Page 1 of 2 12 LastLast
Results 1 to 100 of 110
    Unvailing the King of Fat Bike Design Puzzle
    Getting two things out of the way first.
    The rear offset design of the Pugs and Moonlander...I have never been able to get my head around the reason outside of the ability to swap wheels front and rear, and it is what was handy at the time.
    If one desires to run a 29er wheelset on a fat bike, it always stuck in my mind that handling would suffer over a purpose built 29er with the same geo, due to the differences in dropout width.
    To make my point with an extreme example...lets increase the rear OLD to 10 feet. The bike would then be neigh impossible to steer...correct? It would take more input into the lean to get the same otherwise response?
    Also with a 135mm OLD up front, all the adjustments in the world to the head angle or offset would be in vain. The only saving grace would be to add weight over the front axle...a lot?
    What I am driving at is...is there something to be lost with the coming advent of 186/190 OLDs? If the above logic holds water something has to give.
    That being the case; how do you design around this...enter the Pugs and Moonlander?
    If the above logic is true is it also true that an offset rear dropout...to the right...also decreases the lean effort to the left over the right? But then comes this puzzle...it is naturally easier to lean left over right, so how are we to know just what is in play? But it also seems logical that there has to be an over riding truth regardless of what our brain says.
    What if in an offset design the drive side was moved to the left...? The larger question is how noticeable would any of this be?
    If all of the above is true does this not increase the value of an offset rear in our goal to run wider rubber?
    What say ye...to my over thinking?
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    Why would dropout width make handling worse? If anything it would make handling better, due to stiffness.
    Why would dropout width affect head angle and trail? the width of the dropouts affects neither the trail or head angle, where as, the trail and head angle do affect each other when you change one of them.
    Are you sure you're not high? I mean, why is it naturally easier to lean left than right? That's nonsense, everyone is different.
    Mar 2011
    Quote Originally Posted by Sand Rat View Post
    ...you are over thinking.
    Reputation: vaultbrad's Avatar
    Oct 2007
    I think that either, I am confused, or you are confused. Could you perhaps clarify your thoughts to alleviate my confusion? I don't see any reason that wide hubs or offset design would affect the handling. The centreline of the wheel is still in line with the centreline of the bike.
    Bikes of yore tried drive trains on the left and it works jsut fine, but the right side drive train became standard. I don't think that any of that makes any real difference to riding. I am more comfortable leaning left than right, but that is individual. Some will be more comfortable to the right. But even still the difference for me is negligible.
    I'm still confused
    Dec 2005
    Quote Originally Posted by stoney bones View Post
    +1
    Hub width does not affect handling except where it might increase weight or stiffness. The width itself is not part of the handling or fit geometry.
    Offset vs symmetric also does not affect handling beyond what effect it might have on wheel stiffness.
    A fatty 29er may suffer some compared to a designed 29er but not because of the hub width. It is because of compromises needed to clear the fat tires. Particularly using 100mm bottom bracket and extra wide chain stays. But these are mostly ergonomic issues not handling issues.
    Building a 29er wheel on an offset hub does involve some compromises because the wheel must be dished to accommodate the offset. The Moonlander 28mm offset is probably beyond what you can do with 29er rim.
    Craig
    Reputation: Velobike's Avatar
    Important fact about offset:
    The wheels are still in line. *
    There is a growing myth perpetuated by internet experts that there is a difference in handling with the Pug because of the offset. There is not. The wheels are not offset.
    Only the chainstays and the hub are offset.
    The tyre and rim are centred with the bike.
    There is no effect on the handling from the offset.
    (*Edit: sorry about the emphasis, but I have seen posts in various threads and forums about this offset "problem" a number of times and I think it needs to be laid to rest)
    Latitude: 57º36' Highlands, Scotland
    Nov 2007
    The ability to swap front and rear wheels is not the main reason for the offset design. Rather, it's to allow the chain to clear the tire with a standard 135mm rear hub. Because the hub is not centered in relation to the rim, the asymmetrical frame becomes necessary to center the rim in relation to the main tubes of the frame (and the rider). An asymmetrical fork and offset front wheel are not required at all.
    Oct 2012
    To the OP: From what I gather of your overall understanding of bicycle dynamics, you should just revert to listening to the advice of those with experience, and when it comes to concepts of offsets, and asymmetrical designs, just trust us all that all of the designs out there work great for what the manufacturers are suggesting they be used for.
    as far as finding the right bike for what you want to do, I would suggest just stating what you want to do with the next bike you might get in a thread, and try the bikes suggested on a trail if possible, and not worry at all about what numbers are involved in the geometry, or what the bike looks like.
    will rant for food
    The real puzzle to me is how to cope with increasingly fat tires, feet, cranks, and chainrings all sharing the same real estate.
    What you get from symmetry is some weight optimization, at the expense of narrower range of component choices.
    People are happily riding Lefty forks, which are the definition of offset and asymmetrical. And those have moving parts.
    You get what Velobike emphasized though, yeah? The rubber meets surface directly under your butt.
    Oct 2012
    On the idea of wider hubs affecting handling, iwould say that a 29er wheelset built with 170mm, and 135mm hubs would handle better due to stronger stiffer wheels, and that for heavier stronger riders, I would suggest them even on a 29er without fat tires. I have destroyed a 100mm hub 29er wheel from riding too fast through a turn without even hitting anything but smooth dirt.
    I think 135mm front forks should be specified on 29ers for clydesdale type riders.
    and as far as 17.5mm offset 135mm 29er wheels, a rear wheel probably has less dish(more even spoke tension) than a standard 29er geared rear wheel, as the rim is dished to the opposite side from normal.
    Post...go to work...return...check in...Thanks Guys!
    Not sure if my failure to follow some is due to them not following...me. Perhaps due to the limits of the internet...that sounds safe!
    Let me try it from a different angle. Longer trail...does what? A longer stem...does what?
    A longer bar does...what? Why would not a wider (longer) axle have the same effect?
    I get that regardless of the design, the wheels are by necessity centerlined. The wheel, the contact patch is like a fulcrum point for the axle. The Axle is like a plank on a teeter totter, or a lever if you will. In effect, if you try to do a one man balance act on a teeter totter, say your feet are fixed equal distant from the fulcrum point.
    The wider the symmetrical dropout, the farther apart your feet. An offset design affords a closer stance, at the expense of being asymmetrical to the fulcrum point. This poses an adjustment in the balance act, but I see it as being neutral overall in affect, just different.
    If 6" tires are produced, what are we looking at...206 hubs and 150's with 28mm offset? It is just that it boggles my mind to think that hub width can change in a vacuum with regards to feel of handling.
    My aim in this thread is to explore, what ever the facts are is what they are, understanding the forces at work better is the goal. Which brought about the question; With hub widths at an extreme, would it be a mistake to believe that a 29er set would prove just as satisfactory as in a frameset built for 4" tires?
    As for the left turning thing...oval track racers go in what direction? Why? If by default of choice, I submit there is a reason behind that choice by default though unstated and unrecognized.
