Results 1 to 6 of 6
    Aug 2013
    upgrading my pugsley to 180mm front brakes
    I'm trying to upgrade my pugsley to 180mm front brakes. I got the new rotors, and the bike shop i talked to ordered me an avid 20IS bracket.
    Well, apparently the bracket isn't the correct one, and my rotor wont fit.
    Can anyone point me to the correct bracket that will let me run my 180 rotors?
    thanks!
    never summer
    Reputation: singlefin's Avatar
    If you have the offset fork then you need a rear brake caliper adapter.
    Fargo Ti + Moonlander + Necro Pug + Nature Boy
    Jan 2013
    20mm IS should be the right one.
    Avid CPS Brake Mount | Chain Reaction Cycles
    Edit: singlefin is right.
    Aug 2013
    Quote Originally Posted by Fatsinglespeeder View Post
    Well, heres the kicker. it seems like i already have the 20IS bracket on the front and rear. I will take some pictures to put up here, but with the 180 rotor it won't fit with the current bracket, and the new bracket is exactly the same as whats on there. I bought the bike used, so maybe someone changed something, but i doubt it. It looks like they never touched the brakes.
    Jan 2013
    Quote Originally Posted by mtn_nut View Post
    If you have the offset fork then you need a 40mm IS bracket in the front to fit a 180 mm rotor.
    Forks | Parts and Accessories | Surly Bikes
    never summer
    Yep...
    It's this part: http://www.artscyclery.com/descpage-AVAIS20018K.html
  1. Pugsley and 180mm rotors - no match?
    By hssp in forum Fat bikes
    Last Post: 07-22-2013, 12:58 AM
  2. Hope brakes and 180mm rotor
    By Dictatorsaurus in forum Brake Time
    Last Post: 07-17-2013, 05:38 AM
  3. Upgrading from 160mm to 180mm rotor
    By M-80 Rider in forum Brake Time
    Last Post: 03-12-2012, 07:20 PM
  4. Replies: 3
    Last Post: 02-12-2012, 04:24 PM
  5. Upgrading from 160mm to 180mm
    By indigo_falconm40 in forum Brake Time
    Last Post: 02-01-2012, 09:47 PM
