Page 2 of 2 FirstFirst 12
Results 51 to 54 of 54
  1. #51
    horseman
    Any Vermonters running them yet? Pretty freakin winter here, eh?!
  2. #52
    Re: Vee Bulldozer in snow?
    Vee Bulldozer in snow?-uploadfromtaptalk1421960836324.jpgI find not much stops my bulldozer other than ice. I find that warmer snow does stick to them but does not hinder traction or rolling. Great tire in the rear not familiar for front as I run a bud.
    Sent from my Z750C using Tapatalk
    2014 Devinci Carbon Troy Xp
    2015 Mongoose Vinson Fat bike
  3. #53
    Dec 2011
    Thought I'd comment on these tires after a season and a half riding them in snow. I've found that in cold, dry snow they work very well. Plenty of traction and float in the rear. The front washes out a bit in dry snow but probably no worse than many other tires. I've found the front works better reversed from the "suggested" direction. In cold snow, you can ride in up to eight inches of the stuff without a problem.
    However, warmer / compacting snow and slush sticks to these tires like glue resulting in a packed tire quickly. Once these tires pack, you have zero traction.
    So, below about 25F these are excellent tires. In the 25F-35F range, a bit terrifying.
    Non-snow upsides worth mentioning: these are very durable, set up easily tubeless and are not expensive. I think they're a pretty good tire.
  4. #54
    May 2015
    I got one good ride with the 4.7 Dozers on 80mm rims on my Alaskan, then the season went to ice.
    On a good trail, they're very capable at 6psi. Plenty of float, and good torque wheelies. I love being hooked up on snow.
    On pavement, they self steer if the pressure is too low. At 13psi, they roll fairly smooth and fast. 8-9 psi is fun on trails.
  1. Replies: 43
    Last Post: 12-09-2015, 03:34 PM
  2. Ground control 4.6 vs Bulldozer 4.7
    By Fat-nor in forum Fat bikes
    Last Post: 08-09-2014, 05:50 AM
  3. Marshall Canyon and Potoato Mountan attacked by bulldozer
    By lewisfoto in forum California - Socal
    Last Post: 07-19-2014, 05:23 PM
  4. Tracks In The Snow _ Thurs Night Ride!__________ did GM get any snow?
    By HomegrownMN in forum Colorado - Front Range
    Last Post: 07-02-2014, 10:08 AM
  5. Replies: 19
    Last Post: 02-14-2013, 10:12 AM