    And no offence meant...I don't trust anyone who says..."Trust Me" I am not concerned with adhering to convention if I see it as to my advantage to buck it..."Trust Me" LOL
    Please feel free to jump in with more comments.
    Dec 2005
    Re: Unvailing the King of Fat Bike Design Puzzle
    A wider hub does not necessitate any geometry or ergo changes.
    If tires get much wider you will need wider bottom bracket which will affect ergos.
    135 Offset frames and 170 frames use the same BB size and usually same chain stay length.
    Craig
    Sent from my SCH-I500 using Tapatalk 2
    Reputation: smithcreek's Avatar
    Nov 2012
    The Dude abides.
    Dec 2005
    If it helps think of bicycle geometry as 2d. That is the only dimensions that affect handling.
    The axle is just a point on the 2 D plane. Width does not matter.
    It may affect wheel and frame stiffness.
    There are a lot of variables affecting fatbike handling.
    Skinny bikes don't have so much variation in tyre size, tyre pressures and rim size. On a fatbike, change just one of those factors and you have a different handling bike.
    I'm not keen on the current crop of 135mm forks. We're still using axles with a diameter designed for the size of tyres they had in the 1890s, and yet a fatbike has tyres the size of a motorbike with the resultant feedback into the frame. I would like to see large diameter axles on fat forks and until then I'll stick to as narrow as possible, ie 100mm.
    The most precise handling I've found is when I had a very steep head angle which is contrary to the more accepted view, but that was only tested with a narrow range of tyres and rims.
    I suspect the most important factor may not be trail or head angle but the combination of flop and the tyre profile (ie how rim size affects tyre shape). I'll probably get round to testing that some time this year.
    Mar 2012
    Topicstarter has a point, but there are some things that don't make sense
    There is such a thing as stiffness of the frame!
    A wider beam is a stiffer (and stronger) beam unless you use a stronger or more material!
    So, much less frame torsion when you pedal, but also in corners etc.
    Quote Originally Posted by Velobike View Post
    Bar width and stem length can be tweaked to adjust steering feel...are not contact patch width and axle length much the same? A bike is also steered through the seat no?
    A concern that I have is that as axle width at the rear is increased while the front remains constant is that there could be a pushing effect generated on the front which could be adverse.
    I do not foresee any proof for my concerns forthcoming unless an engineer can bring clarity. But until then...forewarned is fore armed? If any possible downside is outweighed by whatever upside for a given individual...then go for it...you now have the tools to make a better choice?
    Take Beth...with her experience with her mishaps...what I took away for myself is that at my age, it might be best to stick to fat tires alone. Going from fat to skinny, opens myself up to overlooking possible hazards due to a change in tire width. It could end my riding days at worse and in any event it now takes longer to recover, the risks outweigh the benefits.
    So that's where I am at with all of this...thanks to all for being there to prod me on.
    Bar width and stem length can be tweaked to adjust steering feel...are not contact patch width and axle length much the same? A bike is also steered through the seat no?...
    Yes, you can change the feel and a good setup can mask imperfect geometry up to a point. The human body is incredibly adaptable and with a bit of practise you can ride what seemed unrideable. Which is why we can have different fashions in bike configuration and geometry from decade to decade instead of an absolute fixed design. For an example find an old upright bike with rod brakes and try riding it on singletrack. Feels all wrong, but that's what our ancestors were on 100 years ago and riding them around the world on dirt roads.
    Nemophilist
    Reputation: TrailMaker's Avatar
    There is merit in the OP, if not ultimate clarity. It does do good to reflect on the idea offered, if not the surmise, and to look further for answers.
    Skinny bikes don't have so much variation in tyre size, tyre pressures and rim size. On a fatbike, change just one of those factors and you have a different handling bike. I suspect the most important factor may not be trail or head angle but the combination of flop and the tyre profile (ie how rim size affects tyre shape). I'll probably get round to testing that some time this year.
    I am thinking that I agree. I noted a distinct self steer on my first Fatty. This was something I have not really encountered before, at least to this degree. I was trying to figure out what exactly was causing it, especially since I was the one building the frames, and as such, always seeking to improve the "product." My own thinking and experience since, added to those of others on this forum, has lead me to believe that the tire is the single largest factor in handling.
    I have very recently come clear to the notion that some of what I was feeling was simple gyroscopic effect, and it has become quite noticeable to me now that I have separated it from other phenomena. The simple fact that you have all that added mass out there spinning about its axis explains that neatly.
    So too do I believe that the width of the tire is a larger lever acting upon the steering, in a radial sense. The extra width of the tire gives surface grip far outside the width of a normal MTB tire, and my thinking is that this is also responsible for some of the pull felt at the bar. Add to that the notion that the tire certainly is deforming away from the centerline of the wheel under these loads (see attached), and it seems that the effect would be further magnified.
    Tire pressure of course has something to do with that, but in my experience I'm thinking that takes a back seat to tread design. It has been noted by many, including myself, that the HuDu is very prone to self steer, where you do not necessarily hear that about the Nate; a tire with a decidedly more aggressive tread. This mirrors my experience.
    Are you taking exception based on perceived structural weakness, or do you feel that you can actually sense too much flex from the wider hubs? I also am not overly enthused by not having the option of some sort of through axle for the front, and if I were smart enough to figure out how to get one of these new 12mm T/A rear hubs on the front, I'd do it. No, I've never broken a skewer, but at the same time, it sure SEEMS impossibly frail.
    Attached Thumbnails Attached Thumbnails Unvailing the King of Fat Bike Design Puzzle-tirewidthcomparison.jpg
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    I think one of your mistakes is to think that the fulcrum of your teeter totter moves over as the hub is offset to the side. The balance point or fulcrum is the tire contact to the ground. Your connection is your feet on the pedals. The connection between those two points does not matter as long as it is rigid. Obviously if the connecting structure is made super wide so it hits the ground as you lean that would be a problem and if it was offset way to one side so there was lots more mass on one side that could be a problem. At the sizes we are talking about between a 29er wheel and a fat wheel it does not matter.
    Latitude 61
    Nov 2008
    Keeping all other variables the same, axle width has no affect on handling, other than making the wheel build stiffer and possibly improving handling.
    You do have to be careful about helmet width though. Wider helmet will make your steering slower.
    Nov 2008
    You can't throw axle length in with the stem or bar length changes. By changing bar or stem length you are changing the distance from the axis of rotation which affects leverage and handling. No matter how wide the axle is, as long as the wheel is still centered there is no change about the axis of rotation.
    This seems like a troll effort. Fun reading,though!
    Sent from my LG-E970 using Tapatalk 2
    will rant for food
    Quote Originally Posted by tfinator View Post
    After looking at Sand Rat's post history, I disagree.
    Quote Originally Posted by TrailMaker View Post
    ...Are you taking exception based on perceived structural weakness, or do you feel that you can actually sense too much flex from the wider hubs?...
