Results 1 to 18 of 18
    Jan 2013
    UMA 90mm on Pugsley -- can it be done?
    I am new to fat biking, in fact, so new I haven't ridden one yet. I am, however, building a fat bike. This is what I do--I get ideas and I run with them. I scored an essentially brand new pugs frame and managed to pick up some 90mm UMA rims that are offset (12mm) drilled. Boy they sure do look big in this frame and fork!
    The questions is: if I build up the wheels, will they fit? If so, with what tires? I will be building the wheels (and the entire bike) myself.
    I tried to search but couldn't find anything conclusive at all. Any help would be appreciated!
    Jan 2013
    I should add that my concern is purely whether they will fit the frame and fork. I will figure out the drive train stuff. My plan is to either run single speed or 1 x 10
    Sent from my SPH-L720 using Tapatalk 4 Beta
    Re: UMA 90mm on Pugsley -- can it be done?
    Yep, I believe people have run 100mm rims with Nates.
    Reputation: Lone Desert Walker's Avatar
    Quote Originally Posted by ultraspontane View Post
    What?!!!! I'd like to see that!!
    " F#ck it, lets go ride bikes!"
    Quote Originally Posted by Lone Desert Walker View Post
    http://fat-bike.com/2011/11/dear-nate-i-love-you/
    May 2012
    hmm wait.. so 100mm rims fits in the pugs!?!? why the moonlander then? Assuming I'm not riding through soft mud...
    Quote Originally Posted by boogman View Post
    Thats a hundie with a 3.7, I'm sure it barely fits. none of the big casing tires will fit in a pug on that rim though. BFLs on 80s probably have the same clearance, I'd rather have less rim and more tire with the same clearance.
    Jan 2013
    So I could probably fit nates?
    Reputation: Nakedbabytoes's Avatar
    I have BFLs on RDs front and rear on my Necro. I think it is either/or for fit of a big tire with skinnier rims(Marge Lites or RDs) and clearance vs CS with 3.8s. I like the versatility of the RD rims on a Necro myself. Planning on getting a Nate soon, BFLS spun out on me in a race I just did...cost me first place!
    Suckage. But I assumed I was gonna be dead last anyways, so I shocked myself on how well the bike did.
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Reputation: vikb's Avatar
    Quote Originally Posted by Nakedbabytoes View Post
    Just a note - I have found the profile of a 4" tire on 82mm rims wasn't as nice for turning as the same tire on 65mm rims. I got a set of BFLs for the 82mm rims to get back the rounded tire profile.
    This was on dirt. On sand or snow the tire may perform differently.
    Safe riding,
    Vik
    www.vikapproved.com
    Jan 2013
    I'll never fit a bfl... anyone think a 4" like a husker will fit?
    Quote Originally Posted by vikb View Post
    Thanks vikb, yeah I could see that. My Endos look like a Caddy Excalade with 22s on RD rims, they definately spread that tire out! And the endo was pretty flat profile anyways! I need something that grips better though(maybe a HuDu?) as I spun out on hills more than once and had to run up them instead(powdery dirt). Normally, I find BFLs or Endos to be pretty good 90% of the time I am riding. But I do need a rear that grips better for steep hills.
    2014 Big Dummy
    Jan 2013
    I've got some bfl tires coming and will report back on frame and fork clearance with the uma 90mm rims shortly.
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    I've run Endos and Larry's on 100mm chopper rims for a long time now. They barely fit, but the profile of the tire is super flat which is nice in soft sand and barely-tracked snow. That's where I usually ride. My guess is that the 4.7's on narrower rims will be a bit rounder and taller, which might be better for really rough tracks and summer riding as well as soft surfaces. If I had to choose new wheels I'd probably flip a coin.
    I'm covered in beer.
    Jan 2013
    That is a handsome looking bike with the contrasting silver parts and rims on the black Frame.
    Jan 2013
    No ride reports for a bit too come, but the initial mounting has them fitting!
    Reputation: ferrstein's Avatar
    UMA 90s with BFLs may actually fit but would have almost no clearance.
    I got Clown Shoes and BFLs on my Pug but it took a little convincing:
    Clown Shoe + BFL + Pugsley = Fatties Fit Fairly Fine
    Jan 2013
    The fit and ride just fine. Clearance is tight, but many trail miles at 9psi and no issues.
  1. Replies: 1
    Last Post: 05-10-2013, 06:38 PM
  2. 90mm lefty on Scalpel 29?
    By nathanbal in forum Cannondale
    Last Post: 05-01-2012, 07:53 PM
  3. 9 zero 7 chain clearance with 90mm UMA
    By thickfog in forum Fat bikes
    Last Post: 11-21-2011, 08:23 PM
  4. Replacing a 90mm fork on a SJ HT with?
    By fireroad in forum Specialized
    Last Post: 10-05-2011, 11:54 AM
  5. f90rl 90mm to 80mm?
    By tripwr1964 in forum Shocks and Suspension
    Last Post: 03-21-2011, 05:42 PM
