AM