    I've tried 3 different 135mm forks. On each of them heavy braking produced an element of instability which was not obvious on the 100mm fork. The best description I can give of it was that I was feeling squirm.
    I haven't done any measurement comparison of the actual (if any) flex for the various forks/wheel combinations, so this is just an opinion. If someone was to do this it would be an interesting comparison.
    The likes of a truss fork may compensate for inadequacies in the axle.
    In the meantime I'll stick to narrow OLDs if possible.
    This seems like a troll effort. Fun reading,though!...
    No, it's a point worth raising. Sand rat likes to philosophise.
    Sorry, I didn't look at post history, but comparing the width of a hub to the length of a stem... apples to oranges, ya know?
    Philosophize on!
    Oct 2012
    I think it may help to just consider that in the see-saw comparison, the plank changes angle with respect to the person standing on it.
    On a bicycle, even with suspension, the axles always stay square to the bike, save for a little flex in the frame, and despite Velobikes observation about forks, which I will talk about in a second, usually stiffness of the frame is not significantly compromised by widening axles to the point where handling is affected.
    If you assume the frame is sufficiently stiff, when you look at bicycle handling, the only things moving in relation to each other are the handlebars, stem, fork, and front wheel. when you put a rider on it, there is also the change in center of mass based on where the rider is leaning. The width of the pedals(and their minimum hieght) is a consideration as far as lean angle while pedaling, and if the rider is standing, the amount of leverage you have to lean to one side of the bike, but the width of the axles does not play a role.
    the rider and his weight changing location to change the center of mass is not essential to the handling or stability of a bike. Most riders do not realize it, but when you are leaning the bike into a turn, you are doing so with the steering input, not by leaning your body. When a rider initiates a turn, he initialy turns the bars away from the turn, which causes the bike to lean into the turn, then the rider turns the front wheel back toward the turn to keep the movement such that the angular acceleration of the turn keeps the leaning bike from falling over. Then to straighten out, he turns sharper into the turn, which brings the bike upright, while straightening out the front wheel again to resume straightline motion. Trail and head angle are what make this happen. The whole process seems counter intuitive. No one who learns to ride a bike even realizes what motions are doing what, it just becomes part of your body's natural instincts to where you think you are actually leaning the bike over, not steering it to do so.
    For proof, look at a remote control motorcycle. It has no moving mass to simulate a rider leaning.
    for further information on this subject I recommend reading the wikipedia article:Bicycle and motorcycle geometry - Wikipedia, the free encyclopedia
    To Velobike: do you think the weakness of the 135mm forks you have used is due to the distance of the braking surface from the center of the forks causing a greater leverage for twisting. A through axle would definitely help some in this respect, and a double crown even more so. Or you could run two front brakes.
    I do notice a lot of flex with braking on the Onone fat front fork, but I haven't noticed anything when not looking directly at it, and while I do watch it it seems to stay straight, with the non brake side flexing just as much.
    As to forces other than braking, twisting forces should be less with the wider axle, since you have less of a leverage difference between the tire radius and the hub width, which should make up for any additional flex at the wider crown area, whic is going to be more flexible on a fat fork, no matte what the axle width.
    For those who struggle with trying to understand my points, and me yours...I did rather poorly in Physics class... Keep posting...maybe...just maybe...
    VB may have a little trouble wading through my writings also...but he understands ME quite well...so thanks to him and Drew.
    BY the way VB, given any thought to the suggestion by CK of a Blog?
    Sasquatch141...Your comment about helmet size...larger auto adjusts everything to just perfect!
    Nothing's Impossible...Was that you at a previous UK gathering? Going to make the upcoming one? I dare say that you have a brain worth picking when it comes to balance and control on a bicycle.
    Sryanak...With the teeter totter idea and my feet. My feet were fixed and representing the axle end points. In the front, steering takes place in a horizontal plane, in the rear, on a vertical plane through the seat, was the idea I was trying to convey. Therefore my thought that axle width like bar width does matter. The handle bar is nothing more than an indirect connection to the front axle. In the rear, the seat is your connection to the rear axle, but if standing, then the pedals are that connection as you say.
    I keep thinking...axle length...range of motion...longer means stable, slower = an affect that has be produce an effect. For every action there is an opposite and equal reaction.
    But if your head hurts like mine...don't worry about me, this is not life or death.
    Not sure if that makes things better or worse, like I say...Physics not my strong suit. If you can say we agree, great, but I remain unsure.
    So post away...even if I should go quiet on this thread for awhile, know and rest assured that I am reading and tucking away your points/thoughts until such time as I can assemble them into a better understanding. Who knows...sometimes I find that someone says something just a little different at the right time...and things just fall into place.
    Who knows, TrailMaker may be helped more than I by something said.
    Quote Originally Posted by autodoctor911 View Post
    To Velobike: do you think the weakness of the 135mm forks you have used is due to the distance of the braking surface from the center of the forks causing a greater leverage for twisting. A through axle would definitely help some in this respect, and a double crown even more so. Or you could run two front brakes...
    Yes, that's my conclusion.
    I thought about the 2 front brakes - gave it all of 10 seconds. Too much faff for me.
    Would like to hear from those up in Alaska who are working on the development of the reported 186/190 standards to see what their thoughts are.
    Oct 2012
    I just did another fork flex test on the Fatty fork by holding the brake locked and pushing the bike forward, while My assistant holds a straight edge on the fork legs and measures the deflection, and I can't get the left(brake) side to flex any more than the right side. they are both deflecting about a half inch when I use one foot on a pedal to hold the rear heel down, and the other to push forward (backwards against the ground), and both hands on the bars with only the front brake applied at full squeeze.
    You know, while riding motorcycles I just realized that my attention has never been on what the bars and front wheel are doing, my attention was on the more drastic shift of body weight...on the lean. There is also the power distraction a motorcycle has over a bicycle. As a result when on a bicycle, less attention was/is paid.
    I think you have said more in a complete manner that gives it to me in bite sizes. Thanks.
    Oct 2012
    thanks to drew and velo, who made me realize it might not be hopeless to try and explain some of the dynamics to you.
    From the first post I thought you might not be able to grasp it.
    The flaw in this logic is you aren't standing on the ends of the axle. If your input was just to the axle ends then yes you have to move the end of a longer axle more to move the wheel. However they are rigidly connected to the rest of the frame. No matter how wide the rear hub move the head tube one degree and the rear tire moves the same ratio of that amount.
    Or to put another spin on it. Think about it this way. On an offset frame one end of the axle is closer to the centerline then the other. If a wider bike behaved differently than a narrower bike then the two halves of an offset frame would behave differently relative to each other and the bike would have to explode. Since they are all rigidly connected the short end gets a bit less input and gives back a bit less and the long end gets a bit more and gives back a bit more and by the time you get to the centerline of the bike over the tire the input is the same from both sides. I wish I could explain this better.
    Latitude 61
    Nemophilist
    So...
