Results 1 to 12 of 12
    Reputation: drofluf's Avatar
    Dec 2010
    Using Stans With Non Removable Cores
    Getting too many punctures so decided to go down the Stan's in my tubes route. Not quite ready for tubeless yet
    Only problem is that my tubes don't have removable valve (Presta) cores.
    Can I squirt the Stan's through the valve or is that likely to block it?
    If you need me I'll be at the bar
    nothing to see here
    Reputation: Stevob's Avatar
    Just buy some tubeless valves. You won't get stans in though a normal valve. Or are you just planning to run stans in your tubes? There's heaps of tubeless threads in this forum if you need more help.
    I see hills.
    I want to climb them.
    Dec 2010
    Was planning to run the Stan's in my tubes. Will go tubeless at some point but as I'm thinking of a new bike in the autumn was planning the Stan's route as an interim.
    The Surly tubes have removable cores. True, they are heavy, but if you are having flat issues (we have tons of goatheads here in Colorado), thick tubes and tire sealant (slime, gunk, Stan's, whatever) is probably what you want. I would much rather have heavier tires and not have to worry about flats on every ride. Tubeless sounds like it might ultimately be the answer, but I haven't gone there, yet.
    Jun 2012
    the ultralight qtubes have removable cores. However, it only took me about an hour to setup 2 rd's tubeless with gorilla tape with packing foam down the center channel. Cheaper than tubes, and not to much more time invested. The rolling resistance benefit makes this conversion well worth it.
    Mar 2013
    Re: Using Stans With Non Removable Cores
    i got a puncture in my non removable tubes so i got a shringe filled whith stans put it in the thorn hole then patched in with repair kit worked a treat
    Sent from my GT-N7100 using Tapatalk 2
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Quote Originally Posted by stesteste View Post
    There's an option. Just put a hole in your tube, put in the Stans, patch the hole, and you are good for about six months until you have to repeat the process.
    It is easy enough to revove non remevable valve cores. 2 light swipes of a file on the threaded end will let you remove the locknut. then lightly push the core into the valvestem and grab it from the back you. You will have it pinched inside the tube, try not to drop it. shoot in the sealent of your choice and push the core back through and reinstall the nut that you were careful not to lose. pinch the last two threads with a pair of vise grips so the nut doesn't fall off when topping off the tires before a ride.
    Reputation: duggus's Avatar
    Comment deleted.
    ...Be careful what you're looking at because it might be looking back...
    Dec 2010
    Quote Originally Posted by ColoradoClark View Post
    Doh!I didn't realise that! Had the solution all the time
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by c_m_shooter View Post
    I suggest going with this. Even if one looses the core inside the tube, it's moderately easy to find it inside the tube because it's the only thing in the tube that seems like it doesn't belong.
    Reputation: Schott's Avatar
    Nov 2012
    I'm gonna go try this, just because.
  1. Stan's Clogging Valve cores
    By XCFred in forum Wheels and Tires
    Last Post: 09-26-2014, 07:43 AM
  2. Any thoughts on valve stems with removable cores?
    By Jason R in forum 29er Components
    Last Post: 12-23-2012, 08:52 PM
  3. Grove Hard Cores, neon goodness x 2
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 08-26-2011, 11:39 AM
