Results 1 to 9 of 9
    Reputation: druidh's Avatar
    Tyre pressures...
    26 x 4.0 AND 40 psi???
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I'm assuming that is the max allowable.
    If you want to be comfy, probably closer to 10.
    i am running 7.5 in my BFLs
    stubbster
    Reputation: Smallfurry's Avatar
    It looks like its recommending 40 - 65 PSI. Which is nuts. I run 42mm nordic spikes, at around that.
    A big boy did it, and ran away.
    62*28'
    65 psi would probably be a very interesting ride. Especially if it was on a nice hard pack, rooty trail.
    Flotilla or Buffet.
    N8R
    N8R is offline
    What tire make and model is that 26 x 4.0?
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    Quote Originally Posted by N8R View Post
    Looks like an Origin8 Devastator!
    Reputation: shiggy's Avatar
    Dec 1998
    It is a Vee Rubber Mission.
    The pressure range is WAY high.
    mtbtires.com
    Reputation: thesilversurfer's Avatar
    Oct 2011
    I run my BFL's on UMA 90's at 7.5 in fresh snow conditions and they are great. If you did run the pressures as high as the tire is recommending get a very thick gel saddle.......lol