    You are feeling a radial rotation without bar movement? Squirm would be a good descriptor there. Hmmm... Perhaps I have not refined my experience that far, but I can't say I've notice that. I definitely notice a fair amount of flex under heavy braking, as you say. Since I am a biggun and use an 8" rotor, it is pronounced. What I'm trying to decide is if the fork is exacerbating the brake shudder, both audibly and tactiley. Perhaps even causing it, or perhaps more accurately allowing it to occur.
    You feel the narrower axle width is more stable? Hmmm...
    Quote Originally Posted by sryanak View Post
    The part about each side behaving differently I understood, but I was failing to grasp what that would result in...something broken! So of course it follows my supposed premise was wrong.
    Thanks to Autodoctor, what he said, jarred my stuck in the rut thinking. I was going through all sorts of injustice to logic. In time, I shall go over all that has been said by yourself and others and attempt to untwist things. But your above statement drove the nail home, sealed the coffin on a misguided concept.
    Thank you for your efforts.
    Mike
    Oct 2012
    For the most part, on a bicycle, or motorcycle the body weight does not shift at all. It's tilted in perfect harmony with the bike due to the forces created by turning the front wheel. Just watch someone else riding right in front of you, and follow them through a turn. You will notice that their spine stays pretty straight with respect to the bicycle. It does not feel so to the rider because the feel you have for riding balance, is intertwined with the movement of the bike. Usually it is learned at a young age, which makes the motions even more embedded into your muscle memory.
    If you were to lean to the left with your body while holding the bars straight, you would actually lean the bike to the right, making the bike want to turn right. You can test this by riding the bike with no hands, or better yet, push the bike with your hand on the seat. the bike goes the direction the seat goes, which is opposite the way your upper body leans.
    Usually the only time you lean very much to the side on a bicycle is at slower speeds to turn a tighter radius, and even then, it's not much movement.
    On a motorcycle though, at higher cornering speeds, when the limit of the lean angle is reached due to ground clearance, the rider can move to the inside of the turn to balance the bike as lateral forces try to tip the bike over to the outside of the turn(high siding)
    So...
    Are you saying that the shudder is at the pads or in the fork? My impulse is to suggest that there may be a cause and effect cycle going on. The fork flexes, springs back, and until you release the pressure, the cycle repeats?
    [QUOTE=autodoctor911;10333541]For the most part, on a bicycle, or motorcycle the body weight does not shift at all. It's tilted in perfect harmony with the bike due to the forces created by turning the front wheel. Just watch someone else riding right in front of you, and follow them through a turn. You will notice that their spine stays pretty straight with respect to the bicycle. It does not feel so to the rider because the feel you have for riding balance, is intertwined with the movement of the bike. Usually it is learned at a young age, which makes the motions even more embedded into your muscle memory.
    As you are pointing out, my use of descriptions are misplaced, and you give the reason. Perception alone can not be used to define reality, but we tend to govern our lives through it.
    Nemophilist
    Hmmmm....
    I have to disagree with a lot of this. Not all, but a lot. The dynamics of this are extremely complex and variable, and hard to elucidate, and the actions of the rider are extremely subtle. Perhaps not even visible in your following-rider scenario, and that is all it takes to initiate a turn on a two wheeled vehicle much of the time. The amount of force necessary to initiate a turn varies depending on the mass and speed of the vehicle in question, and very likely stays proportional to that, but it takes very little to tip a two wheeled conveyance to one side.
    So, to turn a bike right, you are saying the rider leans left? I don't think anyone rides like that. A bike goes where the mass goes. If you had no steering, the only way to change direction would be to lean in the direction you wanted to go. Obviously, with no steering, at that point you would have very little control of the change in direction, and would fall to the ground on the side you leaned to. Steering is a wonderful thing.
    That's a start.
    Hmmmm....
    That's a start.
    I think AutoDoc misspoke a little, while trying to make a point, he knows that no one does ride as per his example.
    If one were to lean left while keeping the bars straight, the bike mass and rider mass are then not in the same plane, the mass of the bike is at the riders right, but the direction in which the bike goes, it seems to me, to be governed by what mass is able to exert the greater force upon the direction of travel. If bike mass is greater, and rider mass so light, the bike will remain in the same direction of travel, but such not being the case, the bike follows/turns with the mass of the rider with the bars remaining straight.
    So I would agree with you.
    Nemophilist
    Further;
    If it is a lean-initiated turn, which most turns are - and again it takes an almost imperceptible amount to accomplish this most of the time - the rider then "catches" the tip-in of the bike by steering. When the front wheel is steered enough - and a turn radius of proper length is achieved - that steering input counters the tip in. Steer too little and the tip-in continues to whatever varying degree. Steer too much, and the bike either straightens to some degree or the front wheel folds under and you lose some skin! We learn - as The Doc suggests - from experience and repetition until it becomes an ingrained proportion that we manage without even thinking about it.
    The thing that makes this really tricky is there is an infinitely variable degree to which each action effects the outcome. This makes it very hard to explain it in absolute terms.
    Nemophilist
    Ooops, forgot;
    I think it is clear that the brake is initiating the issue. I am wondering if the fork is exacerbating it. I believe that it likely is. I do not have this problem with my suspended bikes, but both of my Fatties with Enable forks do it. One bike each of both suspended and Fat bikes share the same brake system; two with Hayes Nine, and two with Strokers.
    One factor I only thought about today - strangely while cycling a 60 year old bike up a really steep hill.
    The 135mm hub I used may not have as good an axle as the 100mm.
    That's another potential explanation.
    Oct 2012
    Further;
    I beg to differ. When we "lean" in to initiate a turn, we are leaning with the steering. Yes, you apply more weight to the hand on the inside of the turn, but it is the slight turn of the handlebars in the opposite direction when you do so that leans the bike and yourself over. You are right that it is a very subtle action, but it is the input to the bars that initiates the turn in most cases. If you were to initiate a turn by leaning your body, the bike will definitely move to lean the opposite direction from your body more than you think.
    Steering input is what keeps the bike balanced under you in the first place. A bike with no steering us unrideable.
    try focusing on your stem when standing up and riding(in a safe wide open place), then try to lean into a turn and not let the stem cross the centerline away from the turn.
    You can do it, but you have to lean the bike into the turn, while your body stays upright, and even then, the steering is actually crossing the centerline slightly, or you would fall over.
    Now, try the same thing while seated. You will find that if you cannot turn the front wheel to the right, for example, it is impossible to turn left, or even to go straight, and not fall over for that matter.
    Yes, this sounds wrong. It is not what it feels like you are doing when you lean a 2 wheeled vehicle over, but if you pay close attention to the angle of the stem when initiating a turn, you can observe how necessary it is to steer away from a turn in order to lean into it.
    Nemophilist
    Hey;
    I need to make sure I am reading you correctly. Are you saying that turns are initiated by steering away from the intended direction, causing the tip in, and then caught with the correct amount of steering into the turn?
    Oct 2012
    yes
    That is an excellent way of stating it. brief, yet fully descriptive of the process.
