Results 1 to 10 of 10
    Oct 2011
    Turnagain fr80 rims no go with offset.
    I was going to build up a set of turnagain rims for my wife's new pugsley. It turns out that I can't use it for the rear because the spoke holes are offset 24mm from center. They are drilled with 64 holes so I would assume they expected to be used for an offset build. I checked on freespoke with a virtual build and they came up with about 27% spoke tension on the second set which is unusable. If anyone out there has a different experience I would like to hear what you did.
    Jan 2013
    Are you sure you put your offset on the proper side and used 17.5mm for your hub with the freespoke program? When I was playing around with the idea of doing an offset clownshoe for my pug, the tension came out around 88% with a 20mm offset. I don't know what the ERD is for the Turnagain rim but something doesn't seem right if you are getting a 27% with a 24mm offset.
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    I would 2 cross and use thinner spokes on the non drive side
    I wish I could give you a better answer but the number come out bad
    good luck
    I am slow therefore I am
    Sup
    Dec 2008
    Quote Originally Posted by ntm1973 View Post
    I think he is saying the spoke holes are 48mm apart .... double of what surly has
    Oct 2011
    Yes spoke holes 48mm apart, way too wide for pugsley offset.
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    the spoke holes and erd are not that much different then a marge lite or rolling Darrel
    Read my BLOG!
    just a guy who loves bikes and exploring
    Oct 2011
    The spokes are offset twice as far from the center of the rim as a rolling Darrel. This puts the spoke holes about 15 mm from the outside edge of the rim. If you lace offset onto the right side spoke holes it leaves 65 mm of rim unsupported on the left side and rt side spokes almost straight down to the rim.
    Oct 2011
    I do plan to use these for the front. I will lace then to a surly ultra new ( or is it ultra *****en) front 135mm hub. The wider offset of the spoke holes will lessen the bracing angle of the spokes but it will still be at an acceptable range.
    I like the idea of a bolt on front hub.
    Jan 2013
    mactweek,
    If the spoke holes are 48mm apart then they are 24mm off center. When I plug that into freespoke with a 17.5mm offset shimano rear hub laced 24mm to the right, I ended up with:
    Bracing angle rt 3.5 left 3.1
    Tension distribution rt 89% left100%
    I used the same erd as a clownshoe. That looks like it would be a good build to me.
    I'm not trying to be a smart*, just trying to understand what I am missing?
    Oct 2011
    I wish I could get figures like those. I played around with different rims and offsets on freespoke and determined that they would work with with moonlander offset but not pugsley. I built up one on a Hope Fatsnow rear hub and it worked fine, So now I guess I can use my R.D. rim for the pugs.
  1. The New Carbon Rims vs Surly Rims For Offset Use?
    By Sand Rat in forum Fat bikes
    Last Post: 10-06-2013, 11:08 PM
  2. Replies: 4
    Last Post: 05-06-2013, 11:32 AM
  3. Iditarod trail Turnagain Pass
    By MikeC AK in forum Alaska
    Last Post: 12-01-2012, 10:54 PM
  4. Questions about FAT Bike Offset Rims
    By Chunky Tire in forum Fat bikes
    Last Post: 10-24-2011, 12:19 PM
  5. Offset rims: 32H vs 36H
    By intheways in forum Fat bikes
    Last Post: 09-12-2011, 03:26 PM