    Nemophilist
    OK;
    Well, I do not really believe that is the way most people initiate a turn on a bike. I believe it is done with a very subtle shift of the hips. I just went out in the street and tried it all, just to make sure. How many people really think about it... really? I had to make sure... again. I don't turn a bike that way. I turn by leaning and then catching the fall with the bars.
    Do I believe a turn CAN be initiated by steering away? Yes. It is a concept I am very familiar with from years of track driving and instructing in cars. It is a very common practice there, called "shaking" the car for those not aware of it, and comes in very handy when you have a car that is reluctant to set the front end into a turn for whatever varying reason. In Rallying, it is virtually the ONLY way to make a car pivot around a turn, particularly in low grip or super tight radius situations. Hence the name, "Rally Turn."
    However, in bikes there is no CG (center of gravity) in the horizontal plane effecting how they turn. There is no need to swing the mass of the conveyance around this CG to get it to rotate. There is no rotation at all. There is simply vertical fall and catch. I can indeed shake the bike and make it turn, but it is really quite unnatural to me. If there is any slight turn of the front wheel away from the turn, I think it is merely sympathetic.
    That's my take on it.
    Oct 2012
    "Sympathetic"? Did you try to turn without doing it?
    It's not a matter of personal preference, it's the way a two wheeled vehicle behaves.
    I also race cars, and the "shaking" you refer to has nothing to do with what is going on on a bicycle, But moving the Cog in the horizontal plane is quite important in turning a 2 wheeler. when you initiate the turn by turning the front wheel slightly away, the Cog being above the contact patch of the front tire is what causes the bike and rider to lean over with the force of inertia acting as a lever against the force vector created by the front tire. once the mass is leaning over, the front tire must change direction to keep the rider and bike upright. this happens constantly while riding straight to keep you upright.
    when turning, you are letting that slight steering angle back and forth go unbalanced to one side, just long enough to lean over, then you have to steer more drastically to catch it from falling over, at which point you are leaned over with that Cog being accelerated to the side with enough force to balance the pull of the earth.
    Notice that to resume riding stright, you must turn the front wheel more sharply into the turn to bring you and the bike upright. it is basically the same thing you did to start the turn in reverse.
    You don't have to be convinced by me or trust me. To verify this you can just read through the article I referenced earlier, or better yet this one:
    Bicycle and motorcycle dynamics - Wikipedia, the free encyclopedia
    Oct 2012
    see also:
    Countersteering - Wikipedia, the free encyclopedia
    quotes from article above:
    At low speeds countersteering is equally necessary, but the countersteering is then so subtle that it is hidden by the continuous corrections that are made in balancing the bike, often falling below a just noticeable difference or threshold of perception of the rider. Countersteering at low speed may be further concealed by the ensuing much larger steering angle possible in the direction of the turn.
    Unthinking behavior
    Countersteering is indispensable for bike steering. Most people are not aware that they employ countersteering when riding their bike any more than they are aware of the physics of walking. They have learned to apply the required countersteering without thinking.
    As is well known in bicycle racing, the countersteering phenomenon becomes evident when there is an obstacle preventing the wheel from countersteering (e.g., when closely overlapping wheels or riding very close to a curb). In these situations, the way to initiate a turn with the handlebars away from the obstacle is to countersteer towards obstacle to avoid crashing into it.[13] Lack of understanding of this principle leads to accidents in novice bicycle races.
    Motorcycles
    Even more so than on a bicycle, mastering the technique of consciously countersteering is essential for safe motorcycle riding, and as a result is a part of the safe riding courses run by the Motorcycle Safety Foundation and the Canada Safety Council. At the higher speeds that motorcycles commonly attain, it becomes increasingly impractical to steer by taking advantage of the minute and random corrections needed to maintain balance.
    Much of the art of motorcycle cornering is learning how to effectively "push" the grips into corners and how to maintain proper lean angles through the turn. When the need for a quick swerve to one side suddenly arises in an emergency, it is essential to know, through prior practice, that the handlebars must be deliberately pressed away on that side instead of being pulled. Many accidents result when otherwise experienced riders who have never carefully developed this skill encounter an unexpected obstacle.
    To encourage an understanding of the phenomenon of countersteering, the phrase positive steering is sometimes used,[18][19] and is summed up in a simplified way as "Push the right-hand bar to steer right; push the left-hand bar to steer left".
    Oct 2012
    I think the way the countersteering is so subtle, and ingrained is what makes it difficult to transition from an upright position to a recumbent, or even a cruiser style motorcycle with forward controls and tall handlebars, especially if the grips are behind the steering axis. It still usually only takes a few minutes of riding in a straight line to relearn the balance from the new position, and be able to turn. Then it is a bit more obvious how you are doing it from that relaxed position. Then as you become used to balancing with the steering like that, you forget about what your hands are doing, and focus on the balance directly, which makes it seem like you are shifting your weight with some other muscle force.
    I think a lot of times, we might tense up some of the muscles in our torso unnecessarily when turning, thinking it's doing the leaning even when all of the gravitational forces acting on our bodies are pushing us straight down into the seat.
    This effort is probably wasted energy that could be used for forward propulsion on a bicycle, or just conserved to reduce fatigue on a motorcycle. Really, the only time you need to use any muscles other than your arms to turn is when you are going through a turn so fast that you are scraping the ground and still headed to the edge of the track, road, or whatever ridable surface you are on.
    It,s pretty hard to turn fast enough on a bicycle to scrape the ground though, unless you have the wrong pedal down for some reason.
    I guess if you are road racing in a time trial or something, you could be pedaling hard through a turn that is just a bit too sharp to get enough lean angle while pedaling, and some body lean into the turn would give you a bit more pedaling time.
    All of this back and forth makes for interesting reading, I find myself scratching my head often though.
    In the above Wiki link I read...Shifting body weight on a heavy motorcycle is less effective.
    As my experience of such are Harleys and BMWs something made a click as to how I ride.
    Take a left turn as an example...I slide my shoulder to the left followed by my hips, I am then into a fall. To save myself from the fall, I pull myself up with my right hand with the left following along, at the same time as the pull, I twist the throttle. Both the fall and the powering out while pulling myself out of it is a source of pleasure.
    I would not describe it as pushing on the left to go right to get out of the fall. Though in fact both produce the same result.
    During a motorcycle safety class when practicing counter steering everything was a struggle to do, it was counter to my practice of accomplishing the same thing and how I would attempt to explain it to another on how to take corner, I would not even use the term, as the term itself is a point of confusion.
    Let me talk about something quite different in an effort to explain the back and forth, and then hopefully bring it into play.
    Many years ago, I read (Psychology Today?) about a study done on how right handed people arrive at solutions versus left handed people. As I remember, they each arrive at the same result but through different methods, with each group using different sides of the brain from the other.
    Therefore, it would follow that each would use a different description in their explanation. It also follows that within each group, the differences expressed would be minor compared the differences between the groups.
    So in effect the result being produced by the back and forth is separating the players into one group or another, or they are discussing their minor differences within the same group.
    Me...? While I consider my self right handed, there are some things that I can only do left handed. So...taking the study in hand...I turn to Philosophy to keep my balance in the world?
    Today while riding my bicycle I did some playing around with the concepts.
    If riding too close to a curb on the right, to get away from it I fall into curb side. In doing so, my left hand is pushing outward, steering me away from the curb. This is seemingly counter the former explanation on how I take a corner. It easily falls into a description of counter steering, and here, I have no trouble using the term at all. So why then the 'battle' with the term?
    Enter the study?
    Have I been successful in providing any help?
    Are TrailMaker and AutoDoctor in the same or different groups? Is it possible to ascertain which is the dominate hand of the other if one is known?
    And into which group would you see me most favoring?
    How about those of you who are just on the sidelines...reading?
    I don't propose that I myself, am able to do so though...there may be insufficient data and/or my knowledge falls too short.
    Oct 2012
    well, if Trailmaker is a lefty, the study holds true in this case,
    but I have certainly seen people of either handedness exhibit two sides of similar such discussions.
    I think the reason that the "conscious countersteering" that is so hard to learn for pretty much everybody is necessary in certain situations on bicycles as well as motorcycles. It is really the same motion you are doing when you lean, but it is unnatural, because you have to countersteer more drastically than the natural amount to lean over at an easy learned rate.
    Oct 2012
    It's kind of like when you are skiing and start to make a turn in a purely mental sense, not physically though, because you are then dealing with a dual track vehicle.
    But, notice you have to move the inside leg forward and the back leg rearward to lean over, but it is the side thrust against the outside ski that does the turning initially, while angling the inside ski away first. Then if going downhill, the camber of the skis that continues to keep you heading in that direction. the fore/aft movement of the skis relative to each other also gives a little stability, but isn't really a part of the turning process. It is done simply because of the physiology of the person.
    similarly, on a bicycle where you have quite a bit of body weight already on the handlebars, then you have to apply a certain amount of extra force to one side of the bars while reducing the force on the other side to effectively coountersteer into a lean and turn.
    or even if you are seated more upright, it feels like you are pulling back on one side of the bike, while pushing on the other, but in both cases, if yo are doing so very dramatically with your body, then you are actually leaning your body away from the turn, causing the bike to have to lean over more than necessary to turn.
    Oct 2012
    One thing to note, though. It took me longer to accept this way of looking at it than the time we have been talking about it here. I had been told about how it works many years ago, and kind of observed as I rode, not being convinced until I started riding more aggressively off road, where obstacles required faster motions than can be accomplished with a natural lean and turn. Then, the "conscious countersteering" came into play, and once I was able to do it consciously enough times, it wasn't really conscious anymore. At that point, I realized that it is the same thing I do to turn naturally, and was able to relax my body more when riding.
    [QUOTE=autodoctor911;10336328 I had been told about how it works many years ago, and kind of observed as I rode, not being convinced until I started riding more aggressively off road, where obstacles required faster motions than can be accomplished with a natural lean and turn. Then, the "conscious countersteering" came into play, and once I was able to do it consciously enough times, it wasn't really conscious anymore. At that point, I realized that it is the same thing I do to turn naturally, and was able to relax my body more when riding.[/QUOTE]
    Well said, straight to the point.
    Practice...Practice...Practice...
    Another skill is knowing the abilities/limits of the design of the bike...and your own. Then not exceeding them, leaving a margin for error should the unexpected occur. When the unexpected does occur, I have found that the brain has a way of reacting positively if there is something stored for it to draw upon.
    Playing around as I did today helps bring mind and body together, acting in unison. Your point is not that aggressive riding is necessary, but only how you came to understand.
    One may never know of the pain, expense, or death that will be avoided, due to the fact that this discussion was entered into.
    How did we get off on this rabbit trail anyway? Somebody said something, somebody something else...
    All in the True Spirit of Fat Biking...no other bike allows the pursuit of rabbit trails better. Enjoying it all.
    Carry on...
    Oct 2012
    One funny thing about counter-steering that is very counter-intuitive to me is that when the rear tire loses grip, and I start to over-rotate, I really want to turn into the skid, like when recovering from a skid in a car to avoid spinning out.
    In order to get out of a skid on a bike, you have to first turn away from it, which is completely opposite of what I have learned driving cars on the track. I still usually start to make the skid a little worse, by steering into the skid, before I catch myself, and turn the other way. With a bike skid recovery is usually a back and forth movement anyways, because once you are over-rotated, and bring yourself back up, you are going to have to turn to the other side to get back on line, then turn back to the way you originally were to continue through the turn, but it doesn't help to start off the wrong way.
    If you watch flat oval dirt track racing, you can see that they are constantly adjusting the angle of the front wheel to keep from falling, or over-rotating, going to the inside of the track.
    Nemophilist
    Yes;
    I am left handed. I still do not buy into the steer away to turn on a bicycle. Heavier conveyances with much more inertia and higher kinetic energy, yes, perhaps it is more effective then, but not on a bike. Yes it can be done, but I am pretty sure it is not the way I initiate a turn. Perhaps the front tire does turn away just a touch - or at least appear to - as the contact patch changes from the center of the tire to the side, and before it then bites and wants to steer too far into the turn, but I don't feel that is the way I steer at all.
    In a stock car on street tires at an autocross? Or when I have not set my track car up for it (I'm usually too lazy)? Oh yeh, big time steering shake, all day long. Turn 8 at Watkins Glen is a good one for that too!!
    Oct 2012
    Oh, yeah, about the "shaking" to set the car into a turn. It's not the weight transfer that is necessary to generate the grip. It's the increased slip angle. tires can generate maximum cornering force at a given slip angle, and if you are turning in gently, it takes a little while to reach that slip angle, where as if you turn out, and back in sharply, you get the tires set into the right slip angle right away.
    LOL,Now we can argue about this one. I hope you are enjoying this discussion, not getting angry. If it is not fun for you, I will stop.
    Nemophilist
    Har;
    No worries. I understand all of the theories, but I quite prefer to spend my time on the application. A better use of my limited grey cells, I've always thought, and more rewarding! At a certain level, I agree with your slip angle idea. However, most drivers are still at the level of Driving The Grip (not "The Slip") in stock or lightly modified street car, and so squashing their soft suspensions and getting the car to set faster is the goal of a good shake.
    I rode yesterday, and the data says I didn't shake the bike even once. It shook me plenty.
    Oct 2012
    great. What club do you instruct for?
    Nemophilist
    Wild guess?
    Oct 2012
    cool. I'm a student in yellow, in Hill Country, and Lone star regions. Do you do any club racing?
    Nemophilist
    Nope;
    No Klub Racing, as a driver anyways. Just DE.
    1990 - Joined PCA
    1991 - 1st DE, Watkins Glen
    1996 - Zone 1 Instructor
    1997 - Zone 1 Instructor Mentor
    1998 - 2011 Central NY Region Chief Instructor
    Tracks - WGI, Mosport, Lime Rock, Mid Ohio, Mont Tremblant, Calabogie, & VIR. Road Atlanta & Sebring, but only in rental cars.
    REDLINE Rennsport Services
    Check out the Driver's Ed Education section. I think you'll like it.
    Let me know if you think you can help me with my driving!
    Nemophilist
    But...
    No one picked up on the gyro comment. I wonder if a wider axle has any bearing on the gyroscopic effect of these big tires at speed? I have come to recognize this effect for what it is, and fairly distinctly, as opposed to simple self steer from the tread pattern.
    But...
    No one picked upon the gyro comment. I wonder if a wider axle has any bearing on the gyroscopic effect of these big tires at speed? I have come to recognize this effect for what it is, and fairly distinctly, as opposed to simple self steer from the tread pattern.
    Back into Velobikes idea...Wheel Flop?
    As I understand it, two frames with the same geo, but one built with lets say a 135mm front and the other with a 110 or 100mm front axle spacing. Lets also say that we are running 5"x26 rubber on the 135 and 2"x29 rubber on the 110/100, The 5" tire is a larger dia than the 2" tire, increasing trail promoting flop, which is 'corrected' by the increased inertia. The end result...no idea, but my guess would favor the fat wheel for less flop.
    With this added to whatever head angle you have, a 29er wheelset on a fat bike could effect handling because of increased flop.
    I know there is a formula for this, but my math skills don't go that high.
    My guess also would be that axles do not figure into rotational weight.
    Question is...too little make for a sluggish bike and too much...it veers at low and moderate speeds...What is a good flop figure?
    Do I have the basic idea correct?
  67. #67
    ...What is a good flop figure?...
    That's a bit tricky to answer for a fatbike.
    With normal mtbs, there's a range of head angles and trail figures that have evolved and are known to work well. The tyre sizes and rim widths likely to be used on them vary only slightly, so what works perfectly for one setup will be pretty close for any other. Any difference in tyre profile will have only a slight effect because the tyres are narrow.
    Now look at the possible extremes on a fatbike. You can have a tyre on a 50mm rim and it is almost round in cross section. Put the same tyre on a 100mm rim and it is approaching a square cross section. Then there's the tyre pressures, anywhere between 3-12psi in most cases, and that affects the tyre profiles.
    Now imagine what happens when the handlebar is turned. Where is the contact patch in relation to the steering axis? If it is close to the axis then there's not much leverage for force being fed back from its interaction with the road surface. If it's distant, then there's more leverage for the force being fed back which will be felt at the handlebar as being harder to turn.
    Obviously it's a bit more complicated than that. There are dynamic forces involved and the bike is not upright when you're steering it. Also you're balancing all this out automatically as you ride, and we won't even consider what happens in countersteering.
    Headangle, trail and fork offset determine the flop. Taking for example a given fork with a 55mm offset, at a 70º HA the flop will be 30mm with a 100mm tyre, and with the same fork and tyre at 75º HA the flop will be 14mm, at 80º HA it is 3mm, and with a 90º HA flop is zero. A wider tyre will increase the flop and a narrower one reduce it, with this being more evident the slacker the HA.
    In my experiments I found I preferred the feel of the bike with a steep HA (around 75º) and a small offset, but a different tyre profile could completely alter that.
    In short, there's no magic formula for the best flop figure, it needs to be considered along with the tyre profile, especially at slacker head angles.
  68. #68
    So, if the purpose of a fat bike is to run the fattest rubber on the widest rims...a reg 29er wheelset may not be the best idea,...depending upon the geo.
    Perhaps my 'gut' was leading me in the right direction to ask...but I got off on axle widths, not knowing how to ask.
    If this is the route one wishes to go...the geo of the Pugs/Moonie are the better choices.
  69. #69
    So, if the purpose of a fat bike is to run the fattest rubber on the widest rims...a reg 29er wheelset may not be the best idea,...depending upon the geo...
    I think we're going to see fatbikes follow the trend towards the slacker Head Angles dictated by front suspension - ironically so that when the suspension is fully compressed the HA is around the figure we have been accustomed to.
    If that happens, then tyre development will probably follow and the tyre profiles will be made to suit.
    One way to do this will be radial tyres....
  70. #70
    bigger than you.
    Reputation: Gigantic's Avatar
    That's not quite how it works. Cornering on a motorcycle, the rider hangs off to counterweigh the bike, decreasing the lean angle and allowing the motorcycle to ride on the meatier part of the tire. (see above photo) Lateral cornering forces, in and of themselves do not cause high-sides, rather, a sudden loss or rear traction, followed by the tire quickly regaining traction with the motorcycle at a different attitude to the axis of travel, is what leads to a high-side.
  71. #71
    Nemophilist
    Ask the Man Who Owns One!
    Or put another way, it's always about contact patch, especially on pavement, and leaning off the inside maintains that. I even do it on my MTBs on certain trails in certain spots/conditions.
  72. #72
    Nemophilist
    Well...
    I'm really keen to try an On One Fatfork and see how the extra trail makes the bike behave, relative to the Enabler. Sadly, there's no money for that these days....
  73. #73
    Oct 2012
    I am going to put a lefty on my OnOne Fatty soon. SO, I may decide all I need is the suspension fork, In which case, I will have a Fatty fork to sale/trade. It's greater offset(rake) will reduce trail and flop compared to an enabler, possibly eliminating Self steer depending on what you have now.
  74. #74
    Oct 2012
    Quote Originally Posted by Gigantic View Post
    I see what you mean. The center of the tire, or just to the side of center, has a larger radius profile, which may grip better than the part of the tire that makes contact at full tilt, so ground clearance isn't the issue as much as tire grip at a particular angle.
  75. #75
    Oct 2012
    In general though, would you say, if you are experiencing too much self steer, it would help to either steepen the head angle with the same offset, or increase the offset at the same head angle?
    and
    If you are experiencing too twitchy of handling at speed, it would help to slacken the head angle, or decrease the offset?
  76. #76
    and
    My experiments lead me to prefer a steep head angle with a decent amount of trail, but now I'm not so sure if those are the important dimensions or how the tyre profile affects flop.
    This needs some further experiments.
  77. #77
    Oct 2012
    I think I actually prefer a bit slacker(68-70*) head angle with a lot of offset to keep the flop and trail down. But I have always also preferred front tires with a round profile to go with that geometry.(talking about general mtb, and my limited fat bike experiences)
    I do think a steeper angle(72-74) with about 30-40mm of rake would be best for snow riding and wider rims or squarer profiles.
  78. #78
    Oct 2012
    How were you able to try steeper head angles up to 75*?
  79. #79
    The easy way.
    A fork with adjustable A/C and offset.
    The ideal would be to also have a frame with an adjustable rear end - possibly a suspension frame with a turnbuckle in place of a strut. That way dropping the front to steepen the HA could be accompanied by a lift at the rear to preserve the BB height.
  80. #80
    Oct 2012
    ah, so when you got steeper angle, you also had lower center of gravity. weren't really changing one thing at a time, like you're supposed to when tuning geometries. not sure if it made a difference in this case, though.
  81. #81
    That's right. I'm not a research institute, just an individual looking for the best setup for personal use. All my results are necessarily subjective - ie what feels right for me is the test.
    I don't think the CoG variation (BB height) had a significant effect on the handling, just nuisance value with increased pedal strike potential. Of possibly more effect was the lowering of the front end affecting my riding position - again that needs adjustability which I didn't have at the time - but if I was doing it again, I'd look to keeping the cockpit and BB constant.
    I think it's worth people trying different setups - it's easy enough to rig up an adjustable fork and play with head angles. Everyone has different areas to ride, so what I like is not necessarily relevant to someone else.
  82. #82
    Having done a little search concerning leading vs trailing axles...I found it reported that a trailing axle is more stable at speed which has the effect of being able to get out of ruts easier. It also makes turning harder.
    Correcting flop while still providing whatever trail desired?
    Also it brought to mind TrailMakers problem with fork flex...if his bike fork resembled more of the look of a motorcycle fork...ie...where the length of the lower leg extends past the point of the axle attachment...would that not impart some stiffness at the point of need?
    Just a thought.
  83. #83
    Nemophilist
    Hey;
    Search a little and you can find pics of Velo's hacked adjustable height suspension fork. Quite possibly a classic in the niche of Rat Test Equipment.
    In sitting here and thinking about it, I can't see how any material below the axle line is anything but redundant.
  84. #84
    Oct 2012
    I think sand rat was referring to Velo's fork flex issue???
    And I think he means the through axle design that almost all motorcycle forks use, which needs a little more material below the axle to clamp the through axle.
    The motorcycle forks wouldn't work without it, since they usually don't have a bridge between the lower legs, even on conventional(nonUSD) forks. The axle is the only thing keeping the two sides moving together.
    and
    Yes the through axle type axle with the clamp material below the axle should help stiffen any fork in all directions.
  85. #85
    Sand Rat, I think you're asking simple questions about complex issues. With bike forks in the geometries we use it is possible to get exactly the same handling characteristics from leading, trailing or zero offset axles by changing the rake of the fork. Whether the axle is in front of or behind the fork leg is not really part of the equation from a handling geometry aspect. What matters is where the axle is relative to the head tube axis. And by the way we all need to go ride, this thread has gone way too long.
    Latitude 61
  86. #86
    Thanks for the save attempt AutoDoc.
    I was referring to Velo's flop discussion...I was reading that a trailing axle is less disturbed by road irregularities and saw that as a means to control flop. If a trailing axle is more stable over rough terrain, my thought was that flop would also be controlled. But did I forget about the steering axis in my impulsiveness?
    Yes, I was thinking of a TA, as you say, but not well enough stated. I think a TA is the only way to go from a safety stand point alone.
  87. #87
    Oct 2012
    I really don't know what you mean by leading, or trailing axles, sandrat.
    are you referring to leading link, and trailing link suspension designs?
  88. #88
    Nemophilist
    Hey;
    It is simply whether the axle is in front of or behind the fork blade.
  89. #89
    Oct 2012
    I don't see how that would make a bit of difference on a rigid fork.
    on a suspension fork, it might affect the angle of the wheel movement and the trail change due to suspension movement, because for a given static trail figure the forks would be either more upright with the axle in front of the legs, or more angled back with the axle behind. This also depends heavily on the offset at the crown though.
  90. #90
    Righty...-1
    Lefty...+1
    Dang, Auto Doc...just when I was beginning to trust you! LOL
    Seriously, I appreciate the help given by both, and all.
  91. #91
    Oct 2012
    I think what you said about the leading vs. trailing does hold true for suspension forks.
    A fork with a more laid back angle to the legs would tend to absorb bumps better due to the rearward component of the suspension movement. It would also dive more under braking though.
  92. #92
    Hey;
    If a straight axle, there would not be the 'extension' below the axle point to pull against, as in the leading axle pic. If the triangular material fixing the axle to the blade were longer in the lower section, would not that spread the braking force out more, reducing the undesired braking flex?
    Did some plug and click trail calculations...381mm radius - 71* head angle - no offset at crown. Rigid forks
    Leading Axle - +50mm offset = 78mm trail
    Straight Axle - ZERO offset = 131mm trail
    Trailing Axle - neg. 50mm offset = 184 trail
    NO reduction in flop for trailing axle! MUCH worse!
  93. #93
    Oct 2012
    as far as brake flex, THe farther up the fork, your axle gusset goes, the less it should flex, and any stiffness the axle interface creates would keep it from twisting as much, but I don't see how the longer lower leg below the axle would help on a rigid fork. On a suspension fork the extra length of telescoping tubes will help eliminate flex by spacing the bushings out more. That's the main reason the motorcycle forks sometimes have the fork leg go well below the axle. they want to make the outer tube overlap the inner more, while retaining the same ride height and travel.
  94. #94
    Oct 2012
    as far as your trail calculations go, I guess you are also assuming no angle at the leg to crown junction, as well as no offset. You can move the offset and trail around many ways. the legs can be bent, which gives some vertical compliance as well. The fork legs can be angled or offset at the crown, and you can move the axle around at the bottom of the fork leg. as far as rigid forks go any of those ways will net the same result for achieving the desired offset and thus trail. the only other thing that will be affected is stiffness in various directions based on any curved or tapered tubing, and the angle at which the metal can flex in relation to the forces on it.
  95. #95
    Understood, and your assumption is correct.
  96. #96
    The gusset extending further up from the axle helps, but extending the gusset below does not?
  97. #97
    Oct 2012
    A truss fork would be a good way to eliminate brake flex and twist.
    I know my Fatty fork flexes a lot under braking, but it doesn't really seem to affect anything negatively. I don't really notice any twist, and the flexing actually increases the trail when braking hard, so it might be making it more stable than if it were completely rigid.
  98. #98
    Oct 2012
    Quote Originally Posted by Sand Rat View Post
    the tubing below the axle on a rigid fork would not be supported by anything, and would not have any twisting forces on it, since the lower end can move freely.
    the lower leg on a suspension fork is supported from the inside by the upper fork leg. the longer the two pieces are, the more they overlap, and the farther apart the bushings are at any given time, thus making the whole fork stronger and stiffer.
  99. #99
    I could see my idea morphing in that direction.
  100. #100
    If I follow you correctly, the tubing below the axle IS supported by the GUSSET, which is my point.
Page 1 of 2 12 LastLast
  1. Replies: 2
    Last Post: 12-04-2012, 02:05 AM
  2. bike design contest
    By futurerocker1 in forum General Discussion
    Last Post: 04-01-2012, 08:49 AM
  3. Sultan puzzle
    By Coasting in forum Turner
    Last Post: 01-02-2012, 04:42 PM
  4. Replies: 1
    Last Post: 09-02-2011, 06:19 PM
  5. Manitou Dorado brake mount puzzle!
    By nowthen in forum Downhill - Freeride
    Last Post: 04-08-2011, 02:22 PM
